I have an older model Durabrand t.v. I'm trying to connect my satellite to it but the channel got changed. How do I get the t.v. to the correct input to use the satellite without a remote?
    Habit-Forming:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 10 Answers
Connect and put on both TV & Sat Receiver, then on UHF channels, auto or manual tune the Receiver's output signal, try to fine tune if auto or manual does not tune well.
Posted on Nov 27, 2014
tvtek
  • 1284 Answers
SOURCE: How do I change the input without the remote
If there is no nutton on the TV to do so then you have to have the remote for it. You can try a universal remote but, usually functions like that don't work. Here is a link to the remote you need. http://www.electronicadventure.us/Merchant2/merchant.mv?screen=prod&store_code=EA&product_code=6450348129
Posted on Feb 23, 2007
satscoop
  • 59 Answers
SOURCE: InputChannel without remote
Yes and no depends on the TV if you have a menu button press it and go to autoprogram and let it find all the channels then press channel down until you get to channel 1 then press it again and it should start cycling through aux inputs.sometimes TVs dont have a menu button and this is not possible.try simply pressing channel down until you get to channel 1 then maybe it will cycle through your inputs.Please rate me if this helps.
Posted on Nov 16, 2007
SOURCE: Durabrand model BH2004D
I am not sure about Direct TV but dish network does not allow the hookup to go through their box...it must go through the TV only. Speaking with Duraband at 1-800-256-2487 confirms you have to have a Duraband remote and universals won't program to it. Ask for parts dept. and order a new remote. Sorry - not good news for me either!!!
Posted on Jan 11, 2008
SOURCE: AV input selection without a remote
I had the same problem. I hooked up the DVD player and then got into the set up. I used the add/erase feature to go through all of the channels. At channel 91, I saw the logo for the dvd player. I added that channel and now the dvd player works.
Posted on Mar 13, 2009
SOURCE: Need to change tv input for Durabrand DWT2405 without remote?
How do I get a duraband tv out of video mode. with a universal remote
I need to set a universal remote to the tv but it is stuck in video mode
Posted on Jun 05, 2009
Televison station won't scan
If you are receiving a "No Signal" error message, verify that:
  1. All of the cables physically connected to the TV and the input device are secure.
  2. The input device is turned on.
Your TV needs to scan for channels before it can show programming from an antenna, from cable TV when the cable comes directly from the wall (no cable box), or from a cable or satellite box connected to the TV with a coaxial (RF) cable. Do not scan for channels if you have a cable or satellite box connected using AV (Composite), Component, or HDMI cables. The box selects the channel, not the tuner inside your television. If you are not using the "TV" input, press the INPUT button on your remote until the correct input mode is selected.
To perform a channel scan using the coaxial input:
  1. Press the INPUT button on your remote to view your current input source. The TV (coaxial cable) input must be selected. This may appear as "TV," "ANT," or the channel and call letters of a station.
  2. If the TV input is not selected, press INPUT until the TV input mode is selected.
  3. Open the on-screen menu and select TV or Tuner option. (This varies by model.)
  4. Highlight Tuner Mode and select the correct option:
    • Antenna-over-the air signals from an antenna
    • Cable-direct from the wall cable TV, or a cable or satellite box connected to the TV with coaxial cable
  5. Select Auto Search or Auto Channel Scan. (This varies by model.)
  6. When the search reaches 100% complete, exit to the menu.
  7. Check the available channels:
    • Antenna or direct-from-wall cable-Press the Channel Up and Channel Down buttons on your VIZIO TV remote to view the available channels.
    • Cable or satellite box- Will return only one channel. Use the cable or satellite remote's Channel Up and Channel Down buttons.
If this does not resolve the issue, power cycle the TV and then re-run the channel scan:
  1. Turn off the TV.
  2. Unplug the TV from the electrical outlet.
  3. While the TV is unplugged from the wall, press and hold the Power button on the TV for 30 seconds.
  4. Release the power button.
  5. Plug the TV back into the electrical outlet.
  6. Turn on the TV.
Note: There is also an option to reset the TV to the factory default settings. This option is in either the SETUP or SYSTEM section of the on-screen menu. The option may be "Reset all settings", "System Reset," or "Reset & Admin." Consult your TV's user manual for the location and steps for resetting your model.
  1. Remove the coaxial cable from the DTV/TV connector on the back of your television and perform a channel scan to clear the existing channels. See the procedure above. This should not find any channels.
  2. Re-attach the coaxial cable to the DTV/TV connector and perform a new channel scan.
This video shows troubleshooting steps to use when a "No signal" message appears.
Jun 25, 2014 | RCA 46 46LA45RQ LCD TV
I misplaced the remote to the tv, but can power on and off with the satellite remote. I powered off and somehow the tv has switched to AV status and I am unable to change it back to tv status. When I press...
Hi There,
Don't press any more buttons at the moment as you may further complicate the problem. I really need to know which satellite remote you have to give the correct instructions, but the following applies to a large number of TVs.
First, press the TV button on the satellite remote. This simply ensures that any buttons pressed afterwards control the TV and not the satellite box.
Next look for a button on the satellite remote labelled INPUT or SOURCE. If you can find one of these buttons, try pressing it repeatedly until the picture from the satellite channels appears on the TV screen. If there is a TV/AV button on your satellite remote, press this once.
If you cannot find any of these buttons on your satellite remote or they do not switch the TV back to TV mode, please let me know which Satellite remote you are using. If you don't have a model number for the remote, please let me know the brand and model number of the satellite receiver.
Hope this helps. Please reply to me by clicking on "Add a comment" below your question.
Thanks,
BElectric
Feb 27, 2011 | Durabrand Televison & Video
I am trying to connect an Insignia flat panel TV to my existing Dish satellite system. Dish satellite system is not HDMI. We have: cable from the wall (satellite) connected directly to the new TV (exactly...
I really need to know the model number of your Insignia TV and which connections you are using between the Dish box and the TV to give you the correct answer. If you are connecting both cable and satellite, I believe it should be set-up as follows:
1. Connect cable feed to TV
2. Run auto channel scan on "cable" setting
3. Connect Dish box to TV and then try changing the "input" selection.
With the Dish box switched on to a channel number you know, try pressing the "INPUT" or "SOURCE" button on your Insignia TV remote repeatedly until you find the satellite feed. Once you have done so, you should be able to change satellite channels using the Dish remote.
If you need further assistance, please post back with the model number of your TV and details of the connections you are using on the back of the TV.
Regards,
BElectric
Dec 29, 2010 | Televison & Video
No signal onthe screen
If you are connected to a high definition cable box or satellite tv box you would not need to turn to channel 3 on your television. The television would need to be in the right input either component or hdmi. If someone connected the tv to the cable box or satellite tv box with a coax cable like an antenna cable then the tv channels will be available on channel 3 as well but they will not display in high definition. You change channels with the cable box/satellite tv box remote control. If the above is not correct and you are only connected to an antenna cable and not to a cable box or satellite tv box you will need to complete a channel search from the tv menu. It sounds like you are using a cable box/satellite tv box and that the tv is on the wrong input. If the cable box/satellite tv box is not working (i.e. just a black screen) on your television than that is a different matter entirely.
May 10, 2010 | Samsung LE32R41BD 32 in. HD-Ready LCD...
I have a 19" phillips lcd tv and when i turn the tv on the phillips screen comes up but when it is going the show the channel it shut off by itself how can i fix this problem?
Hello. I may be able to assist you. If you are using a direct cable connection from the wall outlet;
  • Check the incoming cable or antenna signal connection to ensure that it is properly secured to the TV's antenna input.
  • If the connection is good, perform the automatic installation again to search for all available channels.
If you are using a coaxial connection from the Cable or Satellite box to the TV;
  • Set the TV to the channel specified by the service provider.
  • Change the channels at the Cable or Satellite box to view the program.
If you are using a video connection (CVBS, S-Video, YPbPr, HDMI) from the source (DVD, Cable or Satellite box) to the TV;
  • You do not need to perform automatic installation to search for the channels.
  • Press the 'SOURCE' 071218044349_22024.gif button on the remote control repeatedly to select the correct input source.
If you are using an HDMI connection from the source (DVD, Cable or Satellite box) to the TV;
  1. Reset the TV and source by unplugging it from the power outlet for 30 seconds.
  2. Turn on the TV and press the play button on your source device. If the source is HDMI CEC compliant, the TV will automatically switch to the HDMI input.
  3. If your source is not HDMI CEC compliant, turn on the TV and switch to the HDMI input.
  4. Turn on your source.
If you are sure you have selected the correct input or channel but still have no picture or sound;
  • Try resetting the TV by unplugging it from the power outlet for 30 seconds.
  • Press the 'SOURCE' 071218044349_22024.gif button to select the correct input source.
  • Check the connection cables.
  • Try the connected source with another TV.
  • Connect a different source on the same connection of your TV.
Dec 14, 2009 | Televison & Video
Programming Channels
Your TV is likely set for "AIR" tuning rather than "CABLE" mode. In this case channels above 13 don't tune correctly. The tuning mode is adjusted through the setup menu (it's been too long since I've seen one of these to remember exactly how the menu looks). Once you set the tuning mode for cable, all the available channels should come in properly.
But you've said you have satellite, so you should have a satellite receiver connected to your TV, and you'd be changing channels there rather than on the TV. Your TV would be staying on channel 3 or 4 (if using the satellite antenna output connection), or on the A/V input you have the satellite connected to (if using the direct A/V outputs). Am I missing something about your system?
Feb 18, 2009 | Mitsubishi WS-73905 73" Rear Projection...
Unable to record one tv channel while watching another tv channel
You CAN record one channel and watch another with satellite service, but it would require two separate DBS receivers. The issue is that all satellite broadcasting is encrypted until it hits the receiver, which decodes it and transmits it outward toward your other AV devices. If it weren't for the receiver, connecting the coax cable to your other devices and trying to tune channels with them would yield no signal and possibly much frustration. You would need to split the signal into each receiver and have one connected to the television via one input and the other to the recorder then to the TV via another input.
With cable, you can split the signal without having to have two boxes - this way the QAM tuner in the cable box is still capable of tuning channels while the recorder can tuner basic cable channels for recording separately. You can also have the cable box connected to the recorder via composite so that you can record premium stations on a DVD recorder input mode anytime you like - but you would have to be watching that channel at the same time unless the DVD recorder had a pass-through RF signal (rather than a composite clone) - meaning you could also use coaxial to your television from the recorder and tune channels separately on your television while the recorder is recording one channel.
A lot of what-ifs there, but it is all quite possible.
Mar 18, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
Durabrand 13" tv model BH1304D
You will need the original remote control I,m afraid. The original remote is the Durabrand HYF-23A. On the original remote, incase you do have one, is a button marked TV/AV. That is the button that changes between the TV and the Audio/video inputs. An original replacement remote can be purchaed HERE: http://www.remotes.com/remotes/servlet/rs?a=gmi&smodel=BH1304D&brand_pn=DURABRAND_BH1304D&mode=large&uid=11831222740150 Good Luck
Jun 29, 2007 | Durabrand BH1304D 13" TV
Durabrand DCF2003
All you need is to press the input select button on the remote to change between the tv and the video inputs.
May 23, 2007 | Durabrand DWT1905 TV
Televison & Video Logo
73 people viewed this question
Top Televison & Video Experts
Electro Med Services...
