Question about Dryers
How to turn on a dryer if the part where u insert the quarters is took in off completely
  • 34 Answers
If you mean the whole top part lock box and all forget it that has the timer in it
If you just mean the coin slot then you might be able to access the timer and see timer and advance it
Posted on Nov 26, 2014
Change headlight bulb on pontiac g6
Open the hood and the connected that holds the bulb twists out with a quarter turn anti-clockwise turn. Remove the bulb, insert the new one without touching the glass of the new one. Insert and turn a quarter turn clockwise.
Dec 25, 2015 | 2008 Pontiac G6
How to change a headlight
Dec 25, 2015 | Pontiac G6 Cars & Trucks
Dryer has Heat but NO AIR
Many of these have a belt driven blower wheel, could be a broken belt or it came off, There was also a bulliten out on several models where the blower wheel would come loose from the drive shaft, the fix was to re attach using a medium body thread lock compound so it would not unscrew again.
Sep 25, 2012 | Maytag Bravos 7.0 Cu. Ft. Electric Dryer
How do I remove the back panel of my Kenmore 70 series dryer?
First you need to determine if your dryers blower housing and other components are located in the rear of the dryer or underneath the dryer. The quickest and most simple way to do this is to look at the front of the dryer and see if it is one complete front or two pieces. There will be a small gap completly across the front about a quarter way up if its two. If its two pieces then your work is going to be up front. You remove the lower kickplate with a flat screw driver and pressing the clips, one on each side in the groove. If its a solid front then you'll need a 1/4 " driver or drill with 1/4" socket, adapter, etc. From the rear of the dryer, there are about nine 1/4 inch screws you take off to access the area your looking for. Hope this helps, good luck.
Apr 26, 2012 | Kenmore Dryers
I have a roper dryer red4440sq0 that will not turn on.. I have checked all power its going to the dryer and hitting what it needs to hit and suggestions?
I bought this dryer 2 years ago. After exactly 1 year, the heat stopped working completely. It turned out to be the Thermal Cutoff device ($20). Then, just last week, the thing stopped working completely. It took me all of 10 minutes to determine that it was the Thermal Fuse (http://www.appliancepartspros.com/part_details.aspx?part_id=3132867), just by using my continuity detector on the two terminals. I unhooked the terminal wires, stuck them together, and the dryer turned on fine. They count on people buying new dryers completely whenever one of these dinky little parts made by child laborers in Asia fail. The fuse is $10 at the site I just linked.
Nov 09, 2009 | Dryers
Signal light bulb change/who and where
  1. From under front wheelhouse, remove access cover behind park and turn signal lamp
  2. Through access hole in wheelhouse, rotate park and turn signal socket counterclockwise one quarter turn.
    1. Pull socket from back of lamp.
    2. Pull bulb from socket. INSTALLATION
      1. Align key on bulb base to groove in socket and insert bulb into socket.
      2. Through access hole in wheelhouse, insert socket into back of lamp.
      3. Rotate park and turn signal socket clockwise one quarter turn.
      4. Install access cover and verify lamp operation.
Hope this helps with your prob
Mar 27, 2009 | 1998 Plymouth Voyager
Hi, I have Kenmore electric dryer 27"wide. I was tring to clean the lint screen. I saw some lint in the hole too. so, to remove that I inserted a thin long brush, but it went inside it. I tried to pick...
I think I can help , I have done this many times , you will need a quarter inch nut driver or a quarter inch socket and a phillips screwdriver , the dryer must be disconnected and you have to get behind it , there are 4-8 screws holding the back lower panel on not the smaller control panel but the large back panel , after removing that you will see the rectangle lint screen duct/housing on your left side , there are 3-4 screws at the bottom of the duct that need removed there , and at the top where the sreen is inserted there are 2 phillips screws that you need to remove. after all screws are out duct should be loose and you can move it out of the way freely and you should see the fan behind it , remove unwanted items and re-assemble. Let me know if you have any more questions , good luck o and dont use the dryer you could do major damage.
Dec 30, 2008 | Dryers
Maytag MLG23PD Gas Commercial Dryer
605 5 quarters to start 712 12 minutes per quarter if yu want 1 quarter to start dryer change to 601. if yu want dry time to be 8 minutes change to 708 press whites and colors to select value and then press permanent press to go to next code.
Apr 19, 2008 | Maytag MLG23PD Gas Commercial Dryer
Kenmore HE2 Dryer makes three beeps but wont start
What happens is that the door switch gets turned inside. I just took mine apart because of the same problems listed. The switch has a tab inside that has to make contact with the internal switch. I pulled mine apart and turned it so it made contact...put it back together and it works fine now. After doing all that it seems like you could turn the swith from the outside a quarter turn with a pair of pliers and accomplish the same thing.
Mar 22, 2008 | Kenmore Elite HE4 Electric Dryer
Dryers Logo
Top Dryers Experts
