Why tv shuts off by itself?
When I power it up it clicks some lights come on inside the unit, the vizio light turns white. Then the unit clicks and shuts off. The screen does turn a dark gray color before shutting off>
  • Ronald Misencik
    Ronald Misencik Nov 13, 2014
    If you mean the power plug from the wall outlet, L just tried that and it did not help! I have no idea as to what the cat5 network cable is could you explain?
  • 483 Answers
Dear User,
People who have faced such problems have tried sticking th epower plug (Going into the TV) a little harder and the thing never went off again.
If this is not the case, then it could be the cat5 network cable. Try keeping it out and observe.
Let us know further
Regards,
Sid
Posted on Nov 13, 2014
  • 3 Answers
SOURCE: only vizio light on
why should i tell you (fixYa) how i fixed the problem for free? You wanted to charge me for your info so i think it's only fair that i charge you for mines. I did figure out and solved the problem.
Posted on Dec 31, 2008
  • 92 Answers
SOURCE: vizio 47" lcd no picture no sound has power
this could be one of two problem. first, check if you have back light. If you do then the problem is with the M/B. Second, if you don't have back light then the inverter is bad and needs to be replace.
Posted on May 20, 2009
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
Raditronic
  • 196 Answers
SOURCE: plugged in orange light turno on vizio light is white no picture
possibly is the main board.
Posted on Apr 30, 2010
SOURCE: Vizio shuts itself off
I have found that turning off the power for awhile will work as a temp fix for a couple of days and then just repeat the process.
Posted on May 28, 2010
Vizio vm190xvt problem turning on - My TV turns on for an instant and turns itself off. I get the start up screen but then it just shuts down.
The problem could be in the lighting circuit or in the control circuit. The only way to tell is to chase signals inside the unit. Due to the low value of this unit, unless you are experimenting for a hobby with it, the unit is not highly economical to repair. New monitors or TV's this size can be found well under $100, and used units in the $20 to $50 range.
Jul 04, 2017 | Vizio Televison & Video
Vizio e322ar won't turn on
My Vizio E322AR White Vizio Light comes on when plugged in, then slowly fades to "Off". I unplugged and replugged - same. I held down the power botton on the side, and plugged in... same. Vizio light comes on (White) and over 5 seconds or so... fades out to nothing.
Remote doesn't do anything, buttons on the side don't do anything.
Going to pull the back off and look for bad Capacitors, and test fuzes for continuity. Wish me luck ... will report back later with results.
Feb 21, 2014 | Vizio E322ar
My Vizio VX37L HDTV won't turn on. Was watching it one day & it turned off by itself. Replaced power supply with new one with no luck. Orange light comes on but will not turn white.
reset the tv with the tv off, but plugged in hold down the soarce botton on the tv for 5 seconds it should click on and work. if not then there may be curcuit board issues. i found the same tv on the side of the road as somewone was throwing it out, it was leaning aganst their trash can. i brought it home. plugged it in and it went on and inediatly went to the orange vizio light. i rest it and it's been perfect ever since is my comoute monitor now...good luck i hope that fixes it for you..
Nov 25, 2012 | Vizio L37 Television
I have a vizio 42 plasma model #vp422hdtv10a when i try to turn on the unit it makes 2 click sound like it is turning on but nothing happen. i open up the unit to look for popped capacitors but i see non...
I am having the same problem with my 42" vizio tv. When plugged in the standby light is on and when turned on the light switches from orange to white, however there is no sound and no picture. I am hoping to find what is wrong with it so i can get it fixed. Or atleast by the correct parts! I have only had my tv about 2 years
Aug 28, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
TV turns off by itself or volume goes out usually within the first 15 minutes. The volume will go off and then I'll try to change stations and tv is black, I have to turn off, wait till the VIZIO light...
your Audio output chip has gone south and shorts out after warm up The unit will shut off to protect itself you need a tech to replace it try Pinicle Service solutions in Haverhill ma
Nov 02, 2009 | Vizio GV46L 46 in. LCD Television
Power
The reason the tv is turning itself off, because most TVs have a "Protection Mode" that turns the unit off when it detects a failed part inside the tv.
The most likely the tv has a power supply related problem. The most common thing to go out is the circuit board that supply power to the screen. Commonly called a Backlight Inverter Board.
I can't say it's 100% the problem because I can't actually look at the tv over the internet.
Being that the TV is under a year old, it should be still under manufacture warranty. Last thing you want do is void the warranty by opening up the TV. Here's some info to get you started on the warranty:
http://www.vizio.com/support.aspx?id=1588
If it not under warranty and If you have some electronic experience, you can purchase a Service Manual over the internet and diagnose the source of the problem and fix it. The Service Manual will give you circuit diagrams, test points, and part# lists. Usually, cost under $20.
I hope I shed some light on the subject for you.
Jun 28, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
No picture but sound
do any lights come on with the TV?, like white vizio or orange vizio light. sounds like a problem with the power board. some vizio parts have lifetime warranties so contact vizio support and report your problem. if it is covered the service call is free. there is a green led light on the power board that should come on, if it is not on, you may have a bad power board. to see this light on the power board, turn off the lights in the room and view the tv from the back cover, power board is 3/4 way toward top in the middle of the tv
Mar 26, 2009 | Vizio VX32LHDTV10A 32 in. LCD HDTV
Televison & Video Logo
98 people viewed this question
Top Televison & Video Experts
