Question about Indesit IDV 65 White Electric Dryer 6 kg, 16 Cycles
I have an Indesit idv65 Tumble dryer and the plug gets hot whilst in use. It is not the socket as other appliances do not get hot. Is this a fault with the model? What could be the problem? The plug i
I have an Indesit idv65 Tumble dryer and the plug gets hot whilst in use. It is not the socket as other appliances do not get hot. Is this a fault with the model? What could be the problem? The plug is fitted so I cannot change it.
    Genius:
  • Indesit Master
  • 1,966 Answers
-The plug it self get hot...?
-If so the dryer carry lot of am through. You possibly need to get a bigger wire to replace.
Good Luck
mai
Posted on Nov 14, 2014
heatman101
  • 43501 Answers
SOURCE: i have just bought an
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Posted on Oct 10, 2010
heatman101
  • 43501 Answers
SOURCE: My indesit dryer is IDV65,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Posted on Jan 05, 2011
SOURCE: my indesit is70c tumble dryer is just blowing
The heater element is broke
Posted on Jan 10, 2011
heatman101
  • 43501 Answers
SOURCE: indesit condensor tumble dryer does not heat up
heatman101
Posted on Mar 18, 2011
machinetech7
  • 1344 Answers
SOURCE: indesit IS70C tumble dryer not heating
This caused by one of two possible things. Either you have poor air flow, or a clogged vent preventing air from flowing freely and therefor making the dryer short cycle, which in turn will take you two or three times to dry yor clothes, or the heating element has gone bad, burnt in half and is making contact with the case to provide it just enough power to barely heat. The second thing is a very rare occurance. I would turn the dryer on, find out where the air vents out to, and with the dryer running, go to where it vents and check to see if there is a strong flow of air. 9 times out of 10 that is going to be your problem. Another way to check air flow is to just pull the vent off the back and let the dryer run and see if your clothes dry faster. If you do it that way and they still take a long time to dry, then you'll probably need to replace the heating element
Posted on May 11, 2012
Indesit idv65 tumble dryer squeaking really loud
hi check drum bearing to see if worn
Jan 21, 2014 | Dryers
Dryer getting hot but not blowing hot air out
Unplug and stop using sounds like a fire hazard, try cleaning out the lint filter and replacing the exhaust hose, and make sure your homeowner policy is paid, hope this helps,
Nov 05, 2013 | Indesit Dryers
My indesit tumble dryer idv65 runs for 10 mins and then trips the electric and stops
if its an old dryer its probably the motor thermostat heating up and shutting the motor down ,replace that or even the motor
Jan 14, 2013 | Dryers
Wiring diagram for indesit tumble dryer idv65
i have put a new belt on and can not find which wires go where
Jul 19, 2012 | Dryers
How to access belt on indesit idv65 tumble dryer
Indesit tumble dryer not turning? How to replace a Indesit tumble dryer belt.
This video will show you how to replace a tumble dryer belt in your appliance
Please remember to subscribe to our YouTube channel for all appliance tutorials
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts How to Repair Home Appliances
Jun 22, 2012 | Dryers
Indesit is60v tumble dryer is not spinning although still heats, would this need a new belt?
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts from How to Repair Home Appliances
Jan 18, 2010 | Dryers
How do i replace drive belt on an indesit is60v tumble dryer please
Sep 09, 2009 | Dryers
Indesit is70 tumble dryer
Common faults -
1 The heating elements can fail (meaning open circuit)
2 There are cut-outs (T.O.C's) that might need resetting
3 The thermostats (stats) can trip out or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehave programs that can fail and circuitry although most should produce an errorcode showing you were the fault is.
5 Faultyconnections and burned wires may also be the fault.
Free tumble dryer repair videos
We have a Free full video library on appliance repair video’s
May 06, 2008 | Indesit WA 125 Front Load Washer
Problem with Indesit tumble dryer
could be a switch in there or one of these This sounds like the thermostats
ForAll Your Appliance Video Help Visit Apart4u video tutorials
see other tumbledryervideos here
Common faults -
1 The heating elements can fail(meaning open circuit)
2 There are cut-outs (T.O.C's) thatmight need resetting
3 The thermostats (stats) can tripout or burn out (meaning opencircuit)
4 Moderntumble dryers also have sensors and pcb's (Printed circuitboards) thesehaveprograms that can fail and circuitry although most should produce an errorcodeshowing you were the fault is.
5 Faultyconnections and burned wires may also bethe fault.
You-Tube video "6x3oXHgPLDg" placeholder (do not delete)
Feb 24, 2008 | Dryers
Indesit is60v dryer
a 4 THUMBS rating is appreciated for answering your FREE question. Tumble Dryer Belts Archives How to Repair Home Appliances
Nov 30, 2007 | Dryers
Indesit IDV 65 White Electric Dryer 6 kg, 16 Cycles Logo
125 people viewed this question
Top Indesit Dryers Experts
Tim Whalen
paul
paul
Are you an Indesit Dryer Expert? Answer questions, earn points and help others
