I have 3 level one 1001 APs, the leds for power lights, the led for Wireless lights but the lead for Ethernet does not light. What could be the problem and how can i solve it ?
    Sergeant:
  • 320 Answers
The ethernet lights will only come on when a computer is plugged into them using a hard wired ethernet cable.
The cable must be a straight through type (Most common) and the computer may need to be powered on (Some cards have Wake on lan which allows the network card to work even with the computer off)
Hope this helps.
Posted on Nov 18, 2014
Testimonial: "Hi, thanks but i think it,s more of that. I have realised that the circuit board for the ethernet port heats up within seconds fter being swithed on. Help please"
jagalbraith
  • 19 Answers
SOURCE: wireless router not connecting
Be sure that your Modem plugs into the WAN port on the router.
1. Unplug your cable/dsl modem power
2. Unplug your Router power
3. Plug in your modem power ... wait for it to come completely up.
4. Plug in your WRT54G Router and wait for it to come up.
Press the reset button on the back of the router for 45 seconds while it is powered on. This will do a factory reset. Wait for it to come up. Then unplug it. Wait 30 seconds and plug it back in. Let it come all the way up.
Plug a PC into one of the switch ports on the router.
Now do an ipconfig /release and ipconfig /refresh in the command prompt of your PC to get an IP address from your Router.
Now you should be able to ping 192.168.0.1 and you should be able to get into the the configuration utility by putting http://192.168.0.1 in a browser. The username should be blank and the password will most likely be admin (all lower case).
Be sure to lock down your wireless SSID so neighbors and people passing by are unable to connect to your access point and do bad things on your network.
Posted on Jun 11, 2008
marked
  • 6487 Answers
SOURCE: power led solid red, internet led solid green
This is a sin of a bad unit already, first thin that you can try here is to reset the router by pressing the reset button of the device for 30 seconds , but after that and still the same light better contact your device manufacturer...
Posted on Sep 15, 2009
  • 137 Answers
SOURCE: The STATUS led on my D-Link DI 524 wireless router
reset you router on factory set and then you can see the satus of lights.
Posted on Apr 04, 2010
puertobori
  • 7733 Answers
SOURCE: power light on linksys wrt54g is yellow and there
try Lynksys Support and Services
Posted on Oct 29, 2010
  • 425 Answers
SOURCE: My ZyXEL p660 router after
You will find ADMINISTRATION tab in the upper right hand corner.
click on the administration tab. just below the administration tab you will find firmware upgrade sub tab. Click on Firmware upgrade.
Now on this window you will find browse option. click on the browse button and select the firmware file that you have downloaded on the computer. after selecting the proper file click Upgrade. The upgrade process will start.
It may take 2 to 5 minutes.
once you upgrade the firmware of the router, unplug the power cable of the router , wait for 5 seconds and plug it back in.
For Netgear router
# Click Maintenance > Router Upgrade
# Click Browse and find the file you just downloaded.
# Click Upload. Do not interrupt the upgrade while the router does this step.
For Belkin router
Open a web browser on the computer.
In the address bar of the web browser, type http://192.168.2.1 and press Enter on your keyboard.
Click Login in the upper right-hand corner of the page.
The router does not ship with a password, so just click Submit.
Click on "Firmware Update" toward the bottom of the left-hand menu.
For D-link Router
Open the web interface of the router.
Go to TOOLS
Under tools you will find FIRMWARE.
Posted on Jan 20, 2011
Software to rest wap 1001 to default
"Its easy but you have to open the unit. Undo the 6 screws holding the base one
Slide out the internals
You will see spot on the board labels SW for switch but no switch soldered to it.
While the power is on, use a wire to short the 2 contacts of the switch that stand out alone. IE. not the 3 together. Hold this short on for about 5 seconds then the led should blink
Presto!
Its now back to factory default 192,168.1.20, User name is "Admin" and leave password blank as per the manual." -fixyaMarkoa34a5098-f669-488f-a6a9-3f02c825de75.jpg
Nov 11, 2011 | Levelone Level One FreeCon 802.11G Outdoor...
APS 912 worked for about 6mo - 1yr. Used with a
Sorry this is what the industry refers to as a throw away.
Sep 12, 2011 | Tripp Lite Lite APS INT 912 UPS System
Gmail.comi forget password wep-1001
Presto!
Its now back to factory default 192,168.1.20, User name is "Admin" and leave password blank as per the manual."-fixyaMarko6b1bc267-b1e9-46c6-83c5-0f9087420f37.jpg
Sep 11, 2011 | Levelone Level One FreeCon 802.11G Outdoor...
Display light of HP9250C control panel is not working, how do I troubleshoot it.
Building a simple light-emitting diode (LED) light display can be a great project for both children and adults. A simple LED Display Light can be built using
several LED lights, a resistor and a battery. Once the LED lights are soldered together, they can be mounted in virtually any container or mounted to a board
in a pattern of your choosing.
1.Solder the positive (red) lead of the battery holder to one end of the 1K ohm resistor.
2.Attach the free end of the resistor to the positive lead of the LED. The positive lead of the LED is the longer of the two leads. Solder the negative lead
to the positive lead of the next LED. Continue to wire the LEDs, negative to positive
3.Attach the negative (black) lead of the battery holder to one lead of the push-button switch. Solder the other push-button lead to the negative side of the
last LED.
4.Connect the battery to the battery holder. Activate the push-button switch; the LEDs should light up.
5.Disconnect the battery, if needed, to mount the LEDs to your chosen container.
Sep 08, 2011 | HP 9250c Printer
My d-link router name no longer appears in my wireless networks list - I can not find it to connect to the internet wirelessly
Hi, this seems to be either an issue with your router's hardware or local computer wireless adapter hardware. In order to determine which one is it do the following:
1. Go and check the LEDs on your wireless router to see if there are any blinking or switched off as stated in the official manual documentation for DLink products (can be found here or here more specific).
LEDS are as follows (left to right - per official user manual/doc):
- Power LED = A solid light indicates a proper connection to the power supply. cdekatrr_0.png
- Internet LED = A solid light indicates a proper connection to the Internet port. This LED blinks during data transmission. cdekatrr_1.png
- WLAN LED = A solid light indicates that the wireless segment is ready. The LED blinks during wireless data transmission. cdekatrr_2.png
- Local Network LEDs = A solid light indicates a connection to an Ethernet-enabled computer on ports 1-4. This LED blinks during data transmission. cdekatrr_3.png
2. Check the laptop's or desktop wireless adapter if it is disabled or enabled and if is disabled enable it by going to your computer's Control Panel (either winxp or vista/win7) and go to network connections (in vista/win7 put the control panel in detailed view to see more options) and then right click on your wireless connection and click enable.
3. In a case that also the wireless adapter is enabled but you still cannot see any access points/wireless networks please go to your current wireless connection and right click go "Diagnose", this feature is mainly available in windows 7 or Vista. For windows XP, go to the command prompt by going to Start->Run->type in the box "cmd" without the quotes->Then type in the following set of commands.
ipconfig /release ---> This will refresh your wireless card IP settings/configuration to 0.
and after that command finishes, type in:
ipconfig /renew --> This will get new settings if the wireless card has problems finding an address from your router.
You can always reset your router (unplug from power supply, wait 2minutes then plug it back in)
or:
Reset the wireless adapter (right click from on the wireless adapter shown in the network connections, disable and then re-enable it) or computer.
Thanks please let me know if you need anything else.
Mar 20, 2011 | D-Link Wireless N 150 Home Router 4Port...
No wireless signal from the router, overheating
its not desirable that the router should get Hot. Only suggestion is you can go in for a replacement
May 31, 2010 | Linksys WRT160N Wireless Router
The power light is very dim and all 4 ethernet port lights are on and internet light is on too, but we are not getting any connection
If hard resetting it does not let the power light lit fully , then it already a hardware problem inside your router , no getting enough power. Bu dont worry it may just be too that the Power light led is just not lighting up properly.
Apr 06, 2010 | Linksys WRT300N Wireless Router
Power led solid red, internet led solid green
Sep 15, 2009 | Actiontec GT704WG Wireless Router...
When I connect the ethernet cable to my tower, I gave an orange light. What could be causing this to happen?
What Orange light are you refering to? You have an orange and green LED on the block of the Ethernet connecter, if the cable is plugged into the plug and the other end is terminated into another deive such as a modem,bridge,router or switch the orange light(led) should come on as that indicates a valdi link hence being called the link light, the green light(led) indicates data being received or transmitted. If orange flash with sparks(bad) from the plug it means there is power on the cable..very bad as this could be due to the ethernet card that is faulty or the device on the other end of the cable is faulty.
Aug 01, 2009 | Intel Ethernet 10/100 Network Adapter
Computers & Internet Logo
46 people viewed this question
David Payne
David Payne
