Question about Cameras
When I try to use my camera it says unfortunately the camera has stopped
I have tried resetting to factory settings but did nothing also I looked in the app remover but there is no icon for the camera . Yours Chris
    Novelist:
  • 235 Answers
You need to explain what kind of camera you have and at what point in your use it fails.
Posted on Dec 04, 2014
Bogdan
  • 198 Answers
SOURCE: Access Screen
Hello, When the camera shows this it tries to acces the lens mechanism, in terms of extending the lens and/or powering on the ccd sensor. Failure in doing so will result in an error code or simply by having the camera not showing anything else at all. Therefore the camera has a problem with the lens assembly. It's the most common problems with digital cameras. However this can only be solved in a service center because dissasembling the camera yourself will risk lens assembly damage, as they are very delicate equipment. I suggest you go to a service center, not the larger ones working for corporations, instead a smaller generic one. Ask them a price estimation before they actually repair it. Repairs may varry from a simple lens readjustment to the replacing of the whole lens assembly, this can get expensive on sony models. Please reply if you have further questions. Good luck with the fix and sorry for not being able to assist you with a quick fix.
Posted on Apr 26, 2007
FlashyBits
  • 11 Answers
SOURCE: The LCD went black, all the icons are showed, but no pictures. Any taken pictures are also black! Already reset the camera in factory settings, didn't help... anyone???
To ivowitteman
Bad news & Good News
The BAD news is that it sounds as if your CCD has gone wrong which is the part of the camera that captures the image. The CCD is made by Sony & there is alot of dodgey ones out there that Sony have said sorry about. (type "bad CCD" on a search engine & you should be able to get more info)
You say that the icons appear so the rear LCD must be working. If the playback of pictures from a card also works then it is almost certainly the CCD at fault.
The GOOD News is that your model is one of the ones that is listed as eligible for a free replacement of the CCD. You will need to contact Canon & they will advice of what to do. I have sent several cameras of different makes back to the agents for repair & all have been repaired for free. The fault you have first occurred a few years back now so there will probably be a point where the agents will say enough is enough & stop the free repairs.
Hopefully you will be eligible for the free replacement.
Hope this helps
FlashyBits
Posted on Sep 26, 2008
old marine
  • 1992 Answers
SOURCE: looking to reset to original factory settings
On the camera's menu system, under Setup2, look for the option titled "Clear Settings". When selected, you can either clear just the Custom Settings, or you can clear all camera settings, which restores it to the factory defaults.
Posted on Jan 05, 2009
SOURCE: Nikon D50 - clock and battery icons blinking
Hi
I had the same problem and rectified it by going to Nikons website , follow this link for the answer:
http://nikoneurope-en.custhelp.com/app/answers/detail/a_id/10601/p/19%2C244/c/241/kw/Clock/r_id/127673
Posted on Mar 26, 2010
  • 11967 Answers
SOURCE: i am trying to get my camera back to the factory
There may be another "reset" in the menu that will do what you want. Search for it.
Posted on Jun 22, 2010
When I try to use my camera on my CnM 9.7 touchpad it tells me unfortunately the camera has stopped?
Try to find and install different firmware version till the camera start to work.Tipical problem with some model
Nov 13, 2014 | Computers & Internet
My ZEKI android tablet keeps saying that unfortunately system UI has stopped working what do i do?
You can try pulling the battery then reinstall it and restart the unit. If that doesn't clear the problem go to settings, and then applications and look for UI and clear the cache and data. If that fails you can try to do a factory reset.
Nov 09, 2014 | Shopnbc Zeki 7" Multi-TouchTablet
Camera turns on, LCD screen works, lens goes in and out when zooming and I can change all other settings. When I try to take a picture the camera beeps and nothing happens.
It looks that your rechargeable battery inside your camera is about to die. Try to connect your camera to your laptop with USB cable or with the one that comes with the camera and see if camera is working properly. If not - replace the battery.
Nov 09, 2014 | Cameras
Hi, we have a Siemens IQ300 Condenser Tumble Dryer which we have recently inherited. Unfortunately it worked for a wek before just stopping. The lights are on and everything looks normal but when you
Check to see if it is properly grounded and that the incoming voltage is correct (120V or 240V) for the wiring config you have.on the dryer as it sits. Also try unplugging and wait a minute or so before plugging back in. This will sometimes reset dryer electrical components to factory settings.
Dec 07, 2012 | Dryers
Flash stopped working even when it pops up
Try going into the settings, look for something called "factory settings /factory reset) This will not erase the pictures on your memory card. But it will set up the camera the way it is soposed to be. If this does not work, the flash is propably burned out. Best of Luck !
Mar 08, 2011 | Sony Cyber-shot® DSC-H20 Digital Camera
Before you give up on the camera:
There are many setting that can affect whether the flash works or not.
You may have inadvertently set something that is stopping the flash from working.
Get out your User Manuals and use the index at the back of the book.
Look for something about "Resetting the camera".
This will reset the camera to factory specifications.
Then see if the flash works.
If that does not work ... recharge the battery and try again.
If that does not work, the flash is likely dead
Jan 05, 2010 | Canon PowerShot A590 IS Digital Camera
Have you tried to reset the camera to its factory defaults to see if it is a setting that is causing the flash not to fire? To reset the camera go to the menu left arrow to reset - highlight yes and press ok. This will set the camera back to factory settings. See if the flash fires now. If it does then, good. If not, then it is a repair issue with the flash assembly internally in the camera.
Mar 23, 2009 | Olympus FE-210 Digital Camera
Nikon D70 - indoor flash problems
Unfortunately, you may have a faulty flash pcb (printed circuit board) The part is around 50$ plus installation 200+ total repair cost. A work around would be to use an external flash unit from the hot shoe
Dec 26, 2007 | Nikon D70s Digital Camera
Cameras Logo
24 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
