Question about Drills
Has anyone brought out a lithium Ion battery to retro-fit into a Makita 8444D drill that currently takes NiMH. I also have the circular saw and jig saw but the batteries don't last very long i
Has anyone brought out a lithium Ion battery to retro-fit into a Makita 8444D drill that currently takes NiMH. I also have the circular saw and jig saw but the batteries don't last very long in these..
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 142 Answers
Batterypakrebuilders.com can rebuild your batteries.
Posted on Nov 14, 2014
SOURCE: makita lithium ion 18 v battery wont charge
this normaly happens when the battery has been kept in cold conditions . keep your batteries indoors try sitting them on a radiator for a short period and they should take a charge . cold weather effects the cells in lithium ion batteries .
Posted on Feb 09, 2009
  • 9 Answers
SOURCE: Makita 18v Lithium-Ion BL1830 Battery Won't Charge
If you have been a bad boy and managed to short the battery by using it for non-proscribed purposes, the fusible link will blow (kind of like a fuse) To fix it, open up the battery (use a Torx 10 security bit, or a small flathead in a pinch) On the battery connection nearest the spring-loaded white catch there is a small bridge of metal with a hole in the center. If this is melted you can solder it back together by sanding the two pieces and putting a glob of solder on them. This will void your warranty (duh!) and remove the battery's fuse protection, but it WILL work again. If the link is intact and nothing else is obviously wrong, you almost certainly have a bad cell. I recommend pulling out the bad cell ( it will be the one that does not read between 2.5 - 4 vdc) and replacing it with one from another dud battery- this requires some fudging and re-soldering. Or do what I did, pull the cell, toss the electronics and the short pink wire, add a cigarette lighter socket and voila! you have a portable power supply giving around 14 volts. Charge it up by wiring two cigarette lighter male ends together (check polarity , + to + and - to -) and plug it into your car, but only while it is running or you will be charging your car battery with it! Hope that helps.
Matt Binns GiantGlobes.com
Posted on Aug 18, 2009
SOURCE: MAKITA LI-ION 18V BATTERIES WILL NOT CHARGE
I have had 3 battiers of the new 18v LXT go out on me. And then I had one of my drills burn up that was one of the new 18v LXT. I am stuck with the grinder, skill saw, 2 impact drivers, sawzal, flash light, and a drill. I only have one battery left and 2 chargers. That is funny. I will never buy any more Makita tools in my life.
Posted on Aug 25, 2009
SOURCE: Compatability issues with new Ryobi Lithium Ion Batteries
i have the same problem and have returned once for replacement charger and battery, still no working well help andykrin@yahoo.com
thanks
Posted on Mar 26, 2010
  • 66 Answers
SOURCE: makita lithium ion battery wont charge
does it have green blinking light when you plug it to mains w/o battery in it ?
Posted on Apr 12, 2010
Why will a makita Li-ion 1.3ah battery not fit in other makita tools?
Some of the Makita 18v LXT tools require the BL1830 3.0AH battery and are designed that the 1.5AH battery will not fit.
Jan 12, 2013 | Makita 18V LXT Lithium - Ion Cordless...
Fitting new gearbox to 8444d
that is a pain. when you take them out they have to go back in that specific way that specific place. if you don't get back just right the case won't fit back together. if you take it slow and only remove what you need to remove you may not have any trouble. you will have to remove all the case screws to get to the gearbox. everything is a tight fit.
Jul 04, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
Where can i buy new case for makita jigsaw BJV180 LI-Ion
you can go to Makitausa.com and buy direct or they have a dealer locator on their site so you can buy locally.
Jun 29, 2010 | Makita BJV180 18V Lxt Lithium Ion Cordless...
Makita 8444d mxt drill
what is the setting in your clutch. if you set the clutch to the highest setting and it`s still slipping then you need transmission assy.
May 28, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Makita dc1804f charger will not charge new i-mh 1834 18v battery
I think your tryiong to charge NIMH batteries oon a charger designed for Lithium Ion batteries. With all the new style batteries such as NICAD, NIMH and LI-ION, charging becomes difficult. Most chargers pre NIMH and LI-ion, were designed for NICAD's. The best advise, match your batteries with the correct charger
Feb 06, 2008 | Makita 18V LXT Lithium - Ion Cordless...
Drills Logo
98 people viewed this question
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
