Explain on the subwoofer input on boston micro media system and on the right speaker there are two wires a green and a blue
Starting from left to right on the back of the sub woofer 12 volt input, white-left & red-right rca plugins, INPUT what goes there what does it hook to COMPUTER?
    Top Expert:
  • Audio Player... Master
  • 36,311 Answers
The INPUT connects to the subwoofer output of the computer.
Posted on Nov 13, 2014
fcollingwood
  • 58 Answers
SOURCE: subwoofer
Most AV receivers do not have a built in amplifier block to drive a subwoofer, and merely provide the subwoofer output channel at line voltage. Thus, a powered subwoofer is required. Does the subwoofer require mains power? From your description, I'm guessing it doesn't. If not, it does not have a buit in amplifier, you will need to purchase a monoblock amplifier, which is just a mono amplifier with a volume control, no tone controls or anything else. Make sure that the amplifier power rating is as close as possible to the subwoofer power rating, as it is quite possible to blow a speaker by using an amplifier whose power output is too low, by overdriving the amplifier , and putting DC through the voice coil when the amplifier clips. If it does require mains power, it will have an amplifier built in, but does not have line level inputs.
Posted on Sep 14, 2007
Raveler
  • 36 Answers
SOURCE: sw 300 powered sub woofer
It sounds like your subwoofer acts as a receiver in its own right. Many low-budget home theater systems act this way, and it may in fact have a Dolby Pro Logic II encoder in it. Your best bet is to hook up either the speakers it came with, or purchase speakers from your local audio visual store. Check its power rating per speaker (in watts) in your manual, and purchase speakers that are rated for it.
The "red and white" input you mention are RCA connectors, and should allow you to connect a source to your system. If you have any more specific questions, please post them here.
Posted on Jan 01, 2008
tech48
  • 624 Answers
SOURCE: subwoofer.......
Please check your model number, I can not find it on the JVC service website.
This is a powered sub-woofer I think. You need to have a thick black cord that connects the sub to the head unit. Then the satellite speakers get connected to the speaker jacks on the sub-woofer box. The sub-woofer should also be plugged into an A/C outlet on the wall.
The speaker outputs are labeled right there where you connect the speaker wires. You should see a red and black connector for each speaker and they are labeled "front right" "front left" "center" "rear right" "rear left".
If you do not have the thick black cord you need to connect the head unit with the sub-woofer, you can not use this system.
If you look at the head unit and give me the model number on it, I may be able to find the part you need. But I must have a good model number to work with, preferably from the head unit.
Dave
Posted on Nov 10, 2008
SOURCE: connect powered subwoofer
  • If your receiver has a dedicated subwoofer line level output, we recommend connecting your subwoofer to this jack. Most receivers will have just one (mono) subwoofer output, while quite a few subs require two inputs. You can use an RCA "Y" adapter cord , which is a cable with one female RCA jack at one end, and two male RCA plugs at the other. Some receivers require menu settings (such as "sub-on" or "front speakers-small") that must be made before the sub output will be active.
  • Posted on Jan 07, 2009
    • 121 Answers
    SOURCE: dayton sub-100 connection
    You have it upon one of several truly odd "standards" in the AV industry but the answer is simple if not quite logical. You will use an RCA type cable from the Sub out or LFE on the receiver to just one of the two inputs on the subwoofer. I usually use the one on the right but it really doesn't matter. The other connectors would be for a system with out a sub out where the speaker wire would be run first to the subwoofer and then out to the speakers. This will not be used at all in your case.
    Enjy!
    Posted on Feb 27, 2009
    2011 holden cruze radio wiring diagram
    2011 Chevrolet Cruze Car Radio Wiring Guide
    Car Radio Battery Constant 12V+ Wire: Red/Dark Green
    Car Radio Accessory Switched 12V+ Wire: N/A
    Car Radio Ground Wire: Black
    Car Radio Illumination Wire: N/A
    Car Radio Dimmer Wire: N/A
    Car Radio Antenna Trigger Wire: Dark Blue
    Car Radio Amp Trigger Wire: N/A
    Car Stereo Amplifier Location: N/A
    Car Audio Front Tweeter Size: 1? Tweeters
    Car Audio Front Tweeter Depth: 1?
    Car Audio Front Tweeter Location: 1?
    Left Front Speaker Positive Wire (+): Dark Blue
    Left Front Speaker Negative Wire (-): Brown/Dark Blue
    Right Front Speaker Positive Wire (+): Yellow
    Right Front Speaker Negative Wire (-): Yellow/Black
    Car Audio Front Speakers Size: 6 1/2? Speakers
    Car Audio Front Speakers Depth: 3 1/4?
    Car Audio Front Speakers Location: N/A
    Left Rear Speaker Positive Wire (+): Dark Green
    Left Rear Speaker Negative Wire (-): Dark Green/Black
    Right Rear Speaker Positive Wire (+): White
    Right Rear Speaker Negative Wire (-): Dark Blue/Black
    Car Audio Rear Speakers Size: 6 1/2? Speakers
    Car Audio Rear Speakers Depth: 3?
    Car Audio Rear Speakers Location: N/A
    Car Subwoofer Speaker Positive Wire (+): N/A
    Car Subwoofer Speaker Negative Wire (-): N/A
    Car Subwoofer Speaker Size: N/A
    Car Subwoofer Speaker Depth: N/A
    Car Subwoofer Speaker Location: N/A
    Jan 02, 2016 | Holden Cars & Trucks
    Loud humming sound
    Make sure that the input connection ground is good. If that does not cure the loud hum then you have a power supply issue.
    Oct 27, 2015 | Boston Acoustics Boston Acoustic Micro...
    How do i connect the boston BA745 comp. speakers to my gateway desktop?
    Assuming you have the BA745 2.1 speaker set up, all of the cables connect to the subwoofer and then to the computer or the satellite speakers (these are built into the speakers IIRC). Take the cable with the black box (2 pins) to red and green. The red and green plugs go into the matching color ports on the computer and the pins on the black end fit into the jacks between the those for the two satellites. Plug the single end speaker cable into the subwoofer port all the way to the right on the back of the subwoofer. Plug the wire with the two plugs into the matching color jacks (blue to the left, red to the right). Then plug in the power adapter cable in the farthest left jack and plug in the other end to a surge protected power strip (that is plugged in and turned on).
    Oct 24, 2010 | Boston Acoustics BA745 Computer Speakers
    Wiring diagrams for clarion dxz535 car stereo
    Here's how it goes:
    Speaker wires:
    grey=right front pos.
    grey/black=right front neg.
    white=left front pos.
    white/black=left front neg.
    violet=right rear pos.
    violet/black=right rear neg.
    green=left rear pos.
    green/black=left rear neg.
    red=12 volt switched power source
    yellow=12 volt constant power source (direct to battery)
    black=chassis ground
    orange/white=illumination (switched source,not to head light switch)
    blue/white=amp turn on lead (to remote turn on lead of amp)
    blue=auto antenna (switched power source)
    brown=phone mute lead (to cell phone mute lead)
    RCA connector leads:
    grey lead:
    red=right front
    white=left front
    black lead:
    red=right rear/right rear subwoofer
    white=left rear/left rear subwoofer
    (connect to external amp)
    red lead:
    red=right aux input
    white=left aux input
    (connect to external unit)
    green lead:
    red=right dual zone output
    white=left dual zone output
    (connect to wireless head phones)
    That should be all there is. on the yellow that goes direct to the battery you need to use an inline fuse holder with 30 amp fuse.
    Sep 26, 2010 | Car Audio & Video
    Where can i find a wiring diagram of a boston acoustic pc speaker
    you can compare the color of male plug agains PC female input....green on green, blue in blue etc..
    May 23, 2010 | Boston Acoustics BA735 Computer Speakers
    Can the Boston BA 7900 be converter to use with TV or DVD Player?
    Yes, but so far I can only get the 2 front speakers and subwoofer to work.
    You need a wire that converts a headphone-style jack (like the green one with the Boston speakers) into a red and white AV connection (typical CD/DVD, etc. connection). I've had this connector for a long time and I'm guessing it's under $15. You connect the green Boston speaker connection to the converter end (mine connects to the back end of the headphone-jack (which has a hole for the connection) and the red/white AV connectors to your TV.
    I'd been trying to solve the problem too for a long time. Only problem is that I can't get all 5 speakers to work because I think the red/white connector doesn't work with all 5 speakers. I have yet to figure out how to make all 5 work, but the system gives great sound anyway. You will have something like a 5.1 system with your computer speakers, the Boston speakers and subwoofers.
    One more issue is that if you connect it directly to the TV, you have to manually turn the Boston speakers on and off.
    Nov 06, 2009 | Boston Acoustics BA7900 Computer Speakers
    Wiring stereo probe gt turbo 1989
    1989 Ford Probe Stereo Wiring Constant 12V+ Blue/Red Switched 12V+ Blue/White Ground Chassis Illumination Light Green/Black Dimmer n/a Antenna Trigger White Antenna Right Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/Orange Left Front (-) Blue/Black Right Front (+) Blue Right Front (-) Blue/Green Rear Speakers 6 1/2" Side Panels Left Rear (+) Green/Orange Left Rear (-) Green/Red Right Rear (+) Green/Blue Right Rear (-) Green
    Apr 25, 2009 | Car Audio & Video
    Cant find users manual for boston micro media systems 7000596 need 2 see how it is hooked up to my computer thank u
    Plug red and white cables into woofer ports that are red/white
    Plug purple lead into front of woofer to input port
    green goes into accessory (green) port on back of computer
    elbow shaped 2 prong leads go to speakers in back
    DC power goes into front of woofer marked DC input
    Apr 19, 2009 | Boston Acoustics MicroMedia Computer...
    Only one computer speaker recieving a signal
    Most probably there is a problem in the cable or plug.
    Feb 06, 2009 | Boston Acoustics BA735 Computer Speakers
     Grubhead
    Grubhead
