Question about Electrical Supplies
Why no spark on 3.5kVA inverter generator ?
No spark. Swapped ign coil with another gen with same model coil. Either coil works in other gen, neither works in problem gen. Checked earth to coil ok. Checked run switch. Checked oil level sensor. Actually also cleaned carbi bowl and jet and tested vac operated fuel pump while I had covers off. CDI unit fault ? How to confirm ? Can I meter out the alternator windings ? There must be some detail out there ?
  • Tony
    Tony Nov 15, 2014
    Got it working again !
  • 1388 Answers
SOURCE: Suzuki SE4000SED generator with no output
There was a day and time when generators were simple. There were no capacitors, regulators to control/adjust power to magnet or ground fault outlets. Winding getting hot indicates short, however could be bad capacitors. Rectifiers and capacitors must be removed from circuit to test properly. Here is a simple test that I use to find fault area. I use a small power supply (16v AC 1 amp like doorbell transformer) into the 110v outlet of generator. This should energize the armature magnet and actually produce voltage at commutator with brushes pulled off. You can slowly pull the starter rope to move the armature into a different positon the voltage will vary. If the ac windings are shorted there will be very little or no magnet. There is a seperate 110 v circuit at the 220v outlet to test (there are two 110v windings that make up the 220v outlet, one is also used for the 110v outlet). There is another winding that products voltage for the regulator that powers the magnet thru the brushes but I think that circuit is porbably working because of the heat in the windings. You might even have 110v power at the 220v outlet. As our parents told us over and over, be careful when working with electricity. Enjoy
Posted on Dec 08, 2008
Benimur
  • 6966 Answers
SOURCE: 2007 wrf250 loosing power similar to running out of fuel
Hi and welcome to FixYa,
Initially, pls try without the fuel filter and replace the fuel hose with bigger inner diameter.
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 20, 2008
  • 62 Answers
SOURCE: Kipor 3000ti generator, doesn't start, i checked
Drain carb bowl it could have water in the gas
Posted on Apr 07, 2009
mamicheddy
  • 79 Answers
SOURCE: Won't continue running
This unit has a fuel solenoid on the carberator, which opens to allow fuel to the carberator. Check to see if this solenoid opens while cranking.
Posted on May 07, 2009
  • 274 Answers
SOURCE: Honda generator ei3000. Will run only a few mins
Tank filter not blocked? (Take tap off tank) Enough oil in motor? Try overfilling it slightly
Posted on Oct 23, 2009
1998 blazer 4.3l crank but no spark condition
use your key fob to start it,your security is on
Apr 22, 2017 | 1998 Chevrolet Blazer
What is the point gap for model:CCKA-S/25830?
Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ...
www.partsfortechs.com > Home > Generator Part
Generator Parts Spark Plug # RS17YX for Onan 167-0272 on RV Gensets ... for this plug require the spark gap to be set at .025" (25 thousandths of an inch).
Onan Gen HGJAB What is the best spark plug and gap? - Heartland ...
https://www.heartlandowners.org/.../39632-Onan-Gen-HGJAB-What-is-t...
Jun 8, 2013 - 3 posts - ‎3 authors Also what is the the correct gap on the plugs? ... brands · Generators; Onan Gen HGJAB What is the best spark plug and gap? ... Gap: 0.025
Nov 04, 2015 | Watts Onan Portable Generator - 4000 ,...
Back cylinder not firing. swapped coils and checked voltage at coils. generator seems to be pulsing.
To fire up the bike will need gas and a good spark on time.
Do you have a wet spark plugs on rear, if not, you have a carb problem (clogged jets, no fuel in carb chamber, torn diaphragm),
if it is wet, you have a spark plug problem. Take one out and check the spark (in darker room, you can not see the sparks on sunlight)
Dec 29, 2014 | 1995 Honda VT 600 C Shadow
Xingyue
Yes, the IC-2500 module is the cause of no spark.
I have swapped the module with a friend's generator to check.
my gen then runs fine. But must give the module back !
now I need to buy a replacement module, any idea where I can get one ?
Jun 27, 2014 | Electrical Supplies
This gen won't start , good fuel, carb good get's air & fuel spark plug new. any ideas
if it has air fuel and spark then check the compression. if it has all 4 of those then it will be a timing issue but I am willing to bet you are missing 1 of the 4.
Sep 28, 2013 | Champion Fulfillment Champion 2000 Watt...
Hi there I'm stuck I don't know how to check the
Sorry but they either work or they dont.
If yours isn't working, replace it.
But before you replce it consider checking the other components, because ign mods are exspensive.
it sounds like you've been already checking the other stuff. heres what i'd check if your bike came to my shop.
1. battery fully charged, and can take a load. (weak batteries = weak ign power)
i have a bike that won't fire at all with weak battery. Make sure battery is good.
2. check for spark at plugs, make sure plugs are good. Pull plugs and turn motor over.
rest plug next to head and turn over, do not touch the plug while turning over
or you can be shocked.look for spark.
if you have spark , then you ign mod is working.
if no spark, then check #3
3. power to coils. check the power going into coils,
if power but no spark, then coil is bad.
if no power. check #4
4. power to coils comes from a ignition system ( points/ cdi /ign. module)
there is a stator and a rotor. and a signal generator. on your motor
the signal generator wire sends a signal to the cdi, every time the rotor rotates.
the ignition system (ign.mod) sends power to coil.
so if no signal to the cdi, then signal generator is bad
if signal going into cdi but not sending the power to the coils then the cdi/ ign. mod is bad.
Hope that helps
Best Regards
Big Al
Jun 28, 2011 | 1995 Honda VT 600 C Shadow
Heart Freedom 20 will not default to generator power.
First of all it is possible that the is no power going into the inverter,trace the input source to see if the connection from the generator is ok. check the fuse if it is broken if not, the contactor or switching relay in the inverter is bad
Apr 06, 2010 | Xantrex Technology Heart Freedom 20 12...
Iam working on a Honda cbr 600 2005. It was running and quit. Ihave repaced the computor and still no fire to the plugs.Have swapped #1 coil with #4 still no fire. The cam sensor appers to have...
A couple of initial checks:
  • 2nd 10A fuse in the fuse box;
  • IGN +12 on black/white wires going to the ignition coils;
  • IGN +12 on black wire going to the ignition control module;
  • IGN +12 on black/yellow and black white wires of the engine stop switch;
  • pulsing low AC voltage from the ignition pulse generator (white/yellow and yellow wires);
  • start with the sidestand folded up and/or the clutch pulled in.
Good luck and thank you for asking FixYa.
Jan 05, 2010 | 2000 Honda CBR 600 F(4)Y
Lost of spark after running for short time.
Are u using the spark plugs that the manufacturer recommends. I can suggest you one thing, you can test the coil when it is cold and it tests okay resistance values okay, but sometime when it is hot the coil shorts, and I have seen this happened check values when the coil is hot. Check resistance for the primary and secondary coil windings and record when coil is cold and when coil is hot
Jul 23, 2009 | RTO New Yamaha Inverter Ef2400is / Yamaha...
Hi, i have a clarke generator g900 ,no spark
this gen has a oil level sensor that will short the "primary" of the ignition coil as well as a spark enhancer that is called a CDI unit but the drawing does not show a Capacitor in or near it?
I hope this helps
Where did you get your replacement coil Colin?
Peter
Jun 22, 2009 | Electrical Supplies
Electrical Supplies Logo
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
