Can't change slides on powerpoint
Have no problem installing flashdrive but can t change slides. What am I doing wrong?
  • 2,509 Answers
Guess as no info
try saving file as a dot ppt not a dot pptx
Some more details are required, equipment, how you select or load file, origin of file etc
Posted on Nov 13, 2014
PowerPoint Viewer error 32-bit
Try PowerPoint Repair Toolbox is powerful .PPT repair software, resolving any problem, causing the damage of PowerPoint files.
For more: https://www.pptrepairtoolbox.com/
Apr 09, 2015 | Microsoft Office Professional 2007 Full...
How to make power presentatio?
  • If Office PowerPoint 2007 is already running, save and close any open presentations, and then exit and restart PowerPoint 2007.
Find links to information about saving presentations in the See Also section.
  • If Office PowerPoint 2007 isn't already running, start it now.
In the Slide pane, you can work directly on individual slides. za001093949.gif Dotted borders identify placeholders, where you can type text or insert pictures, charts, and other objects. za001093950.gif The Slides tab shows a thumbnail version of each full size slide shown in the Slide pane. After you add other slides, you can click a thumbnail on the Slides tab to make the slide appear in the Slide pane. Or you can drag thumbnails to rearrange the slides in your presentation. You can also add or delete slides on the Slides tab. za001093951.gif In the Notes pane, you can type notes about the current slide. You can hand out your notes to your audience or refer to your notes in Presenter view when you give your presentation. Note By default, Office PowerPoint 2007 applies the Blank Presentation template, which appears in the preceding illustration, to new presentations. Blank Presentation is the simplest and most generic of the templates in Office PowerPoint 2007. Blank Presentation is a good template to use when you first start working with PowerPoint because it is straightforward and can be adapted to many presentation types. To create a new presentation that is based on the Blank Presentation template, click the Microsoft Office Button za010077102.gif, click New, click Blank and recent under Templates, and then double-click Blank Presentation under Blank and recent.
After you open the Blank Presentation template, only a small portion of the Notes pane is visible. To see a larger portion of the Notes pane so that you have more room to type in it, do the following:
  1. Point to the top border of the Notes pane.
  2. When the pointer becomes a za010205206.gif, drag the border up to make a little more room for your speaker notes, as shown in the following illustration.
Name and save your presentation As with any software program, it is a good idea to name and save your presentation right away and then to save your changes frequently while you work:
  1. Click the Microsoft Office Button za010077102.gif, point to Save As, and then do one of the following:
    • For a presentation that can be opened only in Office PowerPoint 2007, click PowerPoint Presentation.
    • For a presentation that can be opened in either Office PowerPoint 2007 or earlier versions of PowerPoint, click PowerPoint 97-2003 Presentation.
If you choose this option, you cannot use any of the features that are new in Office PowerPoint 2007.
  1. In the Save As dialog box, in the Save in list, select the folder or other location where you want to save your presentation.
  2. In the File name box, type a name for your presentation, or do nothing to accept the default file name, and then click Save.
Add, rearrange, and delete slides The single slide that is provided automatically in your presentation has two placeholders, one formatted for a title and the other formatted for a subtitle. The arrangement of placeholders on a slide is called a layout. Office PowerPoint 2007 also provides other types of placeholders, such as those for pictures and SmartArt graphics.
When you add a slide to your presentation, you can do the following to choose a layout for the new slide at the same time:
  1. On the Slides tab, click just below the single slide that already appears there.
  2. On the Home tab, in the Slides group, click the arrow next to New Slide.
za001093948.gif The name identifies the content that each layout is designed for. za001093949.gif Placeholders that display colored icons can contain text, but you can also click the icons to automatically insert objects, including SmartArt graphics and clip art.
  1. Click the layout that you want for your new slide.
The new slide now appears both on the Slides tab, where it is highlighted as the current slide, and in the Slide pane. Repeat this procedure for each new slide that you want to add.
Tip If you want your new slide to have the same layout that the preceding slide has, you can just click New Slide instead of clicking the arrow next to it.
Aug 17, 2011 | Microsoft Office Professional 2007 Full...
Ano ang power point
PowerPoint is a presentation program developed by Microsoft. It is included in the standard Office suite along with Microsoft Word and Excel. The software allows users to create anything from basic slide shows to complex presentations.
PowerPoint is often used to create business presentations, but can also be used for educational or informal purposes. The presentations are comprised of slides, which may contain text, images, and other media, such as audio clips and movies. Sound effects and animated transitions can also be included to add extra appeal to the presentation. However, overusing sound effects and transitions will probably do more to annoy your audience than draw their attention. (Yes, we have all heard the car screeching noise enough times for one lifetime.)
Most PowerPoint presentations are created from a template, which includes a background color or image, a standard font, and a choice of several slide layouts. Changes to the template can be saved to a "master slide," which stores the main slide theme used in the presentation. When changes are made to the master slide, such as choosing a new background image, the changes are propagated to all the other slides. This keeps a uniform look among all the slides in the presentation.
When presenting a PowerPoint presentation, the presenter may choose to have the slides change at preset intervals or may decide to control the flow manually. This can be done using the mouse, keyboard, or a remote control. The flow of the presentation can be further customized by having slides load completely or one bullet at a time. For example, if the presenter has several bullet points on a page, he might have individual points appear when he clicks the mouse. This allows more interactivity with the audience and brings greater focus to each point.
PowerPoint presentations can be created and viewed using Microsoft PowerPoint. They can also be imported and exported with Apple Keynote, Apple's presentation program for the Macintosh platform. Since most people prefer not to watch presentations on a laptop, PowerPoint presentations are often displayed using a projector. Therefore, if you are preparing a PowerPoint presentation for a room full of people, just make sure you have the correct video adapter.
Jul 12, 2011 | Microsoft Computers & Internet
) What feature of Powerpoint 2010 helps in broadcasting slides to remote audience
Dear Anand,
To broadcast your presentation, do the following:
  1. On the Slide Show tab, in the Start Slide Show group, click Broadcast Slide Show.
The Broadcast Slide Show dialog box opens.
  1. Do one of the following:
    • If you want to host your slide show on the service listed under Broadcast Service, skip to the next step.
    • If you want to use some other service to host your slide show, click Change Broadcast Service. Under Choose a broadcast service, select the service that you want to use. For more information about broadcast services, see Choosing a broadcast service.
Note If you do not see the service that you want to use, select Add a new service, and then in the Add Broadcast Service dialog box, enter the network address of the service you want to use and then click Add.
  1. After you select your broadcast service, click Start Broadcast. PowerPoint then creates a URL for your presentation.
PowerPoint creates a unique URL for your slide show.
  1. To send the URL for your presentation to your audience, do one of the following:
    • To send the URL for your presentation by email, click Send in Email.
    • To copy the link, click Copy Link.
  2. When your audience receives the URL for the slide show, click Start Slide Show to begin your broadcast.
The audience follows your slide show in their browser while you present within PowerPoint 2010.
  1. After you finish presenting and are ready to end the broadcast, press ESC to exit Slide Show view and then click End Broadcast.
After you begin broadcasting a slide show, the Broadcast tab appears in the PowerPoint 2010 ribbon.
Regards,
Tech_Comp
Feb 23, 2011 | Microsoft PowerPoint 2010
I have created some games in PowerPoint 2007 using hyperlinks to direct the students to different slides and then back to the home slide. The games were created in PowerPoint 2003 where the hyperlinks...
Try to uninstall the Security Update KB 982158 WORKS! Steps look something like this:
1) Start
2) Control Panel
3) Programs
4) Programs and Features
5) Installed Updates
a) Look in the PowerPoint 2007 group
b) Find Security Update KB 982158
6) Uninstall and Update
7) Don't try to CTRL F or "Search installed updates" just use your eyes to locate it
8) Right click
9) Uninstall
10) (You'll have to exit ppt)
11) Reopen and you got your very own, most lovely, color changing hyperlinks!
Nov 07, 2010 | Microsoft Office PowerPoint Home and...
Hitachi cp-s240 remote question
Hitachi data projectors are able to function as a mouse using either the USB port or the control port located on the back of the projector.
However, they are not intended to be used as a remote presenter. This means that although you can use the remote as a mouse, you will not be able to change slides in a full screen slide show using powerpoint.
I recommend the Targus remote presenter for this purpose. This device will function as a mouse, pointing device, and will allow you to change slides in powerpoint. In addition, it's inexpensive, wireless, and small enough to easily fit in your pocket.
Mar 02, 2010 | Hitachi CP-S240 Multimedia Projector
Which is the software that converts presentations into a self running slide show
there are many different slide show converters,
One of them with a free 30 day trial can be found here:
http://download.cnet.com/PowerPoint-Slide-Show-Converter/3000-2075_4-10385108.html
You need to have PowerPoint installed on your system when using the converter.
Success
Aug 29, 2009 | Microsoft Office PowerPoint 2007 Upgrade:...
Linking sound wave files to PowerPoint
Hi Rose,
Instead of copying presentation directly to CD, simply do Package on CD (File menu --> Package in CD, then copy to a folder or directly burn to CD
it will contain everything required to run presentation your PPT file, Powerpoint Viewer and all supporting files.
any ways having problems pl contact me
Zulfikar Ali
ali_zulfikar@yahoo.com
9899780221
Mar 13, 2009 | Microsoft PowerPoint for PC
Transfered Powerpoint file (65 slides) onto Ovation - only got the first slide repeatede 65 times?
Here's a fix I did that worked. I had tried to run Ovation with PPT 2007 first, to no avail. Same problem as described here. I uninstalled PPT 2007 and re-installed PT 2003. THEN YOU MUST bring up Ovation, import your PPT slides, THEN click "Tools", "Clear Show Settings". Ovation will re-import the slides but using the components of 2003 and WALLA! It will work.
Nov 10, 2008 | Adobe Ovation 1 Win Retail Ue 1U Full...
61 people viewed this question
k24674
jasbo
jasbo
