Question about Samsung Televison & Video
There is a Red X and the number 1 below it. Nothing else on the screen.
Unplugged the cable box and tried to boot up but the x and 1 are back.
    Top Expert:
  • Samsung Master
  • 75,320 Answers
Try a reset to this set, and check. There are two types of reset to TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight; will be better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Posted on Nov 14, 2014
4 Suggested Answers
tvtek
  • 1284 Answers
SOURCE: Picture not to full screen
Try connecting just the cable to the TV and bypass the cable box. If you get a full screen and the "ASPECT" button on the remote gives you full operation then either you need to change the output on the cable box to 16:9 output at 1080i resolution (because it sounds like the box is putting out a 4:3 screen size)or in your customer menus on the TV, I believe there is a "AUTO ASPECT" selection? If there is and it is activated then turn hat off. Having DVR won't effect the screen size. It just means the cable box has a hard drive built in to it.
Posted on Mar 13, 2007
jdbouncer
  • 72 Answers
SOURCE: color has too much red
Is this happening when you are switching between color tempature (Normal,Warm, and Cool). You wont be able to access it in normal menu.
You will have to accesss the service tech menu. enter "062596 then info", if u enter the code correct at bottom of screen you will see a warning menu only access by a service tech , continue in menu you will see on main option screen "alignment" enter this. Go to white point adjust the three temp settings (Normal, Warm, and Cool) settings as follows.
Color Temp. I Red I Green I Blue I
Cool 122 120 121
Normal 125 118 108
Warm 127 110 75
( These are factory specs u can tweak them to your own perference)
After u set these press left on remote and exit back to main service menu and store these setting before turning TV off set these settings
I see this alot when Philips manufactured the TV. The did store the settings.
Posted on May 01, 2008
Lear70
SOURCE: My Sharp LED LC-52LE820UN HDMI
This is a known problem on Sharp Aquos TV's. The HDMI inputs connect to their own sub-processor board right at the ports. This board is VERY prone to failure with just the SLIGHTEST static electricity problem - it usually starts acting up after a storm, will only go out for a couple hours, you turn the TV off, come back the next morning, and it works again. You think "OK, random problem, whatever". Then it does it again a couple months later, then it starts happening more and more until the board completely stops working altogether. The board is about $150 and is easy to replace yourself - if you've ever replaced a card in your PC computer, it's not much more difficult, just more screws. These tend to go out right at the 11-13 month point, which is awesome as far as a warranty is concerned. In short, get the extended warranty or buy with American Express which automatically doubles manufacturer's warranties with ANY electronics purchase, then replace it before the warranty is up. Good luck. (and P.S., Sharp will argue that this isn't a known problem but just do a Google search, it'll pop up all over the place).
Posted on Oct 15, 2012
My digital tv is saying no singal whats the problem and how do I fix it? we have a huge antenna on our roof
1 – Is the NO SIGNAL issue happening on just one TV?
CORRECT INPUT or SOURCE
If it is just one TV that is showing the NO SIGNAL…
-Be sure your TV is on the correct source or input as your CABLE or SAT BOX.
-Press the TV button on TV remote control to turn your TV ON.
-Press the INPUT button on your TV remote control.
-Cycle through all the inputs on your TV.
-Do this until you are on the INPUT your CABLE or SAT BOX is plugged into.
-You should then see the CABLE or SAT programming show on your TV.
HINT: Your TV will most likely list the TV INPUTS as: HDMI 1, HDMI 2, HDMI 3, VGA, Component 1, Component 2, and so on.
If you still see NO SIGNAL on your TV screen, see the next step below…
2 – If you have your TV on the correct INPUT or SOURCE and you still see NO SIGNAL…
CABLE OR SAT BOX NEEDS RESET
-Remove or unplug the power cable from the Cable TV or SAT set top box.
-Keep it unplugged for 2 to 3 minutes.
-Plug the power cable back into your Cable or SAT set top box.
-Give it some time for the Cable or SAT box to power up, get the signal, and initialize.
3 – If you have reset the Cable or SAT box and still have the NO SIGNAL…
UNPLUG THE CABLE GOING FROM THE TV TO YOUR CABLE OR SAT BOX
-Remove the HDMI cable or other cables from your Cable TV or SAT set top box.
-Keep the cable unplugged for 2 to 3 minutes.
-Plug the HDMI cable or other cables back in.
-Give it some time for the Cable or SAT box to get the signal and initialize.
HINT: Make sure all the cables that are connected to your Cable or SAT box and your TV are tight, undamaged, and secured.
4 – If all of your TVs are affected with the NO SIGNAL screen…
BE SURE THE COAX CABLES OR ETHERNET CABLES ARE SECURE or CABLE OR SAT IS DOWN TEMPORARILY
-Be sure to check the ones where the CABLE or SAT come into your home.
-Be sure ALL Ethernet and Coax cables are secure.
-Call your CABLE or SAT provider to see if there is an outage.
-Realign your Dish if you have SATELLITE.
May 10, 2017 | Televison & Video
My TV is frozen with this picture on the screen. I unplug the TV and nothing happens. The picture below is what it looks like with the TV unplugged. Can you please help?
What is causing the HDMI 1 display on the TV if the "TV" is unplugged?? What you have pictured is more typical of having the "Source" of the TV chosen as the HDMI 1 input to the TV, not the cable input, and having no live device plugged into the HDMI 1 input. Check your manual for how to select different input sources for your TV, make sure all devices attached to the TV are turned on, including the cable box, and try selecting the various inputs until you get the signal you are looking for.
Jun 15, 2015 | Televison & Video
Tv2 remote not working tv1 must be on
It sounds like the RCA cable is plugged into TV 2 ports on the back of the receiver.
Depending upon your receiver, towards the center on the back of the receiver, you have 3 rows of colored (2 - Red, White, and Yellow; 1 - Green, Blue, Red). The RCA for TV 1 should go in the middle row. Please let me know if you have further problems. Thanks.
Dec 16, 2011 | DISH Network IR Remote Control
I followed the instructions and still nothing. I installed the red and white cables to my cable box. Looks pretty simple. Frank
Hello Frank,
If you've only connected the red and white plugs, you need yellow as well - unless you are using a coaxial cable. If you are using a coaxial cable, then you don't need the red and white plugs, but you will need to run the channel scan on the TV.
If you are using the red, white and yellow connections, you need to set the TV to an external input setting. Look for a button on the TV remote or the front of the TV labelled INPUT or SOURCE. The correct inputwill probably be called either AV, VIDEO, or COMPOSITE.
If you can let me know the information listed below, I can give you exact setup instructions for your equipment and draw you a connection diagram, if required.
1. Brand and model number of TV;
2. Brand and model number of cable box;
3. What cables do you have available;
Hope this helps. If you need further assistance, please reply to me with this information by clicking on "Add a Comment" below your question.
Regards,
BElectric
Feb 19, 2011 | Televison & Video
Computer will power up but won't boot
It seems you have done things i would have done to find the problem.
Have you check the switch mode power supply?
Leave the components connected (test under load) and power up and check the voltages on oe of the power plugs (4 pin), the voltages for 12 volts (yellow wire) and 5 volts (red wire). The 5 volts is the most important power supply, it is for the electronic circuits. If the voltages are below 10% then this could be the problem.
Nov 25, 2009 | Computers & Internet
Compaq 5002US PC won't boot (not even BIOS); no sights or sounds
if the processor was fried, it would not boot at all. i take it that you cannot get into bios? perhaps bios is currupt.
Mar 21, 2009 | Compaq Presario 5000US (D70008-261) PC...
Number 2 is in upper right corner; cannot remove
Had the same problems. Rebooted the box and the 2 was gone. Hope this works.
Oct 05, 2008 | Televison & Video
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Mar 12, 2007 | Hitachi 55HDT51 55 in. HD-Ready Plasma...
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
