Question about Humidifiers
How do i clean model IDU2234
I dont have manual
Need online instruction manual for hankscraft humidifier model 240
I found this. There are no manuals available on line.
Here we have a used working HANKSCRAFT / GERBER COOL VAPOR HUMIDIFIER Model 240 WITH INSTRUCTION MANUAL and STEAMED CLEANED. This humidifier, by Gerber, has a 1 3/5 Gallon Capacity, and produces cool vapor for up to 18 - 20 hours in low, medium or high settings. The humidifier works great , does not have the directional nozzle included but does come with a copy of the instructions.
http://www.ebay.ca/itm/331790662762
Dec 03, 2016 | Humidifiers
I dont have any waterline in my furnace closet on the deck. How do I get a humidifier installed
I've never heard of a manually-filled furnace humidifier. We use a whole-house, stand-alone humidifier (manually-filled) and it works just fine. Easy to fill, easy to clean, easy to maintain. Even if there were such a thing as a manually-filled furnace humidifier, in the case you describe, I would much rather stay inside to fill my humidifier than get bundled up and step outside into the cold to do it. Hope you find a good solution. Good luck!
Nov 24, 2013 | Humidifiers
Reset clean light
clean ligth its means still have dirt in filter or any,,,just clean and its will goes by its self,,
if not try to off an on again,but still the same,,its means the sensor need to replace,call for the service technician,dont waste time and money if you dont have any idea for the repair
Oct 26, 2013 | Honeywell Humidifiers
I dont know how to add water to a sunbeam humidifier model#scm808
Hallo
Can you not find the owner manual?
The best I can do is advice you to go online and find MANUALSONLINE.COM. There look for the brand name "sunbeam" then the product humidifier.
In the one in this house you lift and take the filter out and water in.
Good luck
Kolbrun
Apr 23, 2012 | Sunbeam Humidifiers
Cannot take apart to clean, how do you get to all the screws - if I can't clean it - I can't use it.
The manual should tell you how to clean this product. If you don't have the manual, just do a google search of the brand and model number, put the word "manual" in the search and you likely will find the manual. Or, go straight to the Vicks company website; a lot of times one can find manuals for products directly from the manufacturer. Good luck!
Feb 13, 2011 | Vicks V4500 1 Gallon Humidifier
No manual how do i clean a kaz vicks humidifer model v4450
http://www.ehow.com/how_7442829_clean-vicks-humidifier-model-v4450.html
Jan 21, 2011 | Kaz V4500 Humidifier
My Bionaire Humidifier
From the user manual (which is online)
2. Clean the base by partially filling
it with one 8-oz cups of undiluted
white vinegar or by using Cleanse
CleanTM Solution (DMS216) by the
manufacturer. Leave this solution
in the tank for 20 minutes, while
cleaning all interior surfaces with a
soft brush.
May 19, 2008 | Humidifiers
Filter
If you email me at jennju@hotmail.com, I can send you a pdf of the manual for this product. I had the same model and was able to remove the fan cover by slightly twisting it and pulling up -- was able to clean the unit very well once I removed the cover! good luck...
Dec 03, 2007 | Honeywell DH835 Humidifier
Humidifiers Logo
196 people viewed this question
Top Humidifiers Experts
Mack Baxter
Dennis
Are you a Humidifier Expert? Answer questions, earn points and help others
