Question about Seca 769 Digital Scale 400 Lb with Bmi and Height Rod
Reset the scale after changing batteries
I had to change the batteries on the scale and i now need to reset it
MY SCALE READ 202 AND THEN STEPPED ON IT AGAIN AND IT READS 333 LBS AND NOW STAYS THAT WAY WHEN I STEP ON IT AND HOW DO I FIX THE PROBLEM.
you most probably need to reset scale to factory settings, as you did not give what model and manufacturer, therefore you need to find your manual or google on line howto reset your scale
do not forget to vote...
Dec 31, 2014 | Health & Beauty
Need to reset the weight on the conair th300m. already replaced the battery
Actual weight is detected by a pressure transducer which may have failed. The constantly changing readout indicates there may be a problem with the internal circuitry.
Jun 16, 2014 | Weight Watchers Glass Electronic Scale
I changed the battery and now when turned on all icons on screen flashing non stop
try repeated pressure to reset (5-6 times in 10 sec) or could see if there is a small hole near battery compartment, push with paperclip (button reset)
Jun 06, 2014 | Soehnle Exacta 63694 Body Fat and Water...
Need to reset to oz
If it is operated by battery, try removing the batteries, or unplug from the wall. Check if there is a button to change to ounces.
Thanks
Jun 08, 2011 | Detecto Ap 6 Portion Control Digital...
Scale keeps showing lo no weight
Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Apr 19, 2011 | Homedics Digital Scale
Have a WeighMax postal scale..how to I cange from kg to pounds?
I had mine set to ozs for over a year and then it changed to kg. Couldn't reset it by hitting the button, so I removed the battery and then put it back in. It reset it to ozs.
Jan 15, 2011 | Precision Camera Weighmax Body Fat, Body...
I just changed the battery and I keep getting the temperatures in Celsius instead of Fahren. How do I change it to F?
You need to discinnect the battery and reinstall it. When you reconnect the battery press the 'SET' button within 15 seconds. The temperature reading will now be set to Degrees F.
See below.
Setting/Changing ºC and ºF Temperature Scales
The food safety thermometer can display temperature in either the °C
(Celsius) or °F (Fahrenheit) scales. The desired scale is selected at the time
the battery is installed:
Selecting the °C Scale:
When the battery is connected to the battery leads the °C scale indicator
shows on the display for approximately 15 seconds. If the SET button is
not pressed the unit will time out and default to the °C or Celsius scale.
Selecting the °F Scale:
If the SET button is pressed within 15 seconds of connecting the battery to
the battery leads, the temperature scale display will toggle to the °F scale
indicator and the unit will now default to the °F or Fahrenheit scale
Feb 28, 2010 | Fluke Networks Fluke/Raytek FoodPro Plus...
Reset digital bathroom scales
I cannot reset my digital scale to lbs. it is a conair ww body mass scale
Aug 25, 2009 | Health & Beauty
Seca 769 Digital Scale 400 Lb with Bmi and Height Rod Logo
Top Seca Health & Beauty Experts
Tom Chichester
Donald Ayers-Marsh
Are you a Seca Health and Beauty Expert? Answer questions, earn points and help others
