Question about Whirlpool duet Washing Machines
HOW DO I OM OUT A PRESSURE SWITCH # W10156252 TO KNOW ITS GOOD OR BAD THANKS..
    Problem Solver:
  • 11 Answers
is this kinda pressure switch u was needing to knw?
Posted on Nov 29, 2014
4 Suggested Answers
  • 643 Answers
SOURCE: Any way to bypass the W10156252 pressure switch?
No you cant bypass the switch. what it does is to stop the flow of water comming in to the washer.
if you short it out water will not turn off and it will overflow. it you open it up you will get no water.
Are you sure the switch is bad. A common problem is that the hose that it is attached to it gets plugged up. have you tried to blow through the hose to see if it is clear.
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
Posted on Jul 09, 2011
Macmarkus
  • 2605 Answers
SOURCE: I have a kenmore elite
Hello, welcome to FixYa.
I understand you have a He5t Kenmore washer with the pressure switch "no longer made"...yes this has been a problem I know...they've revised the componets and aren't compatable...what they were thinking I don't know !
If you act fast you might get one, I checked at the link below and they claim to have one. Good luck.
http://www.appliancepartspros.com/Appliance-Parts/whirlpool-switch-item-number-ap5264563.aspx?pn_=W10156252
Thank's for coming to FixYa and good luck. Please take a moment to rate the assistance you received here today.
Regards,
Macmarkus :)
Posted on Sep 17, 2011
  • 3 Answers
SOURCE: I CAN NOT ORDER PART
That's because it's no longer available. Use part number W10312527 as a comparable replacement. Note that you may have to make a slight modification to the connector for it to work with the new assembly. Several vendors have it on hand. I used Appliance Repair Stop (http://www.amazon.com/gp/product/B004PLP6ZY/ref=cm_cr_rev_prod_title) and received my replacement within days of placing the order.
Posted on Jun 14, 2011
I have a kenmore elite He5t washer.. It needs a pressure switch manufacture # w10156252 witch is nolonger made! Any suggestions?
Regards,
Macmarkus :)
Sep 17, 2011 | Kenmore Elite HE5t Washer
I have a Maytag front load Washer Model MHWE500VW10 (5000 Series) . The dreaded F35 / SUD error code keeps coming up. I have checked the tubing and electrical connections to the Water Level Pressure...
Hi
There is only one Analog Pressure Sensor Switch Part no. W10156252, another one that it has is the water level switch (part no W10415587). I believe you are talking about the first one as that is what error code F35 means (ANALOG PRESSURE SENSOR FAILURE). Hope this helps...please post back for further assistance.
Daniel
Sep 17, 2011 | Maytag MAH21PDD Commercial Front-Load...
Codes SUDS and F35 appear. unable to use washer.
This point to a pressure switch issue. If you remove the top panel, three screws in the back, you will have access to the pressure switch. With the tub empty, remove the vinyl hose from the switch and blow backwards through the hose to clear any restrictions. If the fault codes return after diong this, you will likely need to replace the pressure switch. Part number W10156252 (click image)
Hope helps.
Sep 05, 2011 | Kenmore Elite HE5t Washer
F35 error need to replace analog switch
F35 error code means a problem with the ANALOG PRESSURE SENSOR switch operation
Could be a blockage in the air dome or pressure switch hose (Item 29). The pressure switch is located underneath the main top on the right hand side. (See image) The air dome is located on the back of the tub on the left hand side.
If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (Item # 20) Part # W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Part Number W10156252 (AP4323930) is used with the following appliance models: WFW9600TA00, WFW9600TB00, WFW9600TC00, WFW9600TU00, WFW9600TW00, WFW9600TZ00, and more.
Hope this helps.
Jul 15, 2011 | Washing Machines
Any way to bypass the W10156252 pressure switch? The OEM part number is now W10415587, and is not available until August, 2011. The wiring diagram doesn't give details of the switch. Model...
Jul 08, 2011 | Kenmore Elite HE5t Washer
My washer keeps getting and F35 error code and stopping
Hope this helps.. The "F35" error code is indicating a problem with the analog pressure sensorswitch operation (key#20). There could be a blockage in the air dome or pressure switch hose. The pressure switch is located underneath the main top on the right hand side. The air dome is located on the back of the tub on theleft hand side. If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (key#20) part# W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Jun 20, 2011 | Maytag Washing Machines
My HE3 washer is displayer an F35 error
Sorry to read about your problem, I hope this helps you out.
The F35 failure is displayed if the analog pressure switch has a calibration error.
There are two things you can check for this problem if you're comfortable with do-it-yourself.
Remove the washer top to access the pressure switch on the right hand side of the cabinet near the top. You'll want to check if the pressure hose is fixed correctly and not loose. Check if the Air trap is not blocked. You can do this by removing the hose and blowing in it towards the tub. It should blow freely and you might even hear bubbles. If you can't blow or it's hard to blow then most likely the hose is kinked or blocked.
If the hose is not blocked or kinked then the pressure switch is most likely the problem and will need to be replaced.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Jan 01, 2011 | Washing Machines
F35 Flashing
The "F35" error code is indicating a problem with the ANALOG PRESSURE SENSOR switch operation (key#20). There could be a blockage in the air dome or pressure switch hose. The pressure switch is located underneath the main top on the right hand side.The air dome is located on the back of the tub on the left hand side. If the pressure switch hose and the air dome is clear of any blockages the likely failure is the water level pressure switch (key#20) part# W10156252. Replacing the pressure switch will likely resolve the "F35" issue.
Sep 05, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What is f35 code on kenmore he5t?
If the fault codes return after diong this, you will likely need to replace the pressure switch part number W10156252 ,You can get it at a local appliance parts dealer or online at www3.sears.com
Feb 28, 2010 | Kenmore Elite HE5t Washer
I HAVE A WHIRLPOOL DUET STEAM MODEL WFW 9600 TAOO. NO WASH CYCLES WILL START. I GET A FLASHING 'SUD' AND THEN CODE F 35. DO YOU KNOW WHAT THE PROBLEM IS? WHAT PART NUMBER DO I NEED? WHERE CAN I FIND IT?...
SUD, usually caused by using the wrong type of soap. Your soap should have the letters "HE" on front of box/bottle. SUD can also be a bad drain pump, question is, does it still have water showing in tub?
F35, is a pressure sensor # W10156252, good luck finding it, as Whirlpool has problem keeping these things in stock. They list price at $112.82. Only takes about 20 minutes to change. Research sears.com, select PARTS Direct, enter model number, click on cabinet parts, find analog pressuer switch, see if they have in stock. Or, research the net for someone that does.
Take top of washer lid off, pressure switch is located on top right rear side wall of machine.
Good luck.
Oct 01, 2009 | Whirlpool Duet 4.0 Cu. Ft. Steam Washer
Washing Machines Logo
Dan Webster
Dan Webster
Sal De
