Question about Cell Phones
When someone says then need to create a solution using java what do they mean?
    Scholar:
    New Friend:
  • 42 Answers
Java is a programming software used in many areas like websites, cell phones apps and many more. Java scripts used to desigh how the web sites interact with the viewers. Java also used to create apps used in the cell phones. These apps can be designed to solve certain problems.So when someone says they need to create a solution using Java, they might refer to the fact that they need to create a new app or redesign how an app should respond to the commands.
Posted on Nov 13, 2014
How can i corredt this error ??
report to mojang and play the pe version for a while. or you can delete your minecraft file and download it again
May 23, 2014 | Kaltner.net Minecraft Mobile Admin
How to downloaded install jad games
i just reset my phone nokia 5200, After that cant add settings,
May 15, 2010 | LG KG800 Cellular Phone
I want ot link my inventory database to another pc
Create user account for second system in Sql
If u want to get data by code means u need to create
connection to database by using jdbc connection string .
then write a query to acces data.
create statement
pass query to that statement
run query
Statement statement=con.createstatement();
statement.executequery(querystring);
Oct 15, 2009 | Microsoft Designing ASP.NET Applications...
I want to execute java command through php
1. Copy JavaBridge.jar to the current directory.
Add JavaBridge.jar to your Java application. Edit the manifest MANIFEST.MF
2. Recompile your Java application.
3. Run your Java application. This time your application doesn't display anything and doesn't return.
4. Create a PHP test script.
5. Open a new command shell and run your test script.
6. Your PHP script has called the method hello(), which should display a message dialog.
7. Note that the above code doesn't create a application-modal dialog. The communication can be traced by starting your application with the options: java -Dphp.java.bridge.default_log_file= -Dphp.java.bridge.default_log_level=4 -jar HelloWorld.jar
for more read INSTALL.STANDALONE documentation
How to execute Java Programs using console command prompt
May 22, 2017 | The PHP Group PHP
How to creat a report with java? i need Java Enterprises latest tool. how download? how to creat a exe file from java?
If you would like to create a report with java there are a couple of things that you could focus on using. You could either go for Crystal Reports, or even Jasper Reports or any other reporting kit for java. To download the Java Enterprises latest tool.. I need clarification with this one. Do you mean J2EE SDKs? if you do just go to the sun microsystems website and download it from there. To create an exe file... jars are normally the ones you get when you compile java codes. The best thing to do here is to create batch files to run your compiled java applications.
Mar 24, 2009 | Sun Computers & Internet
How can i connect the data base during my project
That seems fine.
I cant assume your level of confidence in programming, however, following are some simple steps you can follow to achieve (for complex implementations, much more time and details will be needed, i can help u with them as well)
1. Create a database in Access ( i assume u r using Access 2003)
2. Create a System DSN (if aren't clear, how to create then goto administrative tools under control panel and you'll find Data Sources (ODBC), here u need to create System level DSN for Access driver (may be Jet 4.0+)
3. In java, you need to import java core libraries for sql (javax.sql package specially)
4. you are almost done, just google for database code in java, simple code will be around 5-10 lines (just for your reference, search with these keywords, ClassName(""), jdbc:odbc:YourDSN)
5. Open a connection using Connection object
6. Fetch the records (select query) using Recordset object
7. You're done.
thanks
Kuldeep
Mar 13, 2009 | HP Computers & Internet
How to play audio clip in java
  • Create an AudioClip object
  • Load .au sound file into AudioClip
  • Play sounds once or loop continuously
  • Stop playback
Here's how the code for these steps looks:
import java.applet.*;
AudioClip ac = getAudioClip(getCodeBase(), soundFile);
ac.play(); //play once
ac.stop(); //stop playing
ac.loop(); //play continuously
It would seem logical to use this same code to play audio clips in a Java application. Unfortunately, if you do that you will get errors from the compiler. Why? Because the AudioClip object and the getAudioClip() method are part of the java.applet package -- and are not part of applications. The good news is we can dive down and make things work ourselves.
The trick to solving this problem is to use some undocumented features that are provided by Sun in its JDK. Taking a peek inside the classes.zip file from the Sun JDK (using any of the various zipfile utilities), we find not only the standard Java packages such as java.applet but also sun.audio. (These are in the directory sun/audio.)
The sun.audio package contains everything we need to be able to play audio clips! Here's the code:
import sun.audio.*; //import the sun.audio package
import java.io.*;
//** add this into your application code as appropriate
// Open an input stream to the audio file.
InputStream in = new FileInputStream(Filename);
// Create an AudioStream object from the input stream.
AudioStream as = new AudioStream(in);
// Use the static class member "player" from class AudioPlayer to play
// clip.
AudioPlayer.player.start(as);
// Similarly, to stop the audio.
AudioPlayer.player.stop(as);
To use a URL as the audio stream source, substitute the following for the input stream and audio stream setup:
AudioStream as = new AudioStream (url.openStream());
Playing the audio stream continuously adds a bit more complexity:
// Create audio stream as discussed previously.
// Create AudioData source.
AudioData data = as.getData();
// Create ContinuousAudioDataStream.
ContinuousAudioDataStream cas = new ContinuousAudioDataStream (data);
// Play audio.
AudioPlayer.player.play (cas);
AudioPlayer.player.stop (cas);
Jan 22, 2009 | Computers & Internet
Creating biodata form in java script
i want to create a biodata for every citizen and non-citizens in nigeria. how can i make it a dream come true.
Sep 08, 2008 | Computers & Internet
To create window using java codes
What you need is FrameDemo by Java which allows you to create Frames (or windows) using Java. Get it here:
http://java.sun.com/docs/books/tutorial/uiswing/components/frame.html
May 07, 2008 | Computers & Internet
Java codes on calculator
when this is type of messeage u shown...that means u make some wron url..first try to correct ur spealing mistake than u see.
Mar 10, 2008 | Computers & Internet
Cell Phones Logo
67 people viewed this question
Top Cell Phones Experts
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
