Question about Viva Pinata Trouble in Paradise for Xbox 360
Viva pinata trouble in paradise xbox 360 having troubles getting dragumfly to appear after getting required red hotts
I freed the first dragumfly going through tasks obtained 6 red hotts with hunter and still no dragumfly
Random beeping metal detector
Get a good quality metal detectors would make only 50% of your task. Only by adding accessories to
the Executive setting could be improved. A good pair of headphones, SIP, carrying pouch and a
few of the components should be obtained for any treasure hunter. You'll find audio equipment,
as well as that might help you capture even faint sounds.
more metal detectors
Jan 29, 2013 | Bounty Hunter Digger Metal Detector
Newly installed Hott Rod in 6 gal RV water heater only heats to lukewarm. Has been on for 12 hours. Outside temperature is 60 degrees
Hott rod is 120Volt AC.
Check voltage supply for undervoltage, or reversed polarity, or tripped breaker.
Check that electric thermostat is set to 120 degrees.
Rotate thermostat temperature adjustment back and forth and see if you can hear water heater working.
Thermostats can be bad, or stick.
Check the ECO red reset button is not tripped out.
If tank was not full of water before power was applied, the element will instantly burn out.
Use continuity tester across bare element screws to see if element is good. Or use multimeter and test across bare element screws shows 29 ohm for 6 gallon, 18 ohms for 10 gallon.
More resources at Hott Rod, for troubleshoot and contact.
http://www.hottrod.net/hott_rod_troubleshooting.asp
Oct 31, 2012 | Camco Hott Rod RV/Camper 6 Gallon Water...
Took side cover off to replace gasket. the gears fell out so we stuck them back were we thought they would go now hard too start AND WHEN STARTS HEADER PIPE GETS RED HOTT wat should we do?
I would be VERY worried about the gears falling out. That is NOT supposed to happen. What happened to the nut on the end of the crankshaft??? When replacing the gears, is the crankshaft balancer now out of time? Did the cam chain jump time? The "red hott" is probably an air leak between the carb and the cylinder. As for what to do, I suggest a dealer look at it and do the repairs. This is a safety issue. The last thing you want is for the engine to lock up causing the bike to go one direction and you going in another direction with your face leading the way. tombones49_287.gif
Sep 11, 2011 | 1994 Suzuki DR 350 S
Red light does not come on when buttoms pressed ,even with new battery,an I obtain a new remote?
Hi and welcome to FixYa, I am Kelly
Kmart and Sears both have replacement remotes for Hunter Fans.
Look on the back of your remote for the model number and you can search
http://searspartsdirect.com using a model search for a replacement.
You can also call the Hunter Fan Company to find out the model of your remote here:
1-888-830-1326. They will ask for the model number of your fan.
The Hunter remotes for the original fans can be one of these 3 models: 27187, 22691 or 27189.
See if you can find one of those 3 numbers on your remote.
Thanks for choosing FixYa,
Kelly
Apr 25, 2011 | Hunter Designer's Choice 5-Switchblades Lg...
On viva pinata for pc it asks for you to press the home key to make a account but i press it and it wont do annything
I had this exact same problem. It appears to be a service running in the background that stops running. For some reason I can get signed into ALL my other Xbox Live Games for Windows games, but not Viva Pinata.
As I understand it, all you need to do is restart the service called Cryptographic Services.
To do that, go to the Start Menu, and then the Run or Search Field. Type msconfig in that box and press enter. Once msconfig opens up, click on the Services tab. Once that tab opens up, find the Cryptopgraphic Services service and start or restart it. Now try Viva Pinata again. It should work like a champ!
Jan 09, 2011 | Microsoft Viva Pinata for PC...
Just installed hott rod to camper and it keeps blowing fuses what's wrong
A six gallon universal style hott rod, is supposed to draw only 4 amps when heating. What you need to do is double check any other items running on that same circuit. Not uncommon for people to plug it in to outside GFI and then find out that GFI protected receptacle near sink inside is on same circuit, and they are using that for coffee maker, or hot plate etc, which will in most cases overload the circuit.
Shut that circuit breaker off, and see what else isn't working then do an amperage draw calculation to see if you may be overloading it. If no chance of overload, then you may want to re-check how you wired it in case of a short, or loose connection. If all that checks out good, then I'd look at the hott rod itself as the culprit.
Dec 11, 2010 | Element Hott Rod Water Heater - For 6...
Carrier 6 wire, installed programmable hunter ther...
Is this a heat pump? Look in the thermostat. You should have something like the following.
Red wire to R terminal
Green wire to G terminal
Yellow wire to Y terminal
White wire to W or W1
Blue or Orange wire to the O or B terminal
Brown wire to C terminal.
Let me know what you have in the thermostat. The wire colors are not always the same.
May 21, 2010 | Carrier 38BRC048 Air Conditioner
Viva Pinata Trouble in Paradise for Xbox 360 Logo
57 people viewed this question
Top Viva Video Game Consoles & Games Experts
James Wishart
Are you a Viva Video Game Console and Game Expert? Answer questions, earn points and help others
