Question about Ricoh Aficio SP 100SU e Laser Multifunction Printer Monochrome Plain Paper Print Desktop
<!-- from fixya rte -->Ricoh aficio sp 100su has error code c6 - Ricoh Aficio SP 100SU e Laser Multifunction Printer Monochrome Plain Paper Print Desktop
    New Friend:
  • 33 Answers
SC101 c6 C CIS Lamp/Scanner Motor Error A problem occurred with the CIS or scanner motor in the flatbed scanner: -Carl
Posted on May 03, 2016
  • Rainer Verhoeven
    Rainer Verhoeven Sep 02, 2017
    Hi Carl, thanks for this. But how can the problem be resolved? Rainer
Bubbabear64
  • 2794 Answers
SOURCE: Error code SC305 for Photocopier Ricoh Aficio 1224c
Its a charge corona cleaning error. Try turning the power off, wait 10 seconds and turn it back on.
If that doesn't reset it, it could be the pcu, toner collected on the mechanism.
If turning it off and back on isn't fixing it, you should get a technician to look at it to see what the trouble is.
Posted on Jun 19, 2008
SOURCE: ricoh aficio 2022 error code sc542
1. Mode(Yellow Button)
2. 107
3. Press STOP Button for 3 second (RED Button)
4. Copy Sp
5. 5810#
6. Excute
7. Power Off
8. Power On
Posted on Feb 24, 2009
  • 86 Answers
SOURCE: Error Code SC580 on Ricoh Aficio SP C811DN
First try switching off and on the printer to reset the error.
If still there the error check the following;
  1. Check CN983, it may be disconnected on the IH inverter.
  2. Defective IH inverter - replace IH inverter.
  3. Defective IH coil unit - replace IH coil unit.
It is a bit complicated to repair these parts.
Better to contact an engineer.
Goodluck and please rate me, thanks.
Posted on Mar 01, 2009
  • 29 Answers
SOURCE: Ricoh Aficio SP 420dn shows SC545 error code after
As NALDZ said, sometimes when the power drops out the thermistor will play up a little. Sometimes this can be caused by toner being caked up on the thermistor. But in most cases it can be reset easy enough.
if you walk up to the machine in COPY mode.
simply press.
(yellow clear), 1 , 0 , 7 (hold red stop button)
The screen will change, if you hold '#' on the keypad and press 'copy sp' on the touch screen you will be into ricoh service modes.
All you will have to do now to reset your error is simply switch the machine off at the main red switch below the plastic flap toward the bottom of the machine.
problem solved =]
ta!
Willi
Service Engineer
Posted on Aug 18, 2009
bosegautam11
SOURCE: Ricoh Aficio SP C411dn error SC542
Ricoh Aficio error SC542
Posted on Sep 26, 2011
What does the error message C8 mean?
press the helpful button
found this on fixya by J Mcallister
Heating roller warm-up error 2
?? The heating roller temperature does not reach the ready
temperature for 90 seconds after the heating lamp on.
?? The heating roller temperature does not reach 80°C for 13 seconds
after the IH inverter on.
?? Defective thermistor
?? Defective IH inverter
Related SC code: SC 542
1. Check if the heating roller thermistor.
Ricoh Aficio SP 100SU User Manual Error And Status Indicate On The Control...
Jan 27, 2016 | Ricoh SP 112SU 3in1 Laser Printer
My new ricoh aficio sp 100su ddst printer has hardly printed 100 pages and now it show E7 and doesn't print. what must I do?
Go to page setting option and set page range and page auto print. If printer ok then may be E7 browser not full support so that up to date then you try.
Read More Help... Ricoh SP 100 Printer Need to press Form Feed button every time to print... and Ricoh Printer Support
Thanks,
Sep 10, 2014 | Office Equipment & Supplies
Ricoh c8 problem solution
hi sir help me rico sp 100su c8 error whats the problem
May 19, 2014 | Ricoh Aficio SP 100SU e Laser...
Show my printer on display C8 on Ricoh SP 100Su
Fusing Reload Temperature Error (Fatal Error)
Fusing thermistor deformed or out of position ? Fusing lamp harness loose, broken, defective ? Fusing unit defective ? After servicing the machine to solve the problem, the service technician must execute a "Fuser SC Reset". Otherwise, the machine will continue to issue this SC code and cannot be operated.- Carl
Aug 02, 2013 | Ricoh Aficio SP 100SU e Laser...
Error code c8
error c8 on lcd screen
Jul 15, 2013 | Ricoh Aficio SP 100SU e Laser...
How to solution of FUSER TEMP.
my rocoh printer SP 100su show on lcd panal C8 error code . power on .
May 17, 2012 | Ricoh Aficio Sp 1000sf All-In-One Laser...
Ricoh Aficio SP 100SU e Laser Multifunction Printer Monochrome Plain Paper Print Desktop Logo
1,075 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
