Question about Dehumidifiers
Fix a bell and howell personal humidifier. It won't work so what do i need to do to fix?
  • 2,760 Answers
If it wont work at all, start by looking at the bucket sensor, this is a very common thing to get out of adjustment and stop the unit from working , see if it moves the way it should and has no broken parts , ck to see if bucket is all the way in as it should be , and not slightly askew or something , also ck to see that entire unit is level !! they wont work if tilted to side
Posted on Dec 09, 2014
  • 1043 Answers
SOURCE: Help with my Bell and Howell BH-10
You should have had a cable come with your camera; one end would plug in to your camera with a small square end, and the other end would connect to your computer. The computer end would be a standard USB end. You should have also received a disc in your box that had software to load onto your computer. Once that software was loaded, you would plug the camera in. Your computer would recognize the camera and startup the software. A box would open and it owuld give you a choice of things to do. Usualy it would give you thumbnail views of all of the pictures in your camera and ask if you wanted to copy only some of the pictures over to the computer, or all of them. It would also allow you to delete all of the pictures from your camera.
ddddddddd
If you go to either of the following websites you can download the software you need.
http://www.bioticaindia.com/bh-10.html
http://members.driverguide.com/driver/detail.php?driverid=
76886&action=summary&from_ums=1
That should do it.
Posted on Apr 07, 2010
muntejaya
  • 10421 Answers
SOURCE: driver for bh-10 bell howell camera
Kindly get it downloaded here : www.opendrivers.com/.../bell-howell-free-driver-download.html
www.nodevice.com/driver/company/bell_howell.html
www.bellhowell.com/
best regards, Jay
Posted on Feb 19, 2011
SUNILVOIP
  • 250 Answers
SOURCE: Need manual for Bell & Howell 456A dual autoload projector
you can try this link
Click Here
Posted on Nov 20, 2011
SOURCE: I need a tv cable for my bell+howell DV550
manuel for 2.0 megappixel dv65
Posted on Nov 26, 2011
  • 6771 Answers
SOURCE: downloadable instruction manual for Bell & Howell PZ3300
Try http://produtools.com/d/manuals.php the manuals are free and can be downloaded in your computer.
Posted on Jun 16, 2012
I have a customer who has a model 1700 dehumidifier Connected to ductwork with a/c only air handler. Not Sure why this is needed or correct way to wire. Also There is no remote humidifier & unit is...
I have to agree with you. I don't see the need for the dehumidifier either. As the AC unit alone, does have some dehumidifying capability.
Your customer would be better served using an independent Low Temp dehumidifier in the basement. If that's the area they are trying to dehumidify because of dampness in the basement.. It certainly would be less costly to operate. But, any unit that is not a Low Temp unit won't work well in a basement.
I hope this helps and good luck convincing your customer of this.
Thanks for choosing FixYa.
Aug 24, 2011 | Aprilaire 1700 Dehumidifier
Won't catch and empty water through attached hose.
My humidifier has a knockout inside the hose connection, that you have to remove. simple but check it out.
Jul 02, 2011 | Maytag Dehumidifiers
Thenunit keeps poping the circiut breaker it will run obout 30 seconds
There is a short in the humidifier. Continued operation, with out proper repair can result in property damage, personal injury and/or death.
Unplug it. It will likely be less expensive to replace than repair.
Jul 17, 2010 | Daewoo DHC250 Dehumidifier
543515 humidifier runs but doesn't collect any water.
try checking the setting of your humidifier, if the actual humidity level matches, what is set on your unit.
Aug 01, 2009 | Kenmore 54351 Dehumidifier
Humidifier does nto turn on.
It sounds like the Dehumidifier has a problem somewhere on the circuit board. You could try and find a local humidifier repair shop in your area otherwise it may be cheaper to purchase a new replacement instead of having it fixed. Good luck.
Tech - 101
Jun 23, 2008 | Whirlpool AD40USR Dehumidifier
Humidifier is freezing up
I have the same dehumidifier and it does the same thing. but I was able to fix mine. It was not low on refridgerant. There is a temp. sensor clamped to the evaporater coil with a thin metal clip. The clip rusted out and the sensor fell out of position. I used a small stainless steel hose clamp and clamped the sensor back into position. It now works fine
Apr 10, 2008 | Fedders A7DH45B2A Dehumidifier
Maytag M7DH45B2A freezing problem
Is this a humidifier or dehumidifier?
Nov 15, 2007 | Maytag M7DH45B2A Dehumidifier
Humidifier Runs but no water collected
Are you talking about a dehumidifier or a humidifier. If you are talking about a dehumidifier, it works by blowing air across a cooling coil causing condensation and the water will drip and pool. The cooling is caused by a compressor working like refrigerator, but using the effect to dehumidify. To check if the cooling coil is working there will be a metal can like in it with tubes in and out. One of the tubes should be warm(input) and the other tube should be cold, if not your compressor is not working. If freezing up, low freon. Check to see if the compressor shuts off very quickly, that would be too much freon. This is not user servicable. Now a humidifier works several different ways. One way is a fan with cloth belts rolling through water using evaporation to humidify. Another way is for a circular fan like on a motor to turn. It has a hollow piece into the water. It picks up water and then through centrifugal force aerates. One way is for a sonic humidifier. All the types have a problem with eventual calcification or mineral build up in the water handling paths. Lime-away or Concentrated Lemon Juice will dissolve this. The lemon juice is the most fun. It will turn your toilet bowl white and also remove rust stains from laundry...
May 01, 2007 | Maytag M7DH65B2A Dehumidifier
Dehumidifiers Logo
131 people viewed this question
Top Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Dehumidifier Expert? Answer questions, earn points and help others
