Question about Garden
My echho pb250 leafblower stopped running and now it wont start
  • 4 Answers
There is a very small screen inside the carb that gets blocked up from the additives in gas. Clean it up and use a stabilizer in your gas/oil mix.
Posted on Nov 18, 2014
My echo pb250 leaf blower wont start
The first thing that I must ask is, "Did you store your blower with gas in your fuel tank? If so, your carburetor will have to be rebuilt because the fuel breaks down the diaphragms and cloggs the screen inside the carburetor. If you didn't store your blower with fuel in the tank then pull the spark plug to see if it's firing. If you have fire the you have to check the compression because you need at least 95psi in order for your blower to run.
Nov 22, 2014 | Garden
Whats going on with my pb 200 starts but wont stay running air filter is soaked with gas
You probably have the needle in the carb not shutting off or going back to shut off the fuel. What you need to do is rebuild the carb and most lawn shops can sell you a kit to do that. You can see videos on youtube.com as to how to do it if you are not familiar with the rebuild process it is not hard to accomplish. The kits are around $8.00. Hope this helps.
May 10, 2014 | Echo Gas Blower 135 MPH390 CFM Blower...
LEAFBLOWER WON'T START
check fuel lines inside fuel tank, see if will run on a shot of starting fluid e85 gas eats them
Sep 01, 2012 | Weedeater 2 Speed Gas Blower FL1500LE ()
My Black & Decker Leafblower Leaf Hog BV4000 type 2 quit running suddenly while using. It had run about an hour, was not warm to the touch and is 2 years old. Is thuis a common problem and what might
Same thing here after i did my neigbours yard!!!! i found out it was the switch the latch that moves it wont I am trying to work a away round it hope this helps
Nov 18, 2011 | Black & Decker Leaf Hog 12-AMP Electric...
Blower starts and runs for 5 seconds and cuts off. Is it an oil to gas ratio. Is is 32:1 or 40:1? For the Echo PB250 gas blower.
I don't think the oil-gas ratio will cause that problem. Did you check to see if the fuel lines or fuel filter is clogged?
Aug 15, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Machine runs for short time then stops
may need a carb kit or the fuel lines and fuel filter replaced
May 19, 2011 | Echo Gas Blower 135 MPH390 CFM Blower...
Craftsman leafblower running worse
Check the exahust screen (if fitted) for blockage. or exahust port...If it is clean port and or screen and use correct type/ ratio mix.
Dec 14, 2008 | Craftsman 4 Cycle Blower/Vac
Garden Logo
69 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
