Question about Iomega Computers & Internet
Whats the GB : iomega P/N 31803800 model GDHDU
    Master:
  • 876 Answers
500 GB
Posted on Nov 15, 2014
Testimonial: "Thx !"
Where can i To buy A MOTHERBOARD
try Summit computers and accessories,.if it's on the market
they can find it for you..any computer part, repair or replacement part
They will even instruct you on how to install if you prefer..
also their prices and turnover times are among the best you will ever find.
Mar 06, 2015 | Hard Computers & Internet
Iomega gdhdu driver
goto iomega for the mac driver, then install in mac
Jan 08, 2014 | Computers & Internet
How to take apart a gdhdu hard drive
Not a good idea. With the correct screw drivers it can be done. WHY? there is nothing to fix, and most likely it will be useless when you finish.
Apr 18, 2013 | Iomega GDHDU2 2tb Select Desktop Hard...
My iomega hard drive Model No GDHDU has just stopped working the power light isnt on but the power lead is fine I CAN`T ACCESS ANYTHING PLEASE HELP
Your hard drive is not getting the power from the port u r connecting to. So please check it with other port . If the same behaviour then it is physically damaged and u have to take it to the service centre
Feb 01, 2011 | Iomega (33150) Hard Drive
I have the Iomega model GDHDU 2 and I want to reformat it from being formatted for a mac to being formatted for windows. I purchased it because it is compatible with Mac and PC. I already managed to...
this should just be a matter od plugging in the drive, if recognised, right click on the drive icon and format to ntfs.
If not recognised. Control Panel / Admin tools/ computer management / storage/ disc management.
Locate the drive (which will appear unallocated) right mouse click on it, then new simple volume and format
Jan 25, 2011 | Iomega (33600) 160 GB USB 2.0 Hard Drive
I have an Iomega GDHDU 2 external HD - 1TB. Just got it today, and when I plug it in it crashes XP (XP - SP2, 1.66GHz, 0.99 GB RAM, Del Inspiron Laptop 1420). I don't get the big blue screen, I get a...
Dell has stated in Dell knowledge base document FA1021802, that a USB device (such as a external hard drives, scanner, printer, etc) may not be detected or function correctly when connected to the USB port of a Dell Latitude or Inspiron PC (it may occur on other models as well).
Various communication errors may occur, including device initialization and device not found errors.
Some Dell computers do not provide enough voltage from the USB ports to power some USB devices.
Dell recommends purchasing a powered USB hub to provide the USB devices with enough power to operate correctly.
I think this explains it. Thank you and good luck!
Nov 01, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Model GDHDU Iomega external usb drive It's been...
body { background: #FFFFFF; margin: 0px; padding: 4px; font-family: arial, verdana, sans-serif; font-size: 10pt; } p { margin:0px; padding:0px; } .spwrap { background: transparent url(../wysiwyg_rte/misspell.gif) repeat-x scroll center bottom; } Hello
Okay , so there are some steps to figure out what is wrong with your external.
Firstly , if your computer makes a sound when you plug in your external , go to Start-Control Panel-Administrative Tools-Computer Management-Disk Management , and see if your external drive is listed here with your local drives. If it is listed , right click on the drive and change the drive letter to make it appear in "my computer".
If your drive does not make a connection sound when connecting to your computer and also does not show up , please follow the next step.
Remove the hard drive from the casing if possible and install it in your computer case or another external case.If the drive works , the problem is with the casing and you can ignore the drive.
Now , if the problem is with the casing , there are still 3 possibilities.
  1. The USB cable between the drive and the computer may be damaged.
  2. The circuit board which connects your drive to the interface of the external may be blown.
  3. The power supply (if applicable) may have a blown transformer.
The latter is the easiest to diagnose , does your external light up at all when you plug in the power? If not , then this is probably your problem. On the bottom of the adapter is a label which you will be able to use to have a new adapter made at your local electronics shop and this will cost about $30 max. They will also be able to test the adapter with a clamp meter to see if this is really the problem and this should be free.
The second component you want to test is the USB cable. If you have a printer , swop out the cables and see if your printer functions normally. Most externals use the same connector so you should be able to test it in this manner. If the cable works go on to the last step. If the cable is defective , replace it with a new one which you can find for about $10 at most electronics and chain stores.
The last component to test is the circuit board. This is a bit of a grey zone as you probably won't be able to spot the blown component unless it failed really badly. With the casing already opened , locate the external's circuit board and check to see if you have any blackened components or fluids leaking from some components. If all the other components of the external worked perfectly , then this is the faulty part. It is not really economical to replace the circuit as most of the time it is out of production by the time you need to replace it and it still costs a lot even if it is available so if your drive is working perfectly when connected via sata or IDE on your computer , the best is to buy a new casing and place your old drive in the new casing.
A casing costs about $50 and you could get it at most tech shops and big chain stores like Best Buy.
I hope this solves your problem and please reply if you need more help.
Kind Regards
Andrea
May 20, 2010 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Computers & Internet Logo
461 people viewed this question
Top Iomega Computers & Internet Experts
Owen Barnes
Martin Murray
Are you an Iomega Computer and Internet Expert? Answer questions, earn points and help others
