Question about Exercise & Fitness
How do I lower treadmill from store to use mode?Rebock Model #RBTL 145060
I don't know (yet), but I'll soon be able to help you though! I have just bought a treadmill that is similar to yours (it's the Lifespan TR1200, mentioned here http://www.your-workout-routine.com/cardio/best-treadmills-2014/).
But hey! You could ask in the store you bought it, can't you?
Posted on Nov 14, 2014
Fix led displays
Check to see if the RPM/speed sensor is functioning. On some models this sensor is positioned next to the pulley on the front roller and opens and closes each time the magnet on the front roller passes the sensor.
The sensor could have failed, or it may simply be too far away from the magnet on the front roller. 1/8 " is the normal distance between the sensor and magnet. It is also possible that the magnet is missing from the front roller.
Be sure to post the units exact model# which normally starts with RBTL....
Nov 29, 2013 | Reebok Exercise & Fitness
Machine shuts off- says LS
follow this steps and fix it. God bless you
Plug Treadmill into wall outlet and press
START.
Display lights up; TREADBELT DOES NOT MOVE "L5 / LS ERROR"
Is red SERIAL lamp on the motor control
board lit?
Is the yellow RLC lamp on the motor
control board lit?
1. Unplug the treadmill from its
2. Wl alk on the belt manually. (push belt)
3. Does the yellow MOTOR lamp light while pushing?
Is yellow MOTOR lamp on the motor
control board lit?
1. Loose wire connection to motor, capacitor, or choke.
2. Loose brush holder screw on motor. (Check Both)
3. Failed drive motor. Part # 70014 (110V), 70125 (220V)
NO
YES
NO
YES
5.1
5.2
5.3
5.4
5.5
NO
1. Check wiring harness connection between
upper and lower board. Part # 70083
2. Replace display board. Part # 70076
YES
Enter Open Loop Speed mode:
WARNING: NEVER STAND ON THE TREADBELT IN THIS MODE.
1. Turn off the treadmill.
2. Press FAST and START simultaneously and release both buttons once the display lights up.
3. Hold the fast button until the display reads 99.
Short in capacitor, motor, or motor
control board.
NO
Turn treadmill off. Disconnect drive motor wires from lower control board (Mtr + and Mtr -)
terminals. Power up in OLS mode (FAST & START). Bring displayed speed up to 99.
Measure across the Mtr + and Mtr - terminals with your voltmeter (DCVolts). You should
measure at least 90 vdc on a 110V treadmill and 180 vdc on a 220V treadmill.
If you are not getting dc volts out of the lower board, replace it.
If you are measuring the proper dc voltage out, replace the drive motor.
Sep 19, 2013 | Bowflex Exercise & Fitness
Freespirit treadmill
see my personal TIPS for motor help. God bless you 1232c4bc-7349-41aa-9120-7d58645cb442.gifc11b620c-0d7d-410d-9958-64f3636d4ac5.jpg
Jun 05, 2013 | Exercise & Fitness
I need to get a replacement bolt or screw for the latch knob
please go to www.fitnessrepairparts.com and get the parts inmediately.
give the number, serial, and model numbers.
Happy New Year and God bless you
Jan 01, 2013 | Proform Performance 400 Treadmill Exercise...
My Proform 785 will not unfold even after I have pulled the latch. Is there something else I need to do to unfold it?
You may have damaged the treadmill when folding it up. If the incline was not lowered to its minimum position, the frame can be damaged.
To lower the treadmill, all you do is release the latch and lower the deck of the treadmill to the floor.
There are many Proform machines known as "785" including a number of elliptical trainers. An actual model number would make diagnosis much easier...
Feb 26, 2011 | Proform 785 Treadmill
I have treadmill rbtl 1198 the cover hood is broked how can i founded one the placed i was calling they say is discontinued the parts
Try Treadmill Doctor or Fitness Repair Parts. If Reebok says it's not available, it's probably not available..
The part number has been removed from the parts list, so it in NLA from Reebok....
Dec 14, 2010 | Exercise & Fitness
I have a Reebok rbtl 1198 in which the belt kept moving to one side and getting frayed. Now the motor isn't working fuse is fine what is the problem?
If the motor is going to one side there are two screws on the back of the treadmill that have allen wrench screws in it. Whatever side the belt is drifting too tighten that side and it will pull it back to the center. If the motor requires too much power it will stop. Once you have it centered you should be good.
May 20, 2010 | Exercise & Fitness
I turned on my treadmill after a long hiatus :) and got an error message and a beep. The errors were E4, E9 and a few others. It is a Vision Fitness T9400HRT model. Any idea how to fix?
E4: Solution 1. Check power to the treadmill, as insufficient voltage to the treadmill can cause this error to reoccur. Check the power socket that the tread is plugged into. Eliminate any extension cords or surge protectors (plug the tread directly into a functional power source). Make sure the circuit is not overloaded. Make sure the circuit is NON-GFI. 2. Calibrate (See engineering mode for specific treadmill). 3. If calibrations do not hold, replace upper console. Note: Usually simultaneous with an E6. E6: Solution 1. Check the elevation plug connection at the lower board. 2. Check ALL large data cable connection at the lower and upper boards. 3. Calibrate (See engineering mode for specific treadmill) 4. Test/change large data cable (use large data cable information provided in the data cable portion of this Guide). 5. Replace elevation motor E7/E9: Solution 1. Certain lower boards have an LED that flashes when the magnet on the roller passes the sensor. Adjust sensor position if LED does not flash. See lower board basic troubleshooting for lower boards with the LED. 2. Unplug RPM sensor at the lower board. Check continuity. Treadmill will operate without sensor but cannot Autocalibrate. Calibrate manually. 3. Replace RPM sensor TREADMILL.TROUBLESHOOTING. AUTO CALIBRATION STEP 1 ENTER ENGINEERING MODE • With the SAFETY KEY in place, hold the “ELEVATION UP” and “SPEED DOWN” buttons for 5 seconds. “DGA3” will appear in the profile window and “EHG1” will appear in the function window. • You are now in ENGINEERING MODE STEP 2 ENTER AUTO CALIBRATIONS • Press the “ELEVATION UP” or “SPEED UP” to “EHG4”. • Press “SELECT”. STEP 3 • Press “START”. The treadmill will calibrate itself. This will take about 3 to 5 minutes. When AUTO is complete, “END” will appear in the window. Wait 10 to 15 seconds and the treadmill will reset itself to “P1”. STEP 4 • Press “START” to test the treadmill
May 04, 2010 | Exercise & Fitness
A2350 doesn't start, just cycles through programs on display
This is just the store display mode it comes with - check the manual, it should tell you how to easily turn off the store display mode.
Jun 20, 2009 | Nordic Track NordicTrack Treadmill, A2550
Exercise & Fitness Logo
81 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Howard
Howard
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
