Question about Crafts & Hobbies
Undefined mth train 20-2745-1 no sound relay clicks off and on
Had train repaired 2 times need to repair it unit does not run
blkghost
  • 46 Answers
SOURCE: TRAINING FOR REPAIRE RICOH COPIER MACHINE
Dear friend. If you work at this company like you say, why do u not ask to the company to help you for training.
Here is a bit dificult to train. You must have a technician whit experience to teach you, personaly.
Posted on Nov 10, 2007
  • 142 Answers
SOURCE: Power On + red LED turns on + but final relay (click) don't come so no sound
Your audio output transistors are shorted and your unit is staying in "protect " mode to protect your speakers from 40 to 60 volts that is being sent at them from the shorted outputs. If you can use a meter you won't need the schematic MOST likely because the outputs are USUALLY the only parts that short out. The output transistors( or chip ) are mounted to the large, finned heatsink. The #'s on the transistors start with "2SA-" and "2SC-" followed by numbers. There are two output transistors per channel. If your unit uses an IC for audio output then the # on the IC will be "STK-" followed by numbers. These parts are available from tritronicsinc.com. Good Luck!
barneyluc
Posted on Oct 17, 2008
drmengle
SOURCE: axu heat and outside blower fan run all the time
I can tell you exaclty whats wrong . and it sounds like multipart problems. you have an old RUUD heat pump and its reversing vavle is stuck. without that valve opening it will contantly try to run in refrigerant mode to make heat. and here its 26 degrees, het pumps are only made to be effiient in over 34 degrees and that why your electric heaters in the blower section in an in a closit of unit
continously running up you eectric bill big time. cuses for the reversing valve to stick are sitting along time when it was low on refrigernt. or ust plain shut depending on its age. that cicking is the relay trying to open or close the reversing valve swict to make pressure again. any local guy an fix that one. theyre are kits called hard start kits that they hook up to them that shoot an extra zap of jiuse in it to try to free it up if its not totally lockd up being though that you still hear the relays pulling in and out thats good you may have just caught it in time.
now here is a quick test and possible cure but only if you what your doing turn both units off take off the top cover of the old rudd and get a small hammer not a sledgehammer and rap and tap all around the reversing valve. it will be a cylindrical tube black usually have sets of copper or brass tubings going in the 2 sides of this so dont hit itthat hard it gets dents it and is ruined. look for oil spots which uually means the refrigerant leaked out , and its seized up for good. they try spinning around the big out door fan door fan some. you may have to rock it back and forth Till it braks lose but dont put super human efort int it,
than put it all bak together making sure you connected wires back up right. go in and have you wife eithe watch it or you do it and switch the breker on and off about 8 times to trying to get the cnnectors switches to stay in and if your brave take a well insulated screw driver and hold them in for 2-4 miuntes to force it to work. if that doesnt do it call your local repairman and tell him you need a hard startkit only much safer, the cost about 40$ but you labor will be high if he is sent alone so may you can help im out and lessen your bill if the valve cant be made to work again. you may want start looking for prices with that model and serial number and d shut that electric heater off some one to replace it . I hope I helped you out some no charge ( I dont have my Pay Pal acct. set up yet ) good luck tom.
Posted on Jan 12, 2009
j2easy
  • 152 Answers
SOURCE: When the unit is turned on the unit makes a
Your unit is going into the protect mode. If this still happen after you unplug "all" the speakers, your output amp/trans are shorted/grounded... send it to Sony their price to repair is with in reason. Don't want to spend that, get a new unit. "And" check your speakers that they are the right ohms speaker and not shorted out and/or have bad wires feeding them.
Posted on Nov 26, 2009
SOURCE: Samsung LN-T4053H LCD Power On problems. When
YOUR POWER SUPPLY
Posted on Apr 29, 2010
I NEED A SCHEMATICS MTH TIU
Request them from MTH.
Sep 19, 2016 | Crafts & Hobbies
I cannot get my MTH engines to run properly. Power is on, bell and horn sounds, lights are on
MTH locomotives have internal batteries that may need to be replaced. The circuit boards in some older MTH locomotives can be damaged if operated with discharged or faulty batteries. Contact MTH customer service for help with your engines.
Feb 07, 2015 | Crafts & Hobbies
Which command base will work with MTH dcs
You will need to add a TMCC Command Base and the required TIU/TMCC serial interface. This will allow you to control Lionel engines with the DCS remote. Please see page 100 of the DCS Operators Manual fifth edition.
Nov 13, 2014 | Crafts & Hobbies
I had the twin engine gg1 2360 repaired and the engines are running in opposite directions
it sounds like whoever did the repair reversed the pickup wires on one of the units.
Dec 20, 2012 | Lionel 18359 Pwc 2360 Gg-1 Engine and...
I am using a standard 80 watt transformer (not command control), but the rail sounds do not work on this unit at all. I have checked the on/off switch and played with the volume, but still no sounds. At...
Many of the MTH Protosounds 1 and 2 and Trainmaster will not work with the Lionel CW-80 electronic power source. The output waveform is so non-like sinusoidal. The electronic sound systems will not usually respond to this waveform and when they do, the sound will be garbled. Use another power source.
Sep 01, 2011 | Rio Grande Lionel 34500 Ft Diesel...
The freezer in my side by side kenmore stopped working. It makes a humming noise & a click
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | Refrigerators
I have a Maytag MZD2766GES refrigerator and it stop cooling. It has a continuous click sound near the compressor like a relay device. I changed the running capacitor and the click sound every 2 1/2 minutes...
Refrigerator
heatman101
Feb 24, 2011 | Maytag MZD2766GES Side by Side...
Mirowave won't stop running; fan runs, light is on only way to shut down is to unplug unit. Model:JVM1650WH05
Sounds like the control circuitry inside is bad,,,or the relay or switching device is stuck on...If the control circuit is bad then you will need someone qualified to repair the circuit...A word of caution...if you decide to try to fix the unit yourself I will tyell you that there are very high voltages inside that can KILL. Please do not service unless you are trained in electrical safety
Dec 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
I have a Kenmore Coldspot Model 106.7629461 Here's the problem: When the unit needs to run to keep the freezer/refrig cold, it does so for about 10-15 seconds. Then it shuts off for about 2-3 minutes. ...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
Check out this tip that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
heatman101
Oct 10, 2010 | Kenmore Refrigerators
Samsung plasma hd ps42097
Sounds like your power transformer is going bad inside the unit. Time for a repair man to visit you. Be warned, it's not going to be cheap. If you have a battery backup on your computer, try plugging the TV into that and see if it continues to shut down. If so, it's definately time for a repair man.
Steven
Sep 06, 2008 | Samsung PPM42S3 42 in. Plasma Television
Crafts & Hobbies Logo
49 people viewed this question
Top Crafts & Hobbies Experts
R.A. Ellis
R.A. Ellis
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Craft and Hobby Expert? Answer questions, earn points and help others
