Question about Motorola Mobility Moto G - Verizon Prepaid Phone Verizon Prepaid Only
My phone is a Verizon Moto G , it sometimes freezes the apps, and then it turns off by itself. When I try turning it on it wont work, then i hold the power button and it vibrates, and take a while to
Please help , I don't know why the phone is missing up, it was working properly, now it wont work like it use to, when I first got it it never did do this, now it turns off and on and freezes.
  • Official Brand Answer
  • 1,623 Answers
Panesha
Try running the phone in safe mode. To do this. Press power button then when power down appears. Long press power down option. It will ask if you want to boot into safe mode. Select ok the it will reboot in safe mode. Use the phone in safe mode for 24 he's to see how it works. If it works better, then there is a third party app you installed on the phone that I'd causing freezing.
Mark
Motorola Support
Posted on Jan 26, 2015
Moto g wont turn on
Try holding down the power key for 30 seconds. You should see a white indicator light blink. If not then plug it into a charger that you know works. If your not using the original charger it may not be getting enough power. You may need to charge it for a couple of hours and then attempt to turn it on while on the charger by holding down the power button for atleast 30 secs or untill it turns on.
Sep 20, 2014 | Motorola Mobility Moto G - Verizon Prepaid...
Freezes turns off sometimes wont scroll same thing when trying to call moto x 2
Try using the phone in Safe Mode and see if you still have an issue.
Mark
Motorola Support
Aug 15, 2014 | Motorola Moto X XT1052 4G LTE 16GB...
My phone wont turn on all the way
Try reseting it by holding the power and volume down buttons when starting the phone up
Dec 07, 2013 | Motorola Mobility Moto X
KEEPS FREEZING WHEN MAKING CALLS PHONE FREEZES. WONT TURN ON ALL THE TIME AND ONLY WILL STAY IN WORKING OPERATION FOR A FEW MOMENTS AT A TIME THEN HAVE TO REMOVE BATTERY AND TRY TO TURN O;N AGAIN SOMETIMES...
This is a known software/firmware bug for the earlier versions. You should contact Verizon, explain the problem and request a software update under warranty. They might even swap phones to fix it ...
Aug 17, 2009 | Verizon Communications G'zOne Type-V...
Phone wont stay on
well your screen problem could be due to some frozen LED's or simply fauly wiring. Did you get this phone used by any chance? If so the store may not replace it. Back to the solution, take out the back battery and you should see 4 screws holding in the outer body of the phone in place with its inside. take these screws off andd carefully remove the outer shell. it you see a blown bulb, this is your problem and it cannot usually be replaced unless you order a whole new circuit switch which you most likely will have to install yourself. otherwise, there may be a loose chip. try snapping it back into place (not too hard or the motherboard may split). replace the outer body and try the phone again. as for the phone only staying ion while plugged in, this is most likley a broken battery. this can only be fixed by replacment. hope this helps.
Jan 15, 2009 | Motorola Mobility MOTO W755 Cellular Phone
Lg Envy2 Keeps freezing
my phone was doing the same thing, i took it to my verizon store and they did a free software update. Seems to have fixed the problem so far.
Nov 25, 2008 | LG enV VX9900 Cellular Phone
My lg dare keeps freezing
throw the ******* thing away,, it wont work, ive tried everything
Sep 12, 2008 | Cell Phones
Need help..
Well, as is the case with most glitchy phones, this is definetly the firmware. Your phone needs to by flashed by a verizon service center. Dont do it anywhere else, this phone is CDMA and needs the actual Verizon firmware because of the PRL (prefered roaming list).
Jan 25, 2008 | Motorola Mobility MoroKRZR K1m Cellular...
Phone freezes and sometimes wont turn on
trying servicing the board or reflashing the firmware...or updating it
Dec 03, 2007 | Sony Ericsson Walkman W810i Cellular Phone
Moto Q won't turn on
Hold down the center nav key and power up the unit. This will restore any files that may have been corrupted and put them to original. If you loaded a 3 party app or something prior to this may be the cause of the issue. Don't use that app.
Aug 10, 2007 | Motorola Mobility Moto Q
Motorola Mobility Moto G - Verizon Prepaid Phone Verizon Prepaid Only Logo
66 people viewed this question
Top Motorola Mobility Cell Phones Experts
Rami Obeid
Level 1 Expert
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
