MAYTAG CENTENNIAL HEAVY DUTY WASHER, HOT WATER SEEMS TO BE RESTRICTED, TRICKLES. WE BUGHT THIS USED AND LOVE I, EXCEP FOR THE HOT WATER ISSUE. iS THERE A RESTRICTER WHERE THE HOSE CONNECTS? WE CHECKE
MAYTAG CENTENNIAL HEAVY DUTY WASHER, HOT WATER SEEMS TO BE RESTRICTED, TRICKLES. WE BUGHT THIS USED AND LOVE I, EXCEP FOR THE HOT WATER ISSUE. iS THERE A RESTRICTER WHERE THE HOSE CONNECTS? WE CHECKED THE WATER HOSE
    Top Expert:
  • Washing Mach... Master
  • 35,762 Answers
A defective fill valve will produce the symptom you describe.
Posted on Nov 13, 2014
docjohn174
  • 943 Answers
SOURCE: Hot water cycle flow problem
hi thanks for the question their is a screen in the water valve to catch any dirt you can try and remove the screen in the water valve and try again if it works ok . it usually works thanks the appliance doc
Posted on Sep 24, 2008
  • 91 Answers
SOURCE: slow cold water only fill kenmore heavy duty 70 902202
remove fill hoses and inspected for debris or cloggs ,,,,
Posted on Jan 04, 2009
jumptrout51
  • 3361 Answers
SOURCE: Kenmore Heavy Duty Washer Leaking from bottom
Probably the drain pump seal has gone bad.
Check it for leaks.
If your floor is good and level look for water near the front center of the machine.
Posted on Feb 26, 2009
SOURCE: no cold water, only hot
The cold water inlet line is either clogged (it has a filter screen in it) or the cold-water solenoid valve is malfunctioning.
Remove cold water line, check for obstruction -- if no success, inspect electrical connections on solenoid valve (where the cold water line attaches to the back of the machine). If valve is getting current, take it apart and clean it. If that doesn't work, replace the solenoid valve.
Posted on May 29, 2009
beltronic205
  • 1466 Answers
SOURCE: Overfilling maytag centennial - brand new?
Sounds like a hose off pressure switch or faulty switch/ however make sure drain connected ok 1st....
Posted on Oct 02, 2009
Maytag centennial washer not working properly in Normal cycle. After it shuts off there is still water in the bottom of the tub. I can move the dial to another setting such as Casual cycle or Heavy Duty...
We have the same problem. The Normal cycle still works, but after the final spin cycle, water is again added (1 gal est.) and the machine stops. Problem occurred after washing an old 25 x 30 inch rug which partially disentegrated when washed. We were seeing particles of the rug in subsequent wash cycles during drain into laundry tub. Don't know if something is plugged in the washer or if it is something else. In another load after the rug wash, the top of the washer was lifted during the wash cycle. The water problem occurred immediately after lifting the lid as the wash load went through remaining cycles. Maybe this affected the timer? Maytag customer service suggested unplugging power cord to re-set timer. This didn't make any difference. We need a technician to tell us if this is a timer problem or something else?
Oct 03, 2011 | Maytag Centennial 3.2 cu. ft. SuperSize...
I just purchased a Maytag centennial washer. I just love it the Maytag products arethe best. Question I am using the HE detergents as the book suggests, however how much bleach do I use?
According to page 6 of the manual for the "3 cu. ft. Capacity Maytag® Centennial® Top Load Washer" and page 8 of the manual for the "Centennial® High-Efficiency Top Load Washer", not more than 1 cup (250 ml) should be used in either machine.
Also, it should be added to the dispenser cup on the front left of the machine - not directly to the wash as it will interfere with the detergents ability to clean the clothes.
I hope this helps & good luck. Please rate my reply. Thanks.
Apr 20, 2011 | Maytag Centennial MTW5800TW Top Load...
The water fills very slowly on rinse
You probably have a cold inlet valve with restricted flow, either because the filter on the inlet valve is clogged or because the cold valve is failing......If you wash on "warm" you have both hot and cold water mixed. On rinse there is probably only cold water used....Check water flow for HOT and COLD settings and you'll probably see the difference...Good luck...Nomess
May 23, 2010 | Whirlpool LSR5132PQ Top Load Washer
Washer does not allow hot water to enter machine when you press the heavy duty button. Regular warm cycle or hot works fine. Replaced the water valves, main control panel.
This is a common question we face daily. Certain washing machines allow hot water to enter only during certain cycles. Others allow hot and cold to enter intermittently. Consult your owner's manual to be absolutely sure about this. If you're sure the machine isn't working the way it used to--or should--try these tests:
Is the hot water turned on? If not, turn it on.
Is the washer getting cold water but no hot water? If so, check to see if the control panel
settings are correct.
Thanks for writing to Fixya.com and I am Aparajita. I will be assisting you today.
Mar 22, 2010 | Maytag Neptune MAH5500B Front Load Washer
I have an old Kenmore Heavy Duty 70 series washer.
its a filter inside the water hose thats still blocked or the relay inside the washer for the cold feed is not opening up fully it could just need a clean or maybe a new one fitted
Nov 05, 2009 | Kenmore 22422 Top Load Washer
Slow cold water only fill kenmore heavy duty 70 902202
Dec 30, 2008 | Kenmore 22422 Top Load Washer
Washing Machines Logo
35 people viewed this question
Top Washing Machines Experts
