Polaroid flat screen tv freezes once I change channel or select EPG. Has to then be unplugged and then plugged in again in order to turn tv on again. Tv then comes on the channel it was on originally before Problem is tv is stuck on only one channel.
  • 1,680 Answers
Try firmware update on the Polaroid TV for appropriate model
Posted on Dec 18, 2014
2 Suggested Answers
  • 88 Answers
SOURCE: tv screen went blank
sound like the inverter circuit board problem. check & replace back same part# inverter circuit board. hopefully could help!!
Posted on May 17, 2010
Hi my polaroid LCD flat screen TV is behaving strange. I've had it almost a year and problems have started the last few days. Basically when I change the channel the screen will go black and freeze. The...
would need the model number but it sounds like a software fault, this can be the control switch chip, does it do this on source to, some times can be fixed with the tv board being clean'd and the dust removed from the board. if there is a lot of dust build up it can cause problems with the micro chips connections you get a statick build up from the dust and make the board do strange thigs
May 09, 2014 | Televison & Video
Cello TV keeps freezing
I am surprised you have just bought a CRT TV. You will need to get back to the maker or supplier
Feb 01, 2014 | Televison & Video
Change channel, lose picture. power off/on, picture appears
switched HDMI plug from HDMI1 to HDMI2 port and that solved the problem
Oct 11, 2009 | Polaroid Televison & Video
The digital tuner on my Olevia LT37HVS LCD TV freezes sometimes. When it does, you can't change channels, adjust the volume or even shut it off short of unplugging it. All of the other A/V inputs work just...
Tune the tv to a channel that is just blue screen. Then turn the tv off and unplug for at least 30 sec. Then plug the tv back in and turn it on. Then leave the tv on the blank screen channel go into the menu and do auto cable channel search. After the search is complete try all channels. This worked for me. My tv will not scan if the tv is on a channel that comes in. GOOD LUCK these tv's are junk .
Sep 21, 2009 | Televison & Video
My TV freezes instantly when it turns on.
Take the tv aparts cleans all parts and disconnect an reconnect everythings.It will work,or u might also need to replace the Video ic inverter board.
Aug 23, 2009 | Televison & Video
47" Vizio Flat screen HD LCD freezes up and remote will not work.
could it be Ch 9's digital signal is not broadcasting right? what is your refresh rate on your tv? 60 or 120hz? if its 120hz, then its more then likely the digital broadcast, if its 60hz I think its your tv can't keep up with their signal that may be at 120hz. Make since??
Jun 16, 2009 | Vizio VO47L 47 in. LCD TV
TV freezes when switching to a digital channel
The problem your describing can be contributed to your cable box. Depending on your cable company there are times when the box has trouble translating the signal to the tv. You tv is operating normally. Suggest to the cable company to switch your box.
Dec 05, 2008 | LG 32LG40 32 in. LCD HDTV
How to use EPG
EPG or Electronic Programme Guide is the on-screen version of a tv guide for digital tv. The remote control usually has a dedicated button for the display of the EPG.
The information displayed is often incomplete and some digital boxes or tv sets perform better than others though in theory it needs no setting up. Once the box has searched and made a channel list the programme guide will be available.
Nov 17, 2017 | Pinnacle Televison & Video
Polaroid flm-3232 locked or in sleep mode? Is that possible
Hi there!
I work in an electronics store and I've come across this problem before. The only solution that has ever worked for the people who call in or come to see us is pretty simple. You need to unplug your PC from the TV (if you haven't already done so), turn the TV on by using the "channel +" button. Some TV's when turned off at the wall will not turn back on again unless you press the channel + button. Give it a go and see what happens. Let me know if you need more help.
Also, it sounds like your laptop may not have been supported due to the wrong resolution being outputted through your VGA connection. When you get your TV turned on again I'll see if I can help you get them to work together,
Cheers and good luck!
Abby.
Oct 19, 2008 | Polaroid FLM-3232 Television
Televison & Video Logo
63 people viewed this question
Top Televison & Video Experts
