Question about Microwave Ovens
Turntable has stopped going round
Still heats but doesn't go around
  • 4 Answers
Excuse me for stating the obvious but did you check your control panel to see if there is a setting for the turntable? You may have accidentally turned it off.
Posted on Nov 13, 2014
Testimonial: "Could be possible we brought it second hand with no manual so don't know on the control panel which one it would be"
I have a Russell Hobbs RHM2018 microwave oven with grill and the turntable will not stop going round and the light stays on until I unplug it? Once plugged back in it carries on in the same way? If I
The switch for the turntable does not disengage anymore. Could be a relais, could be an electronic switch. When opening the door, a second switch, in series with the other one, connected to the turntable motor disengages, stopping the motor. The light is switched on, because you opened the microwave. Perhaps you never noticed this, but it is the normal way that should work.
Aug 31, 2014 | Microwave Ovens
Turn table not turning round but heating ok
There is a panel under the microwave, held on by one or more screws. Remove it and you will see the synchronous motor inside. There should be a plug to disconnect the wires. Remove the motor and fit a new one. Ensure that the microwave is disconnected from the wall outlet before attempting any work on it.
May 18, 2011 | Microwave Ovens
I have a GE Spacesaver PVM1870 microwave - the turntable has suddenly stopped turning. I've tried the "Turntable On/Off" button, but it did not help. What else can I try?
Perhaps the turntable motor has failed. Replace it as soon as possible as if you don't the food will not cook properly.
Replacing the turntable motor.
The motor assembly is fixed to the base of the oven usually with two screws and access i obtained by removing the inspection plate directly beneath the motor. It is usally a plug in synchronus motor that revolves at a few revs per minute but the plastic cogs in the motors gear box fail and the motor assembly must be replaced. They are fairly inexpensive and obtainable usually from a domestic appliance repair shop.
If you feel confident, disconnect it from the mains power, remove anything in the cavity and turn it upside down if it is a tabletop model, a little more complicated if it is built in!
Remove the inspection plate and disconnect the motor. Remove the motor and go and get a new one. Re fit it and put the microwave back in its position. Plug it back in, with the turntable and plate. Put a cup of water on the plate inside of the oven and heat for 20 seconds to check the plate goes round.
Hope this helps.
Jan 03, 2011 | General Electric PVM1870SMSS Microwave...
GE microwave oven squeals as carousel is rotating. Noise stops in a minute or so but begins anew when the unit is used again.
If it is the wheel on the turntable that squeels, wash the turntable in strong solution of washing up liquid and water.
If it does it without a turntable fitted, change the turntable motor.
Hope this helps.
Jan 01, 2011 | General Electric Microwave Oven
I have a CMW-100 microwave. The turntable has intermittently stopped spinning. Now, it has stopped spinning entirely. Is there a part I need to replace to fix this problem? Judie Snivley
Sounds like the turntable motor has stopped working.
Hope this helps.
Dec 15, 2010 | Cuisinart CMW-100 Microwave Oven
Describe your Whirlpool JKP90B0M1BB Micro/Wall Oven combo/ doesn'
Sounds like the turntable motor is burned out or you may need a new coupler which is a plastic piece that sits on the motor shaft under the round glass tray. There is no button to make this work, it should rotate automatically when you select your time.
Jan 24, 2010 | Microwave Ovens
Have GE JVM2050 over the range microwave, which stopped heating food and water since this morning. All other functions including light, key pad, clock, turntable work normal. The magnetron sound also
if everything works except the heating, it is most likely the mag tube is on its way out.........that is the most common reason for it not too cook.......since the microwave is a GE and it is 3.5 years old, i would say you are better off buying a new microwave, the mag tube starts at around $70.00 and up + the labor it costs too have a service person put it in........around another $60.00
May 02, 2009 | GE JVM2050 Microwave Oven
Turntable makes grinding noise and barely turns
Unplug unit and take bottom off of it with the screws that go around the outer edge. The turnatanble motor has 2 screws and is removabe from the bottom underneath.
Sep 24, 2017 | GE JES1851 Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
