Question about Dell OptiPlex Computers & Internet
Blue screen errore??
When i on the pc it shows blue screen error sometime
  • Ganesan Chandraiah
    Ganesan Chandraiah Nov 13, 2014
    Hi Danish , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Please include the error message with the error code. Your operating system and your hardware informations
  • Official Brand Answer
  • 560 Answers
Danish
You will need post what the blue screen error is in order to get people to help resolve the issue.
Thank You,
Dell-Jesse L
Dell Social Media and Communities
Posted on Nov 13, 2014
SOURCE: blue screen error
that only happens if your hardrive goes to hell or you have a lot of viruses,if it gets a blue screen while booting, your harddrive may have gone bad, or forgotten what file system it had, then you have to format the drive and reinstall from a cd, and try blowing the dust the cooler on the laptop out also.
Posted on Jan 02, 2009
  • 106 Answers
SOURCE: Blue error screen and system shutdown on Dell Dimension C521
check your RAM. maybe your RAM is Damaged or lose in connection..
Posted on Feb 13, 2009
rockitman187
  • 2559 Answers
SOURCE: Blue Screen with error 0x000000ED
This behavior can occur if either of the following conditions is true:
  • Your computer uses an Ultra Direct Memory Access (UDMA) hard disk controller, and the following conditions are true:
    • You use a standard 40-wire connector cable to connect the UDMA drive to the controller instead of the required 80-wire, 40-pin cable.
    • The basic input/output system (BIOS) settings are configured to force the faster UDMA modes.
  • The file system is damaged and cannot be mounted.
The purpose of this error message is to prevent the following two things:
  • Potential data loss caused by using an incorrect IDE cable for the faster UDMA modes. An IDE cable is a kind of cable used to connect storage devices, such as hard disks, inside a computer.
  • Continued access to a drive on which the file system is damaged
Some things that you should know before you try this solution loadTOCNode(4, 'resolution');
  • If the file system is damaged, you can use chkdsk /r command to repair the volume. However, if you use the chkdsk /r command, you may lose some data.
  • You will need the Windows startup disks or the Windows installation disk. If you do not have them, contact the computer manufacturer for help in obtaining the disks.
  • You will need the administrator password to complete the steps.
To repair the volume, follow these steps:
  1. Start your computer by inserting the Windows startup disks or the Windows installation disk if your computer can start from the CD drive.
  2. When the Welcome to Setup screen appears, press R to select the repair option.
  3. If you have a dual-boot or multiple-boot computer, select the Windows installation that you want to access from the Recovery Console.
  4. Type the administrator password when you are prompted to do this.
    Note If no administrator password exists, press ENTER.
  5. At the command prompt, on the drive where Windows is installed, type chkdsk /r, and then press ENTER.
  6. At the command prompt, type exit, and then press ENTER to restart your computer.
  7. After you repair the volume, check your hardware to isolate the cause of the file system damage.
If this procedure does not work, repeat it, but type fixboot instead of chkdsk /r in step 5.
Note:
  • If your UDMA hard disk is connected to the controller with a 40-wire UDMA cable, replace the cable with an 80-wire cable.
  • In the BIOS settings for your computer, load the 'Fail-Safe' default settings, and then reactivate the most frequently used options, such as USB Support.
  • Posted on Jun 03, 2009
    SOURCE: dell xps crashes and i get a blue screen error
    Please use the troubleshooting data at link below, work through the steps and I am sure you will remedy you problem. http://support.microsoft.com/kb/322205
    Posted on Mar 08, 2010
    • 707 Answers
    SOURCE: i turned on my pc
    First try restarting in Safe mode. In the Advanced Options menu, select the Last Known
    Good Configuration option.
    If that doesn't work and you have the OS cd (ex: XP, Vista) then pop it in and go to the recovery console.
    run
    chkdsk /r (let it finish...do not interrupt it.
    Issue command... FIXBOOT
    Issue comand .... FIXMBR
    If you are still having problems you may contact me at doctorphibes53@yahoo.com and we will try to work it out.
    Good luck.
    If this helps you resolve your problem, please
    consider giving a good rating and a quick thanks
    or good job.It will help me as well Thank you.
    Posted on Oct 23, 2010
    Tip
    Blue Screen of Death - How Do I Fix It
    Those who are using Windows operating system are aware about the Blue Screen of Death (BSOD) and may be they have faced it in their PCs. This is a common error which usually occurred when something wrong with PC in hardware and software. Sometime it occurred when some major problem has been created in PC but it also come when a minor corruption occurred in it. So, the most important thing to recover the desktop screen is to detect the problem.<br /><br />Blue Screen of Death has not proper technical guideline to solve but it has various way to resolve - depends upon condition or error. Sometime it automatically resolves by restarting the PC but sometime it take great effort and time to resolve. In short there is no simple answer of "how the blue screen of death can be resolved?"<br /><br />To get the desktop screen and resolve the BSOD, user has to recognize the error. This error detection can only be done manually because both parts - hardware and software, are checked one by one. At the blue screen the error is displayed but this display shows the error in computer codes which are not easy to understand by the user. But these codes help to diagnose the error. So, once you get the BSOD error write down it on a paper.<br /><br />Unfortunately, if you couldn't get success to resolve the BSOD by rebooting the machine, then you have to do some effort for resolving the problem. It is not easy to concise the instruction of all resolving method that's why there are some hints to resolve but if you cannot resolve the blue screen error through the following guideline, then write the error code on search engine and get method for resolving through Internet.<br /><br />The first method of diagnosis the problem is to check the windows at safe mode. If you couldn't get success to reach the desktop screen in safe mode that's means there must be a hardware problem. One of your computer physical devices has been corrupted or destroyed. To resolve the screen in this condition check your devices one by one in other PC.<br /><br />If you get desktop screen in safe mode, so you're PC has software or driver problem. Once you reach at the desktop screen, scan your PC through anti-virus immediately. The anti-virus will detect the software if there will be anything wrong. If anti-virus detects any software which is virus infected, uninstall and delete the software immediately from your computer, then re-install the windows because your PC have get the virus.<br /><br />Sometime both of the above method has been failed and computer reached at the desktop screen in safe mode and anti-virus also doesn't find any infected file. This is the condition of driver failure. You have to re-install the driver to resolve the blue screen of death.<br /><br />
    on Apr 19, 2011 | Computers & Internet
    Well, my computer sometimes starts up normally but sometimes when im in the middle of what im doing it turns to a black backround and a blue box shows in the center of the screen it says something about...
    This is Probably the BSOD i.e. Blue screen of death error...
    1. Uninstall any programs that you had installed recently. Sometimes, there is a conflict in drivers installed on your computer that causes the blue screen error to pop up. In most cases, this does not happen, but if it does, Windows provides you a roll back feature where you can bring your PC's operating system back to its original functioning state.
    2. Random Access Memory is faulty. When the Random Access Memory is faulty, the PC stops functioning everytime that area of the RAM is accessed by the CPU. This causes your PC to halt almost at Random. A simple process of elminination is just to remove 1 stick of RAM and see if the problem goes away. If it does, your PC is fixed!
    3. Registry Errors Over time, the registry of your windows gets cluttered with tons of information. If you experience slow down in your PC during boot up times, opening up of new folders, surfing windows, its likely your registry has a ton of information it needs to wade through. That being the case, its a good idea to get a good registry cleaner and improve the performance speed of your PC. Errors fixed in your registry can also prevent Blue screen error crashes.
    Aug 10, 2011 | Computers & Internet
    How to solve blue screen problem
    I think it maybe Virus Or hardware ! In hardware, memory Or Hard disk is not good , it always show blue screen . But it sometime shows Os error . i think u must check out HDD for Virus .
    Jun 07, 2011 | Computers & Internet
    Sometimes,,when I open my pc,,there is a blue screen appeared after the windows xp logo and it restarts again after a few seconds..you cannot read the error because it restart fast
    Follow the steps below to capture the blue screen error code.
    1. Turn the computer on.
    2. Keep tapping F8.
    3. On the Advance Boot Menu, use the arrow keys to select Disable Automatic Restart on System Failure.
    4. Press Enter.
    The next time that the blue screen shows up, it will be paused and you can get the error code. Let us know what type of error code you are getting and we will be more than happy to help you out.
    Thank you for visiting FixYa!
    Apr 25, 2011 | Computers & Internet
    Blue screen error message (Crash Dump)
    kernell has over run the memory....
    some corrupt registries may also cause this issue...
    u can try to run a registry cleaner (Tuneup Utilitis or Registry defrag etc can do the job...search in google)
    else
    do a clean install of OS after data backup
    Dec 14, 2009 | Computers & Internet
    Qosmio G35-AV600 boot problems
    You will have to reinstall both its BIOS and operating system, only that can properly solve the problem. I my solution was helpful, Kindly accept it.
    Thank You, Arjun
    Apr 01, 2009 | Toshiba Qosmio G35-AV600 Notebook
    I have got a blue screen error in my averatec 2100
    if it is blue screen error so if have xp cd insert int the cd drive and restart the computer and go the boot order by pressing the del key or which they have given and change it cd rom has first order and reinstall the fresh copy of xp
    Feb 25, 2009 | Computers & Internet
    Hardware problem
    Your memory is broken it's need to be replaced!
    Jun 24, 2008 | Compaq Presario Notebook
    Computers & Internet Logo
    71 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
