Question about Ovens
I have moved in a property the cooker is a beko s 502
For the life of me cant work the grill at all do i need to call someone
    Master:
  • 876 Answers
Posted on Nov 15, 2014
  • 26 Answers
SOURCE: conection of a beko electric cooker
Pretty normal problem with Beko.
You need a Philips 2 screwdriver to get a suitable grip on the screwhead.
Good Luck!
Posted on Nov 27, 2008
SOURCE: Beko D533 cooker only half working
where the power goes in there should be fuse links on both sides if they all in then its the thermal fuse inside
Posted on Jun 22, 2009
SOURCE: beko dvc6531 cooker
i can send u a copy of user manual if you need one you have to hold the first two buttons in then move time with up or down please email me if you need more info andyali09@btinternet.com
Posted on Aug 30, 2009
  • 3 Answers
SOURCE: beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
Posted on Sep 17, 2010
  • 417 Answers
SOURCE: Beko dv555w electric cooker.Oven and
Hi
check that the cook mode is set to MANUAL, as if its on AUTO it will not come on.
Posted on Dec 20, 2010
Beko oven
If you have a problem with your beko cooker or oven then this diagnostic video will help you find the fault and i hope it helps you. i have put a link also so you can get the parts for your cooker
cooker parts
Need help fixing your appliances
these repair guides will also help you find and understand the exact problem with your cooker
How to Repair
and if we really helped you you could always buy us a beer
Buy Paul Beer
Jul 06, 2013 | Ovens
Beko DVC5622X bottom oven wont heat up
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. If this helped you why not get me a beer?
Paul is from the Naturally he would appreciate beer How to Repair Home...
Oct 27, 2011 | Ovens
I ve got beko electric cooker model DC543 and the oven doesn't work
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing. For all you Beko elements
Jan 15, 2011 | Ovens
Our beko dv 555 w double oven bottom oven is not working as the clock display is not on
Beko DV 555w Electric cooker.Oven and clock is not working.
The hob and grill work.
Nov 19, 2010 | Ovens
Have beko D533W electric cooker oven not heating up fan still working
Generally speaking, if the fan is working o/k, then it is usually the fan oven element that has failed.
This is usually located at the rear of the oven compartment behind a removeable cover.
Nov 14, 2010 | Ovens
Have a new electric cooker but the oven and 1 of the hob plates isn't working dc5422 beko
hi chances are that the internal thermal cutout fuse has gone this fuse is situated on the right hand side of the cooker when you have taken the back plate off about half way down it has two wires attached to it and is screwed with a self tap on the right hand corner of the body of the cooker near the middle of the cooker. You can buy this part and have it delivered for about £6 so is a very cheap fix.
Sep 17, 2010 | Ovens
Beko dvc 62 ,all electrics tripped out ,put cooker
May 16, 2010 | Ovens
Beko s512 oven wont heat up light not on hob works ok ,,electric oven
you probabbly have some burnt out elements or switches gone bad use a meter and check for current coming to your element when you have it on if no current its a switch if there is current then its an element problem
Mar 15, 2009 | Ovens
Dec 07, 2008 | Ovens
Conection of a beko electric cooker
Good Luck!
Nov 26, 2008 | Ovens
Ovens Logo
89 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
