My tv goes over all the channels before settling on one
    Top Expert:
  • Televison & ... Master
  • 75,581 Answers
Try a reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 14, 2014
I have a 50inch LG TV that when switching between programmes the TV goes blank for a moment
Are you using cable and if so which company and box?
ELECTREPAIRUSA@ELECTREPAIRUSA.COM
Dec 07, 2016 | LG Televison & Video
Cable channel source goes up from channel 3 to higher channel?
First to check your cable resepction then replace your tv tuner same number your tv channel mistunes
Jun 09, 2015 | Prima Televison & Video
My Focusrite ISA428 has some consistent issues where channel 1 buzzes, and channel 4 is unusable for 2 hours after power up. Channel 4's needle goes right up to the meter and stutters there for an hour,...
Does this happen with no mics AND outputs connected? If it doesn't, you have a severe ground loop problem. Make sure ALL interconnected equipment is powered from teh same receptacle or power source. Use ONLY balanced lines, XLR or TRS cables. A possible problem MIGHT be supersonic feedback that you can't hear but is saturating the amp. Thats is why we disconnect all inouts and outputs and observe if symtoms are still there.
Apr 06, 2011 | Focusrite ISA428 Pre Pack quad microphone...
Every now and again it will switch from HDMI1 where i am watching SKY onto the DVB inbuilt freeview channel. If i press AV to switch straight back the OS menu doesnt appear and then after about 5 seconds...
Sorry - no solution as of yet but the EXACT same thing is happening to me. (TX-32LXD700). It has only just started happening - and also seems to have tied in with the Sky+ controller stuttering with the TV controls (eg volume) after it has been configured witht he 0051 Panasonic code. Did a "Shipping reset" on the TV last night and have repgrammed the controller with 0051. Don't know if this will cure thinbgs, but just hate not knowing WHY!?! (But will settle for the cure and not knowing if it comes to that).
Feb 09, 2010 | Panasonic Televison & Video
We've had our 32" Vizio TV for about 4 months now and up until about 2 weeks ago, everything was working fine and all channels came in. Now, we only get about a quarter of the channels that we used to...
go to menu settings, find add/delete channel or programming or tuning. There should be an option that says "autoprogram" select this option and let the program run thuroughly. It will read and install all available channels. Do make sure tv is set to CATV and that it is NOT set on AIR.
Jan 27, 2010 | Televison & Video
I have a Phillips PC7225 C121 ..I programmed it to a universal remote and went to menue.. it says Barker, Channel, Firmware ..I put it on channel but cant get to do anything after that...what do I do... I...
I need to add channel 66 to this tv and it only goes to channel 60.- the remote or the tv.?.
if remote doit mannuly on the tv.
if tv. .............................
Aug 06, 2009 | Televison & Video
Cannot set channels
It is the software or the program that have the TV to operate properly.  Sorry for my english.
Dec 19, 2008 | Acer AL2671W 26 in. LCD Television
No remote-
Have you bought a universal remote for the tv? That is what we had to do to get to av mode and when you do make sure you try the input button before settling with the first code that works. We stopped at the first code that changed the channels and still could not get into av mode. Finally I tried the rest of the codes and found the correct one. HOPE THIS HELPS
Aug 10, 2008 | Sanyo DS27820 27" TV
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
