Question about Airhead SLIDE - DOC RAYBURN MFG. INC
How do I keep it going overnight as it keeps going out!
14.1 kw
Replace a kfceh3101c15 with a 20 kw. 15 kw just is not keeping up in this weather
The best answer would come from Carrier. Here is their contact info-
Feb 23, 2015 | Carrier Heating & Cooling
Why my 1996 golf from turn off while driving, it sparks but I won't start, need to wait 30 min and it will start with no problem but if it keep driving it it will do the same thing... please help me
which engine? see list , mind blowing, and what country>???
doing a 60k mile tuneup works, at least once a decade.
ever do the list of parts, spark and fuel , per operators guide?
that be first, 99% of bad running engines are that.
my guess , (weak based on only 1 fact) is has lost fueling
the ECU in the all cars 96 tries 10x to stop stalls.
the reasons are this: (top list)
1: lost 12vdc power ,see dash lamps or other lights go dead at stall>?
2: lost spark (tune up time?)
3: lost fueling, (try test fuel start now.
4: flooded, are the spark tips soaked in raw gasoline. (use wide open throttle cranking, does that work? this cuts fuel. (a secret mode)
5: ISC dead? (start car with 10% throttle) ok ISC is funky. clean it.
can you save the stall with fast right foot? (key fact here)
gen 3 engine list.
1.4 I4 40/44 kW (ABD/AEX/APQ)
1.6 I4 55 kW (ABU/AEA/AEE)
1.6 I4 74 kW (AEK/AFT/AKS)
1.8 I4 55 kW (AAM/ANN)
1.8 I4 66 kW (ABS/ADZ/ACC/ANP)
2.0 I4 85 kW (2E/ADY/AGG/AKR/ABA/AWG/AWF)
2.0 I4 16v 110 kW (ABF)
2.8 VR6 128 kW (AAA)
2.9 VR6 140 kW (ABV)
1.9 I4 D 47 kW (1Y)
1.9 I4 SDI 47 kW (AEY)
1.9 I4 TD 55 kW (AAZ)
1.9 I4 TDI 66 kW (1Z/ALE/AHU)
1.9 I4 TDI 81 kW (AFN/AVG)
Jul 10, 2014 | Cars & Trucks
New battery keeps going dead when car shut off overnight
Sounds like a slow drain - like a dome light or short in the wiring.
If the battery stays charged when it is disconnected, you'll have to check for a power drain in the car.
Jan 16, 2014 | 1997 Honda Civic
Does any one know how many valves a 1986-1987 toyota carolla 1.6 has, I think it is 12 or 8
Hi there:
Keep in mind this information:
Japanese market engines:
* 3A-U 1.5 L (1490 cc) I4, 8-valve SOHC, carb, 83 hp (62 kW)
* 3A-LU 1.5 L (1490 cc) I4, 8-valve SOHC, carb, transverse mount, 83 hp (62 kW)
* 4A-GEU 1.6 L I4, 16-valve DOHC, EFI, 130 hp (97 kW)
* 2E 1.3 liter
* 5A-F 1.5 liter
* 5A-FHE 1.5 liter
* 4A-FE 1.6 liter
* 4A-GE 1.6 liter
* 4A-GZE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, supercharger, 165 hp (121 kW) GT-Z
* 2E 1.3 L (1295 cc) I4 cylinder 12v SOHC 73 PS (54 kW; 72 hp)
* 4E-FE 1.3 L (1331 cc) I4 cylinder 16v DOHC 100 PS (74 kW; 99 hp)
* 5E-FE 1.5 L (1497 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 5A-FE 1.5 L (1498 cc) I4 cylinder 16v DOHC 105 PS (77 kW; 104 hp)
* 4A-FE 1.6 L (1587 cc) I4 cylinder 16v DOHC 115 PS (85 kW; 113 hp)
* 4A-GE 1.6 L (1587 cc) I4 cylinder 20v DOHC VVT 160 PS (118 kW; 158 hp)
* 4A-GZE 1.6 L (1587 cc) I4 cylinder 16v DOHC supercharged 170 PS (125 kW; 168 hp)
North American market engines:
* 4A-C 1.6 L I4, 8-valve SOHC, carb, 90 hp (67 kW)
* 4A-GE 1.6 L I4, 16-valve DOHC, EFI, 112 hp (86 kW)
* 4A-F 1.6 L (1587 cc) I4, 16-valve DOHC, carb, narrow valve angle, 95 hp (71 kW)
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 102 hp (76 kW)
* 4A-GE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, wide valve angle, 115 hp (86 kW) 1988/89, 135 hp (100 kW) 1990/91 GT-S
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 93-94 SD
* 4A-FE 1.6 L (1587 cc) I4, 16-valve DOHC, FI, narrow valve angle, 100 hp (75 kW) 95-97 SD
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 115 hp (86 kW) 93-94 DX and LE
* 7A-FE 1.8 L (1762 cc) I4, 16-valve DOHC, FI, narrow valve angle, 105 hp (78 kW) 95-97 DX, and LE
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Jun 18, 2012 | Toyota Corolla Cars & Trucks
My battery keeps dying, and I replaced the alernator
with the engine running check the voltage at the battery. If you see 14 volts than the tensioner is not the problem. If it where the problem you would probably hear a belt squeal.
does the battery go dead while you are driving?
Does the battery go dead after the vehicle sits overnight?
Feb 03, 2012 | Cars & Trucks
2009 Jeep Liberty battery keeps dying!
Check and verify that your alternator is charging properly, if you hook a multimeter up to your battery you should see a voltage between 13-14 volts on the charging side, if this is the case your alternator is good, next i would check the resting voltage of your battery that should be tested with the car off and it should be between 12-12.5 volts, if all of this checks out i would start looking into the parasitic draw on your battery while your vehical sits overnight, make sure all your courtesy lights are going off, your glove compartment light any under hood lights things like that if any lights like this are remaining on you will have a dead battery day after day because the light or draw on the battery keeps draining it of its charge....
Dec 07, 2010 | Jeep Liberty Cars & Trucks
Need driver windows seven
Go this website www.driverguide.com they usually keep up with the current drivers.
Dec 13, 2009 | KWorld KW-TV878RF PRO (kwtv878rfpro) TV...
Airhead SLIDE - DOC RAYBURN MFG. INC Logo
354 people viewed this question
Top Airhead Boating Experts
Steve
Steve
ray gallant
Andrew Taylor
Andrew Taylor
Are you an Airhead Boating Expert? Answer questions, earn points and help others
