Question about Apex Digital Apex ABS100 - Rear Main Seal Set
How to replace rear main seal on 2002 Hyundai sonata 2.7L
Remove and replace
    Top Expert:
  • Apex Digital Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Disassemble procedure to many popular brand TVs and other devices are given in detail with illustrations.
Electro help
Posted on Nov 15, 2014
How do I remove and replace the trunk lock on my Sonata
hi, for that you need an operator manual for your product which you can get it from the reliable store and here's the link from where you can buy it.
http://www.reliable-store.com/products/2002-hyundai-sonata-workshop-repair-service-manual-pdf-download
Nov 21, 2015 | Hyundai Motor 2002 Sonata
Install crankshaft kit on 2004 hyundai sonata 6 cylinder 2.7l engine
Really need more information...It sounds like they didn't give you a complete gasket kit...You will have to remove and re-install other components just to be able to see the crank shaft....You need the front and rear oil seal for the crank..,Oil pan gasket..,exhaust will have to be removed also...etc.......NEED MORE INFO..
Jan 24, 2015 | Hyundai Motor 2004 Sonata
2002 Hyundai Sonata "battery" light
The Alternator may not be charging at the proper level. If the car is running while you're trying to open the sunroof or turn on the defroster, then the battery light has nothing to do with those and they are separate problems. Have an ASE Certified mechanic check the charging system.
Apr 21, 2010 | Hyundai Motor 2002 Sonata
How to change spark plugs in a 2.7 v6 hyundai sonata 2002
the rear plugs can only be accessed by removing the fuel/air intake plenum. If you're not familiar with the procedure, you might want to pay a mechanic to do it right.
Aug 07, 2009 | Hyundai Motor 2002 Sonata
Does the 2002 hyundai sonata have front shocks or struts?
The 2002 Hyundai Sonata has struts on the front and rear.
Jun 27, 2009 | Hyundai Motor 2002 Sonata
Headlight bulb replacement for 2002 Hyundai
http://www.autozone.com/autozone/repairinfo/common/repairInfoMain.jsp?targetPage=productsHowToInspect&leftNavPage=productsHowTo&pageId=%090900c15280213e7e&subtitle=replace
Apr 23, 2009 | Hyundai Motor 2002 Sonata
HOW MUCH TO PAY FOR TIMING BELT CHANGE-HYUNDAI SONATA 2002
Hi if your made of money then you can go to the main dealer but if your local mechanic is reputable then he should be alot cheaper for the same job, also the timing belt is not usually covered under warrenty, but to comply with the warranty you must keep your car serviced and replacing the timing belt is part of a main service, Hope this helps
Dec 11, 2008 | Hyundai Motor 2002 Sonata
NEED TO REMOVE REAR ROTOR
Take off the wheel, remove the brake caliper (2 bolts on the back), then the rotor just slides off, the wheel studs are part of the hub assembly not the rotor.
Nov 21, 2008 | Hyundai Motor 2002 Sonata
Replacing rear wheel bearings on 1999 hyundai sonata
  1. for drum brakes with sealed hub(all one piece) remove lug nuts and wheel.
  2. spray penetrating oil around studs if there is a big phillips head screw visible remove it with impact driver/if not use big ballpeen hammer ,tap on flat of drum near studs(becareful not to hit them) until drum loosens(your creating a shockwave to loosen rust)
  3. once drum is off there are 4-bolts coming in from behind backing plate, remove them then hub should be able to be removed w/a little persuation from hammer.
with out sealed hub ,
  1. remove wheel
  2. remove dust cap,cotterpin,star washer(if equipped) do not re use cotter pin
  3. remove nut then washer, wiggle brake drum and front bearing will come out.
  4. put nut on shaft tighten 2-3 turns grab drum by sides and pull towards you this should remove drum leaving inner bearing/seal on shaft
  5. to replace reverse procedure making sure to pack new bearings w/grease(take drum and use long punch to remove bearing races, use race/seal installer to install new races
with disk brakes
  1. remove wheel
  2. remove caliper/bracket
  3. remove rotor
  4. remove 4-bolts from behind,tap old hub out
  5. reverse procedure
Jul 19, 2008 | 1999 Hyundai Sonata
Apex Digital Apex ABS100 - Rear Main Seal Set Logo
53 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
