Question about Video Game Consoles & Games
My Wii won't connect to the internet - Video Game Consoles & Games
Can't connect to online content
you must have the internet ready to go online! if you don't have a wking internet connection, then it won't work. set it up in the wii settings menu. and then update!
your guy for help,
ElijahCruz
Even kids can help :)
Jul 14, 2012 | Nintendo The Beatles Rockband Bundle For...
What is error code 32007 my wii won't connect to
http://www.nintendo.com/consumer/wfc/en_na/ds/results.jsp?error_code=32007&system=wii&locale=langYour Wii was disconnected from the internet during a system update.
May 06, 2012 | Nintendo Video Game Consoles & Games
Ps3 won't connect to internet?
For instructions on setting up the PS3, Xbox, or Wii, for awireless/Internet connection. please click on this link :-http://fixhomenetwork.com/xbox-play-station-wii.php
Nov 17, 2011 | Sony Video Game Consoles & Games
Cant connect to wii shopping channel
If you haven't connected to the internet yet,then you won't be able to connect to the wii shopping channel.
Jul 19, 2011 | Video Game Consoles & Games
How do I connect my PS3 to my network? It won't recognize my key.
For instructions on setting up the PS3, Xbox, Wii, for awireless/Internet connection. please click on
this link :- http://fixhomenetwork.com/xbox-play-station-wii.php
Jun 01, 2011 | D-Link DIR-615 Wireless Router
My Wii will not conncet to netflix. It keeps telling me to try later and I tested to see if it still had internet connection and it does but it still won't connect to netflix. How do I fix this?
Netflix is down at the moment. my PS3 won't connect right now either. On the plus side, the last time this happened, they offered me a discount. =)
May 10, 2011 | Nintendo Wii Console
My wii won' t register
You should first check to see if your internet connection on the Wii is up and running. Next just double check through all of the steps that your doing everything correctly. Good Luck!
Mar 03, 2011 | Nintendo Wii Console
Cant connect wii to internet
The unit can connect to the Internet by utilizing its 802.11b/g Wi-Fi, which is built in, for wireless connections or via a USB-to-Ethernet adaptor for DSL connections.
For your wireless connection or Wi-Fi, the 802.11b Wi-Fi has a data rate of 11 Mbits per second and has an indoor range of 30m or approximately 98 ft. The 802.11g has the same indoor range, however the data rate is at 54 Mbits per second. If you have an existing wireless connection or are in a Wi-Fi hotspot, the unit will connect to your wireless connection automatically out of the box. If you do not have a wireless network, however, you will need to have your wireless network subscription done or set-up first. Once you have wireless Internet access, you then search for your access point, put in your security settings and you’re good to go. It would also be advisable to have a wireless router for this so that you won’t have to shuttle the connection between your PC and your Wii. wi-fi-usb-connector.thumbnail.jpgAnother option would be to connect your Wii via the Nintendo Wi-Fi USB Connector. This accessory allows Nintendo Wii users who do not have an existing Wi-Fi connection or a compatible Wi-Fi network to create one through their broadband or DSL connected computer. This is inserted into your existing computer’s USB port and the Wi-Fi USB Connector acts as a wireless access point for the Wii. This allows the user access to the internet and to play Wi-Fi Connection games from Nintendo Online.
nintendo-wii-lan-adapter.thumbnail.jpgFor your DSL connection, however, you will need to have quite a few things. You can use a WII LAN adapter to connect your Wii to your DSL modem. You can also use a router so that you can use your PC and your Wii at the same time. With the LAN Adapter though, to use or plug in the Wii, you must disconnect your PC. This can be quite tedious since you will have to plug in and out your PC and your Wii every time you need to use one or the other. A LAN Adapter is fairly cheap, but if you get a router, your PC and your Wii can go online at the same time, saving you the hassle of connecting one or the other when you need them. You can then hook up the existing ethernet cords to the back of the router and connect it to the Wii via a USB 2.0 cord.
i hope this helps
Nov 05, 2009 | Nintendo Wii Console
Wii shop channel won,t work
YOur internet isnt allowing the wii to access the shop...
Apr 22, 2008 | Nintendo Wii Console
Video Game Consoles & Games Logo
Top Video Game Consoles & Games Experts
James Wishart
Are you a Video Game Console and Game Expert? Answer questions, earn points and help others
