Question about Jawbone Up24 Wristband Onyx, LARGE
How do I bring reset myjawbone back to factory ? I keep getting error code o
Want to reset back to factory keep getting error code o
My motorola citrus keeps resetting how can i fix this?
Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380#
This function apparently works on almost all nokia mobile phones
Dec 31, 2012 | Motorola Mobility CITRUS Smartphone
I want to restore the factory default settings of my nokia 2630 but when putting the default code "1235 " getting code error. As far as I remember I have never changed that. I have even tried ...
Factory settings This is possible to reset your Nokia to factory settings (Note that you will lose all your data). For this look in the manual of your phone. Soft Reset Soft Reset will clear pending errors and bring your mobile to an initial state by restoring Factory setting. To operate this function on your mobile, the shortcut is: *#7380# This function apparently works on almost all nokia mobile phones. Hard Reset It may happen that despite you have restored your mobile to factory setting, the error still exist. In this case, it is recommended that you opt for Hard reset Enter the code: *#7370# and press Yes to confirm initialization. Important Notice: It is recommended that you save all important information on your phone (e.g: memo, contacts etc) To make a Hard Reset on a Nokia phone that is not willing to turn on, just press simultaneously these 3 buttons: on/off + * + 3 Before making a Hard reset better backup all your important information: contacts , memo...etc
Mar 10, 2011 | Nokia 2630 Cellular Phone
How can i take back the games of my nokia 2630?
Use these codes for factory reset/hard reset.
This will bring back the phone to its factory condition. You'll get all the default games/applications provided by the manufacturer.
Do not forget to take the backup of contact/useful information from phone before using these codes.
*#7780#
Regards
Nov 21, 2010 | Nokia 2630 Cellular Phone
My son forgot his security pin and wants to change his sim.. model: 1110i type: RH-93 imei 356450019605655
hello,Hi,you can make use of either soft reset,hard reset or factory settings.
Soft Reset
Hard Reset
Important Notice:
press on/off
+ * + 3whenever you forget your security code the only option left to keep making use of the phone is to format it and the steps to take in the formation is to follow them below,
1.MENU
2.SETTINGS
3.RESTORE FACTORY SETTINGS
4.YOU WILL BE ASKED TO ENTER PHONES FACTORY DEFAULT CODE
5.12345 OR 00000
wish you good luck,
take care.
Aug 15, 2010 | Nokia 1110i Cellular Phone
My model nokia 5200 i forgot security code i want for mate my phone how can i do it please tel me
Soft Reset
Hard Reset
Important Notice:
press on/off
1.MENU
2.SETTINGS
5.12345 OR 00000
wish you good luck,
take care.
Aug 15, 2010 | Nokia 5200 Cellular Phone
How can i soft reset my lg ku990
These codes will work on nearly all Nokia mobile phones.
Soft Reset
A Soft Reset will clear pending errors and bring your mobile phone back to its preset state by restoring the factory settings. To operate this function on your mobile, the code is:*#7380#
Hard Reset
Hard Resets are sometimes needed after the soft reset was performed but the problem was not resolved. Enter the code: *#7370# then press Yes to confirm initialization.
For the Hard Reset, it is recommended that you backup all info, such as phone numbers, contacts and any data you would like to keep.
If the Nokia Mobile Phone will not turn on, press these 3 buttons at the same time: ( on/off) + ( * ) + ( 3 ).
Jun 08, 2010 | LG KU990 Viewty
I forget my password how can i reset it plz send the solution now..
hi im rain im going to give you the code to soft rest your nokia.
-----------------------------------SOFT RESET-----------------------
if that does not open your phone you can also try a hard reset.
A hard reset will erase all the user data and restore the phone back to factory settings.
It will erase everything passwords pictures music . But you'll be in and able to set a password of your own. THe hard reset code is.
------------------------------------------Hard Reset-----------------------------------
Important Notice: It is recommended that you save all important information on your phone IF it can't be replaced.
Nov 17, 2009 | Nokia 1100
I want to know my lock code..this is my e71 IMEI : 351940033894595 Please solve this problem
hi this will reset your code back to factory.
if this do not work you will need to do a hard reset . save all pictures ect..
Hard Reset
( turn phone off then back on to allow new settings)
Nov 13, 2009 | Nokia 6600
Nokia 5800 xpress music, i got it off a friend and its blocked evrything works except sms and calls keeps saying connection error, phone only works in offline mode, how can i make it work again?
try a soft reset this will unblock it and set it back to factory without deleting your data .
Nov 13, 2009 | Nokia 5800 XpressMusic Smartphone
How i can restore my nokia 5000 i don't know the seurity code plz help
But remember a hardreset will erase all your pictures , music ect... back up your files .
Nov 12, 2009 | Cell Phones
Jawbone Up24 Wristband Onyx, LARGE Logo
23 people viewed this question
Top Jawbone Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Jawbone Cell Phone Expert? Answer questions, earn points and help others
