My Panasonic air conditioner CS-PC9KKT timer light flashes continuously and turns itself off every hour all night. Have tried to reset, which seemed to work, the light went out but then after an hour it turned off again and the light came back! Grrrr! Please help!
  • 43 Answers
Hello...
maybe there is a short circuit on the main board; or is defective. Try to remove the main board and clean and dry.
Posted on Nov 13, 2014
Panasonic CS-E24FKR Airconditioner keeps turning off. Error code 15 H
Is the air-conditioner plugged into an extention cord or directly into the wall outlet???
Aug 20, 2016 | Panasonic Heating & Cooling
Panasonic air conditioner with seral nr. A75C2616
Have you checked your remote
control if you have accidentally set the
timer off to turn off one hour after
turning it on? Seems like the problem because the
timer LED is lighting up means that the
unit has shut off via the timer. Verify the remote if there is a timer
setting on it. If you would not
recognize it, try to remove the battery
for about 5 minutes, return the
battery, then just press the on and off
switch and put it in cooling mode and observe if it did correct the problem.
Jul 15, 2013 | Heating & Cooling
My panasonic ceiling aircon model cs-d24db4h5-1 timer light on and not cold.
is your filter dirty? i could see it stoping if the filters dirty. check the filter and if that is not it take it into a shop or send it in. if it cost's more to fix it just forget about it and get a new one good luck.
Jun 24, 2012 | Panasonic CW-XC104HU Air Conditioner
I have a Panasonic Invertor in my office with no manual. The timer light is continually flashing and the unit will not operate. I have tried re-setting the timer to no avail. My remote has an on/off orange...
I have looked through the manual but I do not have a device to test what your issue may be but here is a link for the manual. I hope this can help you out.
https://support.panasonic.co.nz/docstore/CS-ME10DTEG%20Operating%20Instructions.pdf
Mar 01, 2011 | Heating & Cooling
I have a Friedrich MW18Y3F unit. It's not heating this morning but the operation light and timer light are flashing together 5 times and then the timer light flashes a 6th time by itself. On line manual...
Try the reset at the unit and see if the fan tries to engage at all. Also check the wiring connections between the indoor and outdoor units. If it does not then you either have a bad fan motor or the control board is bad.
Jan 30, 2011 | Heating & Cooling
My panasonic airconditioner c9kkzw timer is always blinking and automatically turned off every hour. its driving me crazy becasue my kids won't asleep.. please please help me, tried turn and off but to no...
I think, you have set the timer for one hour. No problem, remove battery from remote and reset it and same way isolate the power to your air conditioner for 5 seconds and reset it. Now all pre programmed would have been canceled. Now you can set your temp as you like.
And another reason may be your compressor getting heated after an hour, due to dust blocked in your out door coil. Hence, please serive the unit at once. Thanks.
Dec 15, 2010 | Panasonic CS-A12C Air Conditioner
Green light flashes 3 times will not operate
Its may be the thermistor is defective or out of range or the board itself, the unit will not operate unless the defective part is not replace.
Mar 04, 2008 | Fujitsu 18C1 Air Conditioner
Heating & Cooling Logo
491 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
