Question about Ic Verify Payment Processing Software - Upgrade
<!-- from fixya rte -->I am locked out of icverify user manager - Ic Verify Payment Processing Software - Upgrade
If you are unable to remember the username and password of ic user, it may be necessary to delete just icverfiy user (not the main program) and reinstall icverfiy user manager with it's default username / password and thenlogin from there. We have had to do this when installating a new operating system.....
Posted on Nov 26, 2014
Change the combination on a DHo74E
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777).
You should set the lock to your own unique master & manager code immediately.
Please keep your codes in a secure location. You may also register your codes on our website at www.sentrysafe.com.
A single signal (LED flashes and beeps once) response from the lock indicates valid entry.
A double signal (LED flashes and beeps twice) response from the lock indicates an invalid entry.
• If three incorrect entries are entered in a row, the keypad will shut down for a period of five minutes. During this shut down period you will not get a response from the keypad.
Changing the Master Code
(Code length: 1 to 10 digit code) Always perform this operation with the door open.
1. Enter: # - Existing Master Code - #
2. The set light will stay orange for ten (10) seconds.
3. Enter: 1 - * - New Master Code - # - New Master Code - #, before the orange light disappears.
If a mistake is made during the change, wait thirty (30) seconds and repeat steps 1 thru 3.
Test the new code several times before closing the door: Enter: * - Code - #
• The lock will indicate a valid code change with a single signal.
• The lock will indicate an invalid code change with a double signal and the old code is still valid.
Changing the Manager Code
1. Enter: # - Master Code or Manager Code - #
3. Enter: 2 - * - New Manger Code - # - New Manager Code - #, before the orange light disappears.
Activate user codes
3. Enter: User ID Number (3-7) - * - New User Code - # - New User Code - #, before the orange light disappears.
If a mistake is made during the activation, wait thirty (30) seconds and repeat steps 1 thru 3.
• The lock will indicate a valid code entry with a single signal.
• The lock will indicate an invalid code entry with a double signal and the old code is still valid.
Example: # - Master Code or Manger Code - # - 5 - * - New User Code - # - New User Code - #. This will activate User Five (5).
Changing the user code
1. Enter: # - User Code - #
3. Enter: New User Code - # - New User Code - #, before the orange light disappears.
The Master and Manager can also change the user codes by following the "Activate user codes" section steps 1 thru 3.
Deleting user codesAlways perform this operation with the door open.
3. Enter: User ID Number (3-7) - * - # - #
Programming your lock codes
Dec 17, 2012 | Sentry Safe Dh-074e Solid Steel Depository...
I want to change the combonation
The SentrySafe electronic lock is shipped with a factory set master & manager code (777777). You should set the lock to your own unique master & manager code immediately.
Activate user codes
It keep telling me "YOUR
I couldn't see if someone else has already posted a solution. This same error message happens to us all the time-usually after a power failure, or windows decides to reboot the computer...In any case it will be necessary to login to "user magnager"..Once in switch to the tab that says "login"...then where it says "application" use the pull down menu to "icverfiy for window"
Then select any user that is listed , then go to the bottom of the page and select "log off user"...Close the program and start Icverify again...should be good to go
Feb 11, 2011 | Ic Verify Payment Processing Software -...
IC VERIFY CREDIR CARD SOFTWARE WONT DIAL OUT AFTER SWAPING HD TO A NE PC. EXTERNAL MODEM WORKS FINE, SETTINGS ON ICVERIFY POINTS TO MODEM COM PORT. SOFTWARE WILL NOT DIAL OUT. aNY HELP?
Ok,
There's really only a few reasons this would fail beyond the COM settings. First, if the computer you're using has actual serial ports on the board and you're using a USB modem or if there are more than one serial ports it's possible you have either got the wrong COM assigned or that you have more than one trying to use COM 1. This will not cause conflicts with newer USB based devices but can when using actual UART chips on the motherboard or a mix of USB and UARTs.
Go into device manager and check for additional ports. Disable all COM ports except the actual modem and try again. If it still fails, check for DMA and IRQ conflicts. Do this by going into Start>All Programs>Accessories>System Tools>System Information.
Once open navigate to System Summary>Hardware Resources>Conflicts and Sharing.
Check for any conflicts with COM 1 and it's related DMA settings or anything sharing an IRQ with the modem. If you find any devices conflicting or sharing IRQ or DMA with the modem either disable the device or go into device manager, double click the offending device, click onto the resources page and find an alternate configuration that uses different IRQ/DMA that won't conflict. This will require a reboot for most devices.
Sorry my answer would be faster but I'm shaking almost a decade worth of dust and cobwebs out of my brain that have built up since the last time I even used a modem for ICVerify.
Hope this helps, lemme know how you make out,
chris
Dec 23, 2010 | Computers & Internet
When i am signing in it displays "YOUR ACCOUNT HAS BEEN LOCKED"
You will need to login as an administrator or a different account that has admin rights.
Once logged in, you need to go to the control panel> Administrative Tools> Computer Management (If XP)
OR Start, type in Computer Management in the Search Window (if Vista/ Windows 7)
Once in Computer Management, expand System Tools> Local Users and Groups> Click on Users
On the right hand side, double click on the user account that is locked and untick the box that says Account is Locked
Hope that answers your query, Pls rate this answer
Nov 22, 2010 | Computers & Internet
ICverify 3.1 won't open.
the issue is caused by a Microsoft Jet update. in c:\icwin310\backup directory you will find the files needed by icverify. Make a backup of the following files in c:\windows\system32 msjet35.dll
msjint35.dll
msjter35.dll
msrd2x35.dll
msxbse35.dll
msexcl35.dll
msltus35.dll
vbajet32.dll
vbar332.dll
Copy the files listed from the c:\icwin310\backup directory to c:\windows\system32 and your error should be no more.
May 28, 2010 | Ic Verify ICVERIFY 3.1
ID error = 0
msjint35.dll
msjter35.dll
msrd2x35.dll
msxbse35.dll
msexcl35.dll
msltus35.dll
vbajet32.dll
vbar332.dll
Ic Verify Payment Processing Software - Upgrade Logo
475 people viewed this question
Top Ic Verify Computers & Internet Experts
David Payne
David Payne
Are you an Ic Verify Computer and Internet Expert? Answer questions, earn points and help others
