Question about Magnavox Zc320mw8 Dvd Player Recorder
<!-- from fixya rte -->How do i turn off dvd+vr to regular dvd - Magnavox Zc320mw8 Dvd Player Recorder
    Habit-Forming:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 166 Answers
Look in setup menu on unit
Posted on Dec 01, 2014
Tip
Import Error 0x80048003 on DVD-VR with Pegasys and TMPGEnc Products
Typically a DVD-VR media format is in ISO9660, UDF v1.02 with an import label of DVD-RECORDER and the preferred Media format is that of DVD+RW that can be written on without finalizing a erased several hundred times before it fails.
If you are trying to import a DVD-VR created on a DVD Recorder into your PC for editing and re-encoding you might get this error with either the excellent TMPGEnc Authoring Works v4.0; TMPGEnc v4.0 Xpress or the TMPGEnc MPEG Editor v2.0
When using the preferred media format of DVD+RW It might be able to find the VIDEO_TS folder and software like VSO Inspector OR Nero ROM's Info Tool may also indicate that the DVD-VR has track information on it as shown below
Possible Faults :
  • Corrupt VOB or VOB's this is the most common fault.
  • The DVD+RW reads in the DVD recorder as BLANK means that it has not authored the media correctly.
  • Faulty DVD+RW media that can only be used a finite number of times, you need to bin it and buy new media and try to record the Video again for re-import.
  • The AUDIO_TS folder is missing.
Possible Solutions:
Create an ISO file using Lightning's Excellent ImageBurn then import the DVD-VR from a mounted drive you can either use Slysoft's Virtual CloneDrive OR Alcohol 52% FE to do this make sure that you read at about X2.4 or slower and check the ignore read errors shown in red in the Settings Menu
Use DVD Shrink great user guide by Mr. Bass there also to try to import as much of the media as possible it might fail however but you will find out where the DVD-VR fails on the import it will also save the files that it has imported correctly for you which is a bonus and save them in a folder called DVD_VR or whatever the DVD Recorder labels the media as.
In this case DVD Shrink throws an I/O read error 19 seconds before the end of the track or 65% good files fails on 66%
This case shows a DVD-VR that has 10 good files however the last three VOB's of the DVD-VR format are unreadable hence the 0x80058003 error on DVD-VR import.
If you use Total Commander you can copy the 7 good files to the Harddrive and use evilmaster's excellent VOBMerge v2.51 remixed to join VTS_01_1 to VTS_01_2 together as the IFO files are still intact this will work and you will be able to import the resultant file for editing.
This is not ideal however you will still be able to retrieve about 50% of the video data from the corrupt DVD-VR from the first 2 complete Video Object Blocks (VOBs)
Even if your VOB's are not consecutive like in this example you can still join them and import then using the Add File Option or add the individual VOB's as long as the video that you want to edit is on the good VOB then you are OK.
Each one contains typically 30 mins of SLP DVD-VR video (MPEG-2 @ 720 x 576 4,380kbps 25fps) you may also need to change the file extension of merged.vob to merged.mpg to avoid any import errors although in my experience VOBs will import correctly in the latest versions of the software despite the warning shown below.
on Apr 05, 2010 | Pegasys DVD Author (123594)
LG DVD recorder RH735T. Page 10 of the manual says to finalize a disc before you can play it on a different unit. But when I record something on a disc, the settings menu will not allow me to finalize
On my Toshiba DVD burners, you need to first open the DVD tray, and while it is open hit the regular menu, then DVD menu, select "FORMAT" from the DVD drop down menu, then "FORMAT MODE", which leads you to the 2 CRITICAL Choices :
1) Video Mode - Which has the DVD recording in "DVD Compatibility Mode" so it is "Compatible" with most other DVD Players
OR...
2) VR Mode- Which says "Editing Possibility mode" (Note you need a "+R DVD "to be able to do editing, at least on my machines.
Obviously you'll close the DVD tray to be ready to record
Finish the DVD, @ "DVD" Menu, & Finalize, or what you need with "VR"
Mar 02, 2014 | LG Televison & Video
What file formats does the Sony DVP-NS51P support?
It will play the following: DVD Video VCD SVCD DVD-R DVD-RW DVD+R DVD+RW CD (Audio) CD-R CD-RW Picture CD DVD+R DL DVD-VR as well as MP3 and JPEG file formats. Hope this helps.
Jan 10, 2011 | Sony DVP-NS51P DVD Player
GO Video VR 3845 DVD/VCR combo will not turn on.
Yes,if u want to.Unplug,replug the unit back after about an hour or so.The unit should reset it self out of protection mode and work again,if nothing in the circuit boards are burn.
Jun 15, 2010 | GoVideo Go Video DVD/VCR Combo
I Have a Magnavox MWR10D6 DVD Recorder Certain shows or movies i try to record , I get a pop-up saying " Cannot record in +VR mode " . What is +vr mode and how do I change it?
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewritable disc.
In VR mode, users can create and rename titles for the scenes. Also, if a scene is deleted, the space allocated by it will be utilized later without the need of reformatting a disc.
If the user would like to record on the same disc again at a later time, in VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Currently, users can only record in VR mode with the use of DVD-RW, DVD-RAM and DVD+RW discs, (updated in 2000 to accommodate DVD-R (General)) [DVD players marked “RW compatible” and “DVD Multi” can play DVD-VR recorded discs] and on some recorders, also on hard-disk drives.
Oct 29, 2009 | Philips Magnavox MWR10D6 DVD Recorder
What is +vr and how do I remove it
VR mode or Video Recording mode is a feature on stand-alone consumer and computer DVD recorders that allows video recording and editing on a DVD rewriteable disc.
If the user would like to record on the same disc again in later time, on VR mode, users may eject the disc and it will not be finalized by the recorder until it is manually initiated. For the sake of comparison, any DVD disc recorded in VR's competitor V mode (or Video mode) will be automatically finalized before it is ejected by the recorder. Disc finalization is still required if the disc formatted for VR mode will be played in another DVD player.
Blu-ray Disc and HD DVD also support VR mode-like features.
Accordingly when DVD recorders became a viable option the features offered by <Video Mode> were minimal - the linear structure did not allow post recording editting or non-linear playback. Thus the DVD Forum devised Video Recording (VR) mode.
Unlike DVD-Video this uses a much simplier file structure that allows non-linear modification to the recorded data. This means features such as partial erase, editting, playlists, simulataneous record/playback, mixing of different media types (JPEG, MPEG1/2/4, MP3, WMA, WMV etc) and, in future models, dual record are all possible."
That basically summerises the differences: video is a linear recording that should end up DVD-Video compatible, VR is a digital recording mode that allows HDD-like functionality on disc.
Do you need to always be able play your recorded DVD-RW discs on other DVD Players? If yes you have to use Video Mode, although some players will play VR mode discs, and you can test this easily by giving it a go.
The main differences are:
DVD Video mode on DVD-RW
Plus points: Provides good compatibility (70% plus). That’s the only plus, plain and simple.
Negative Points: Only simple linear editing possible, really just hiding a title. You can reuse space only when you delete the last title or completely reformat but lose everything in the process. No defect management. Requires finalisation to play in other DVD Players. No possibility of time-slip, i.e. recording and playing back at the same time.
DVD VR mode (Video Recording)
Plus points: Better use of recording rates by having intermediate resolutions. Defect management so reliable. Time-slip on 2 speed media if supported by the recorder, allowing record and playback at the same time. Non-linear editing. Any space freed is reused automatically (think hard-drive or Mini-Disc) and added to the remaining time.
Negative Points: Not very compatible with existing DVD Players, plain and simple.
Of course if you have a hard-drive based recorder then all the negatives are wiped out, as you use VR mode on the hard-drive which gives you all the pluses of VR mode, then record to DVD-RW in Video Mode to give you the compatibility to play the disc elsewhere.
- A recording on DVD-RAM will always use VR mode
- A recording on DVD-R will always use Video mode
- A recording on DVD-RW can be either Video or VR depending which is set before the recording is made.
- A recording to DVD+RW or DVD+R will always use Video mode
- Many HDD/DVDR combi recorders will record to the HDD in VR mode and allow you to dub (digitally) to DVD-R in Video mode.
Here is your manual:
http://www.p4c.philips.com/files/d/dvdr3545v_37/dvdr3545v_37_dfu_aen.pdf
Jan 10, 2009 | Philips DVDR3545V/37
Playing a recorded dvd from dvd-vr375 on another dvd player
If you are using DVD-R media, you can record in either V or VR mode.  What is confusing is that if you try to format the media, you only have the choice of VR mode -- and this mode is very well understood by other dvd players, some other records do understand it.  This mode has much better editing capability, but poor compatibility.  If you want compatibility, use the V mode.  The trick is that to do that, you don't format it!   V mode is the default and does not require formatting.  The owners manual says that, but too well hidden if you ask me
Oct 23, 2008 | Samsung DVD-VR375 DVD Recorder/VCR
Mini dvd can be burned on a regular dvd, but cannot be played
convert them to normal format using file convertor or record in VR format instead of Video format
Oct 24, 2007 | Canon DC210 DVD Camcorder
Zenith xbr411 DVD recorder
See the manual, page 8:
What are “Recording modes”? for DVD-RW
There are two recording modes available using this
recorder: VR mode and Video mode. When recording to
a DVD-R disc, recordings are always in Video mode.
DVD-RW discs can be formatted for VR mode recording
or Video mode recording.
VR mode recording
• 4 different picture quality/recording time settings available
(SP, LP, EP, XP)
• Not playable on regular DVD players
• Recordings can be extensively edited
• Total number of titles on the disc should be less than
99.
(SP, LP, EP, XP)
• Playable on regular DVD players (after finalizing)
• Limited editing features
99.
Note :
DVD-Video Format (Video mode) is a new format for
recording on DVD-R/RW discs that was approved by
the DVD Forum in 2000. You may therefore experience
problems playing recordable DVD discs in some players.
Symptoms include video artifacts, audio and/or
video dropouts and playback suddenly stopping.
Our company cannot take responsibility for problems
playing discs recorded on this VCR/DVD Recorder in
other players.
May 24, 2007 | Zenith XBR411 DVD Recorder/VCR
Magnavox Zc320mw8 Dvd Player Recorder Logo
57 people viewed this question
Top Magnavox Audio Players & Recorders Experts
Jay Plesset
Are you a Magnavox Audio Player and Recorder Expert? Answer questions, earn points and help others
