Question about Goodman Manufacturing Goodman ARUF48D14 Air Conditioner 4 Ton Multi Position 3 Speed Standard Air Handler
What cause 3 amp fuse to keep blowing when power in turn on goodman 16 sier air handler
  • 43 Answers
Hello...
Apparently, there is an overload or shorted wires. Elequipo Disconnect electricity and check the cables are in good condition.
Posted on Nov 13, 2014
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
Air conditioner won't turn on
A very common problem that can cause unit to not turn on, assuming you have checked breaker on and no other mechanical problems, is the float switch on the overflow pan. Check you overflow pan for excess water. If this is your problem, your normal drain is clogged and needs to be unclogged.
Another problem that sometimes causes the controls to turn off, is the fuse blows on the air handlers control card due to some control circuit is pulling to much power and blows the fuse. If this is the case you will need an experienced techician to find the cause of overcurrent. It could be but not limited to solenoid coils on main contactor or reversiing valve. It could be a shorted control wire or shorting thermostat wire. Hope this helps.
Aug 09, 2014 | Goodman Heating & Cooling
Brand new furnace wont start its a aruf 14 electric air handler with a 10 amp heater coil
the 3 amp fuse protects low voltage side of transformer. if it's blowing on a call for cooling wire pair going to outside unit bad or contactor in outside unit.
Nov 18, 2013 | Goodman Heating & Cooling
Inside control on wall is not lighting up so therefore my ac unit won't turn on
Look inside the air handler, next to the low voltage transformer for a 3 amp fuse. Check that fuse and if it's ok check the transformer.
Sep 02, 2013 | Goodman CKL36AR36 Air Conditioner
My air handler is blowing the 3 amp fuse on the curcuit board. what does it control
Its not what it controls but what it protects. It protects
the transformer. Disconnect the thermostat wires and mark where they go. Replace the fuse and turn the power on. If it does not blow the fuse the problem is in
your thermostat or thermostat wires.
Jun 30, 2010 | Goodman GMS80453ANA Open Flame Mid-Size...
3amp fuse is blowing.
Disconnect the yellow wire from the thermostat and tape off the end. Turn the power back on. If the fuse blows, it is not in your wire nor the compressor contactor. If the fuse does not blow, turn off the power, reconnect the wire, and replace the fuse. Then, disconnect the wire from the compressor contactor and tape it off. Turn the power back on. If the fuse blows, it will eliminate the compressor contactor coil and will likely be a "short" in the wire itself. The yellow wire goes from your T-stat to your air handler and from your air handler, it goes to the oudoor unit's compressor contactor.
Apr 07, 2010 | Weather King 10PJA2501AH Air Conditioner
HELP, A/C wont come on in FL
Stopped up drain line caused float switch to trip. Blow out drain line. Blown fuse in Air Handler. Bad transformer. You have a 3 ton on a four ton air handler. You need to lower fan speed to low dor better effeciency. Could have bad Tstat butchances are control voltage problem.
Jun 06, 2009 | Goodman CLQ36AR49 Air Conditioner
Fuse blowing on tappan air handler
most of the time its out by the ac unit . you have a shorting thermostat wire .. the outside unit has a large wire thats 240v and a small one that 24v thats the one you want to look at . look for bare wires , look where it goes into the wall , thats the common place . "critters" love to chew thermostat wire . so take a look . .....please rate this answer , i need votes . thanks
Jan 24, 2009 | Heating & Cooling
Goodman Manufacturing Goodman ARUF48D14 Air Conditioner 4 Ton Multi Position 3 Speed Standard Air Handler Logo
155 people viewed this question
Top Goodman Manufacturing Heating & Cooling Experts
bobalix
snowmanii
ray gallant
Are you a Goodman Manufacturing Heating and Cooling Expert? Answer questions, earn points and help others
