Question about Crafts & Hobbies
Which command base will work with MTH dcs
I want to control Lionel locomotives with MTH dcs
  • 34 Answers
You will need to add a TMCC Command Base and the required TIU/TMCC serial interface. This will allow you to control Lionel engines with the DCS remote. Please see page 100 of the DCS Operators Manual fifth edition.
Posted on Feb 03, 2015
SOURCE: Lionel Polar Express Berkshire Locomotive will only go in reverse
No doubt the transistor in the motor controller inside the engine is shorted TIP31C Q6 If you have the skills you can repair the unit. Parts are cheap, like 50 cents. Expense is shipping. Have repaired at least one that had the probblem you describe
good luck
Posted on Dec 23, 2009
jssummerfiel
SOURCE: I have a problem with
Had trouble with 072 switchs. Something is causing half the switch to loose track power. Most of the time it is the wide place on the switch. Had two of mind on both ends of the hot rail hookup do the same thing. What I did was have hot rail hookup in five or six different places. No problem now. Also have problems with derails at switch when going through ir backwards. Lional should in stall a small spring at the switch point to help hold it against the rail. No recommended but I took a punch and flatten the rail so it would push more on the switch point. OK so far. Hard to remove switchs when all your Fastrack is screw down.
Posted on Dec 17, 2012
residentoccu
  • 161 Answers
SOURCE: What is lionel smoke pellet tamper used for? Why needed?
Yes, you do just drop the pellet in...
But if there is any kind of crud built up in the
smoke stack, it may not allow the pellet
to seat on the heating element. Thus the
tamper is included to allow you to push
the pellet all the way down. If you don't
have one, a piece of wooden dowel the right
diameter can be used.
Posted on Jan 31, 2013
residentoccu
  • 161 Answers
SOURCE: lionel o guage santa fe steam engine locomotive won't reverse even with reverse switch on?
You do not specify which Santa Fe steam engine you have, but I am going to guess it's the Santa Fe RTR O27 set...
Here's a link to the manual for it. Go to page 9, read the last paragraph on the page. It may be the answer to your problem
.http://www.lionel.com/media/servicedocuments/71-1900-250.pdf
Hope this helps.
Posted on Feb 15, 2013
residentoccu
  • 161 Answers
SOURCE: Lionel battery operated g scale locomotive will not move
Replace all batteries in locomotive & remote.
You do need to be fairly close to the set with the
remote for it to work.
Posted on Mar 02, 2013
I have a Lionel 7796 New York Central. The remote blinks a constant red and it does not operate the locomotive.I thought it was the remote so Lionel sent me a new remote but the same problem exists.
The locomotive is not receiving the single from the remote . You need to paire them. In the Manuel should be intuitions for pairing. Hope this is some help.
REDEAGLE
Dec 17, 2017 | Crafts & Hobbies
I have a new 104 MTH Long Island engine and tender and I cannot get it to run.
The locomotive may be defective as received. Try applying power directly to it to confirm.
Dec 05, 2016 | Crafts & Hobbies
I cannot get my MTH engines to run properly. Power is on, bell and horn sounds, lights are on
MTH locomotives have internal batteries that may need to be replaced. The circuit boards in some older MTH locomotives can be damaged if operated with discharged or faulty batteries. Contact MTH customer service for help with your engines.
Feb 07, 2015 | Crafts & Hobbies
Where can I get a copy of the Trainmaster Command Control operators manual?
See pages 17 - 23 of attached Manual/PDF.
The manual may not be for your unspecified locomotive,
but the TMCC instructions will apply.
Lionel Service Manuals
May 15, 2014 | Crafts & Hobbies
Jan 19, 2013 | Lionel A Christmas Story Gauge Train Set...
Lionel train wheels are locking
1: clean & lubricate your engine2: if that does not work, the wheels may be out of quarter,check with Lionel Parts & Services.
http://www.lionel.com/ContactUs/
Dec 22, 2012 | Toys
I am using a standard 80 watt transformer (not command control), but the rail sounds do not work on this unit at all. I have checked the on/off switch and played with the volume, but still no sounds. At...
Many of the MTH Protosounds 1 and 2 and Trainmaster will not work with the Lionel CW-80 electronic power source. The output waveform is so non-like sinusoidal. The electronic sound systems will not usually respond to this waveform and when they do, the sound will be garbled. Use another power source.
Sep 01, 2011 | Rio Grande Lionel 34500 Ft Diesel...
I recently purchased a Dash 9-44 CW Diesel locomotive. It has on the label of the box "Command Equipped" - "Towercom TM" - "Crewtalk TM" - "Railsounds TM". My...
I'm not familiar with the Dash 9-44 CW but it may be that the sound and smoke switches are turned off. You will probably find these under a removable cover on top of the locomotive or under it, usually near the cab. Check your instructions or go to Lionel.com and click on support. Instructions and manuals can be found here.
Apr 29, 2017 | Lionel Toys
good luck
Dec 08, 2009 | Lionel The Polar Express Train Set
Crafts & Hobbies Logo
183 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
