Question about Kitchen Appliances - Others
<!-- from fixya rte -->How to replace the curtain switch. - Kitchen Appliances - Others
    Novelist:
    Champion:
  • 373 Answers
On the curtain at bottom corner is a magnetic switch you have to pry it off it is stuck on with stick-em the one one the curtain has now wire on it and the other part of the switch will that runs back to the control board.
Posted on Nov 14, 2014
I am getting a message saying the Curtain Open and I can't get my ice machine to come on?
I didn't think their smaller units had a curtain, but it is referring to the plastic shield that hangs in front of the ice making grid or evaporator. This must be closed for the unit to run and there is a magnetic reed switch located on the bottom right hand corner of the curtain to prove that it is closed. Actually the magnet is in the curtain and the reed switch is snapped into the side of the grid. Make sure the curtain is in place and the magnet has not broken off. If that is in tact look to see if the reed switch is in tight. IF YOU DO NOT HAVE A CURTAIN... some units had a small plastic flapper at the bottom of the grid that was activated whenever ice dropped. Same system though with a magnet and reed switch. The magnets on some of these curtains and flappers were just surface mounted with some kind of adhesive and others have it captured inside of a plastic pocket made into the curtain. So if you don't see a magnet look for a spot where it used to be. If you want to prove this is the problem just get a magnet and hold it up to that spot for about 10 seconds and see if the unit cycles on. You will then have to order a new curtain or flapper or attach a magnet to the broken spot somehow.
Mar 07, 2015 | Manitowoc QY-0214A Self Contained Ice...
Why my scotsman ice machine goes off on the refridgertion light
This could be several things. This means it has tried to harvest the ice 3 consecutive times before the machine has locked out.
1. Likely Cause, Ice bridge thickness too small, not enough ice to open curtain. PROBABLE SOLUTION, Check and adjust if needed.
2. LIKELY CAUSE, ice bridge too large, ice frozen to evaporator frame. PROBABLE SOLUTION, Check and adjust if needed.
3. LIKELY CAUSE, Purge valve does not open, water melts ice bridge, not enough ice to open curtain. PROBABLE SOLUTION, Check purge valve during harvest.
4. LIKELY CAUSE, incomplete ice formation. PROBABLE SOLUTION, Check water distributor for partially plugged holes. The machine needs to be cleaned and sanitized every 6 months.
5. LIKELY CAUSE, Curtain out of position. PROBABLE SOLUTION, check curtain for swing restriction.
6. LIKELY CAUSE, Curtain switch dose not open when curtain does. PROBABLE SOLUTION, Check switch with ohmmeter if bad replace.
7. LIKELY CAUSE. Machine in very cold ambient. PROBABLE SOLUTION. Move machine to a warmer location.
8. LIKELY CAUSE. Hot gas valve does not open during harvest. PROBABLE SOLUTION. Check hot gas valve with a volt meter during harvest mode to see if you are getting correct voltage to it. If not then replace control board . IF yes and valve is not opening then replace valve.
9. LIKELY CAUSE. Harvest assist probe out of position - ejector pin not retracted. PROBABLE SOLUTION. Check harvest assist mechanism - spring should retract pin.
10. LIKELY CAUSE. Damaged evaporator. PROBABLE SOLUTION. Check evaporator surface. Make sure the plates where they intercept each other is not loose this will cause ice to hang up. check to make sure the nickel is not peeling off, if so then the plate will need to be replaced.
11. LIKELY CAUSE. Fan motor stays on during harvest. PROBABLE SOLUTION. Check controller using test mode. If this dose not help you then give me the model number so i know what machine you have.
May 28, 2014 | Scotsman Ice Maker CM3 30inW Cubed Ice...
Max harvest retrying
Likely cause,
1. Ice bridge thickness too small, not enough ice to open curtain.
Solution, Check and adjust if needed.
2.Ice bridge thickness too large, ice frozen to evaporator frame.
3. Purge valve dose not open, water melts ice bridge, not enough ice to open curtain.
Solution, Check purge valve.
4. Incomplete ice formation.
Solution, check water distribution for partially plugged holes.
5. Curtain out of position.
Solution, check curtain for swing restriction.
6. Curtain switch dose not open when curtain does.
Solution, Check switch with ohmmeter.
7. Machine in very cold ambient area.
Solution, Move machine to warmer location.
8. Hot gas valve dose not open.
Solution, Check hot gas valve, check controller using test mode.
9. Harvest assist probe out of position - ejector pin not retracted.
Solution, check harvest assist mechanism-spring should retract pin.
10. Damaged evaporator.
Solution, Check evaporator surface now would be a good time to make sure evaporator plate is not dirty this will cause ice to hang up on evaporator plate also check plate to make sure all cross points are not loose.
11. Fan motor stays on during harvest.
Solution, check controller using test mode.
Jul 18, 2013 | Scotsman HD22B-C0322MA-1B Hotel / Motel...
Manitowoc Ice machine only makes 2/3 bin of Ice and shuts off
The unit shuts off based on the magnetic reed switch in the plastic curtain on the front of the evaporator. If the ice is not falling as one single sheet with about 1/4"-3/8" of a bridge conecting all of the cubes then the ice is too thin. When the ice falls (in a single sheet of ice) if there is enough ice in the bin to hold that ice up and keep the curtain open the unit shuts down. A full bin may only be what appears to be 2/3 or 3/4 of a bin full because the ice sheet is propped up behind the curtain. If the ice sheet is too thin and does not fall as a single sheet more often than not a single cube or a piece of a cube can get caught between the curtain and the evaporator plate. This can shut the unit down for several hours until that piece melts and the curtain closes again.
Dec 19, 2010 | Manitowoc - QD-0212A/115-1
I have a model qd0452a manitowoc and it will not stop making ice
Very unusual for one of these to not stop. There is a magnetic proximity switch located on the bottom right side of the water curtain that serves to both cancel a harvest/drop and to shut the unit down on a full bin. When a drop occurs the control board sees a open and then close of the switch and restarts a freeze mode. If the ice drops and the bin is full the curtain is blocked by the ice behind it from closing again and the unit shuts down on a full bin indication. If the curtain does not open and close after 3 hours it would lock the unit out. Therefore I assume that the switch and the board are working. Most likely you either have the unit on a non-Manitowoc bin or are missing a deflector plate in the Manitowoc bin and the ice is falling out of a service door.
Nov 17, 2010 | Manitowoc SY0454A S Series Ice Maker...
We have four Scotsman Ice Makers. The curtains are beginning to turn a little green. What is the approximate cost of replacing these curtains. How much per curtain?
Unless they are terrible you can clean the curtains. What you do is put icemaker cleaner in the icemaker and run it through a cycle. I don't know how much the curtains cost.
Sep 28, 2010 | Scotsman Ice Maker CM3 30inW Cubed Ice...
I am using the Bissell device to vaccuum curtains. Now I
I wentto WalMart and a sales rep showed me how the machine works. I had already attached the curtain extension back in the proper place ont the machine. This action automatically returned the suction to the floor.
Sep 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
Screechy shower curtain
they do make chrome plated, plastic curtain rings.
Apr 12, 2009 | Home
Nikon 6006 shutter curtain
Shutter Curtain needs to be replaced.
There are 2 of them. Usually one goes out of position and brakes.
Mar 22, 2009 | Nikon N6006 35mm SLR Camera
Kitchen Appliances - Others Logo
47 people viewed this question
Top Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Are you a Kitchen Appliances - Other Expert? Answer questions, earn points and help others
