Question about DeLonghi Magnifica ESAM4200S Espresso Machine - Silver
How do I open the front panel to access coffee grounds and remove drip tray
Have only bought this machine and not sure how I open door to remove drip tray and do not want to force it
    Top Expert:
  • DeLonghi Master
  • 14,161 Answers
this video gives step by step directions.
Posted on Nov 13, 2014
Grinder is jammed cleared it but red light still on and it's not working
I'm not sure what model you have, but I have a Vienna Deluxe and I recall getting the machine to reset by opening and closing the front door. Of course you should make sure the drip tray, grounds receptacle, and water reservoir are properly seated. If that fails you might just try restarting the machine with the off switch or by unplugging the unit. Hope that works for you.
Jun 16, 2011 | Saeco Coffee Makers & Espresso Machines
It says driptray full, but it isn't? Any ideas?
Wevhave had ours into the shop four times for the erroneous 'coffee grounds' and drip tray' emptying. They have changed the mother board, chip in the door and even looked at the head gasket and carburettor settings but can't find the source of the problem.
What we have found latelt (it's Christmas so everything is closed for a month) is if we leave it overnight without power, 3 out of 4 times it resets itself.
It's apain if it plays up during the day but mornings brings us a good cuppa more often than not.lesson-get a deLonghi next time, this Saeco brand is more trouble than they are worth.
Nov 28, 2010 | Gaggia Titanium Espresso Machine
The brew group does not seem to engage properly. All the lights work, along with steam and water out of the wand. The red light flashes and switches between red and cup back and forth. It does start the...
Hi
Check behind the drip tray for coffee grounds. Make sure that your drip tray is locked in. If its not fully locked it, this could be your problem. If everything is removed but the brew unit, grab the handle without pushing the press button, and pull. If the brew unit comes out, it wasn't locked in. Put the drip tray in. Set the brew unit on the drip tray. Now slide the brew unit towards the machine with a little force and see if that locked it in?
Jan 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
I put beans in where the grinds should go. help!?
Hi
Open the door and remove the drip tray. Then remove the brew unit and empty the beans. Make sure that you get all the beans. Check the brew unit thoroughly. Then put everything back. Try the pre ground button but don't put anything in the brew unit then push the medium coffee button. That will run the machine through a brew cycle and if it works OK then you set to go.
Dec 30, 2009 | Saeco Incanto Classic Espresso Machine
1. After brewing a cup of coffee, when the grinds are emptying, a stream of coffee and grinds drains into the Drip Tray from the valve(?) in the rear right of the Drip Tray. We have gone into program mode...
HI
Excess water into the drip tray is an indication that you don't have enough coffee going into the brew unit. There is a lever on the top of the door that has a + on one side and a - to the front. Push the lever back to the full plus, then pull it forward 1 click. Try that.
Water into the drip tray is normal in small amounts. This is the release of pressure after brewing, like the 3 way valve on commercial machines
Sep 29, 2009 | Saeco Magic Comfort Plus Espresso Machine
Water not coming out of dispensing area, goes to drip tray instead Water comming out in drip tray instead of regular way
Try this, if the machine has a pregrind door(usually on the top front) then use the button to tell it you are using pre grind coffee, if water comes out the spout this way then the grind on the grinder is too fine, if it goes out the drain then the coffee passage is blocked, remove the brew unit and check/clear tubes, also clean the spouts on the door of the unit.
May 30, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
Water Leaks from bottom of machine as coffee is dispensed?
I had this same problem. Open the front door, remove the dreg drawer and then remove the brewgroup. In the back you will see a pipe sticking down with an o-ring gasket on it. Below that is a channel and a little opening where rinse water is supposed to flow into the front drip tray. It gets clogged with grounds pretty easily. I filled a hose with some water and stuck it down there and blew through it until you can see water come out the front hole. It's a little hard to describe but I hope this fixes your problem, it did for me. I just have to do it once every couple months.
Dec 07, 2008 | Saeco Vienna Digital Coffee Maker,...
Brewing system jammed - Delonghi Magnifical 3200
Ran into this same problem this week - brew /infuser unit is stuck at the bottom of the machine and it doesn't seem to want to move. Cannont replace the drip tray/grounds catching container. After speaking with Sam a wonderful customer service rep at DeLonghi (866-528-8323) I learned the following that saved me from having to send the machine in for repair which could take 2-3 weeks.
  1. Make sure that the machine is unplugged before attempting this repair process.
  2. Open the front door of the machine so that you can see the brew unit.
  3. Take the grounds catching container only (without the drip tray) and put it into position where it would normally be seated.
  4. Carefully try closing the front door.
  5. If the door will not close with the container in position, carefully reach under the door and apply gentle pressure to lift up on the container so that the door can then close.
  6. Plug your brewing machine in. It should power on and then make an internal adjustment which will raise the brew/infuser unit up enough to then be able to once again replace the drip tray and grounds container back into position.
  7. If it does not raise high enough, try unplugging the machine again, wait about 5 seconds and then repeat the same process just described.
  8. Once you are able to replace the tray and container, power the machine on.
  9. Have a cup ready to place under the dispenser as it will release water and coffee as it preps itself for operation again.
Hope this helps those of you who are experiencing this same scenario.
Successful in Seattle
Dec 27, 2007 | Coffee Makers & Espresso Machines
Significant leak into drip tray when brewing and using steam/hot water
run a 50/50 mixture of white vinegar and water thru your system.may have to run it twice,should clear it up if its a mineral clog. be sure to run a few cycles of clean water afterwards to clear the system
Dec 01, 2007 | Saeco Vienna De Luxe Espresso Machine
DeLonghi Magnifica ESAM4200S Espresso Machine - Silver Logo
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
