Question about Hotpoint Bwd12, Bwd129, Bwm129 Washing Machine Pump & Filter Housing - C00092264
My machine on spin cluunks but spins though the final result is fairly wet clothes may be the axle is bent ? god with diy could I replace it /.
Not much more to say checked pump ect 1200 spin but does not seem to go that extra it used to on spin . thanks .
    Sergeant:
  • Hotpoint Expert
  • 448 Answers
Pump is normally the cause for this its first comes on to take wait of tub. if water is not pumped out in time washer is spinning with water still in it run just spin again when you see this happen if close are dyer then change the pump its just not fat anymore
Posted on Mar 24, 2015
Why are clothes dripping wet after final spin?
There is a balance sensor in the machine that checks to see if the load is distributed for high speed, When that sensor goes bad, the machine wont spin the water out of the clothes. YOu need to check for spares
Apr 22, 2016 | Tricity Bendix AW1000W Front Load Washer
My clothes are still very wet even after cycle is finished. It is like they are not fully spinning out, even when I select to do an additional spin cycle. Does anyone know why?
I'm an owner as you and do all my repair on multiple FAV6800A machines.
I don't feel from the info supplied that you have a drain pump/drain line issue because you do not take a "ND" error code for "no drain" during the wash cycle.....the wash cycle completes. I don't believe you have a stuck slightly open water inlet valve in the machine because I feel the machine would eventually over fill and flood the laundry area in time.
Is there any standing water in the wash basket when you remove the wet clothes after the final Spin Cycle?
I would place the machine in Service Mode and run it thru a Quick Spin Test (with a wet load) and record the fastest RPM speed the wash basket will spin up to.
You need the Service Manual to help you get into Service Mode to do the test. Are you going to DIY or call in repair service?
If you want to run the Quick Spin test I will look for a previous post on this forum where I called out the process steps.
Oct 12, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Clothes seem too damp after final rince
its a washer ,not a dryer....if the spin setting is set low the clothes will feel quite wet....reset to a faster spin cycle if needed.
Jul 26, 2010 | Whirlpool LSQ9549P Top Load Washer
Model 110 washer will not go into a final high speed spin.
hi, i would suggest the timer/programmer is faultyas it is ok on the other cycles, the noises you have described may have caused some damage,
Feb 10, 2009 | Washing Machines
LG front load washer/ clothes still wet after final spin
The heavy jacket prevented the washer from spinning at a rapid pace, so I added a heavy bathrobe to absorb some of the water and to balance the load. The washer then spun very quickly and drained out all the water.
Jan 07, 2009 | LG WM-1832C Front Load Washer
How can i fix my washer myself?
The washer will not ever completely drain according to Maytag. A certain amount of water stays in the outter tub for balancing the machine for final hyper-spin. However if the machine is not spinning all of the water out and your clothes come out sopping wet....read the long thread I typed out to another person earlier.....it's about 2-3 questions up on the same topic
Dec 11, 2008 | Maytag Neptune MAH5500B Front Load Washer
Kenmore Front Loading Washer Slow Final Spin Cycle
out balance are water still in tub will do that try cleaning out the pump filter under the panel at the bottom of the washer some have a big white looking screw you turnit remove filter if there water in it it will flow to the floor so have something to catch it with
Jan 26, 2008 | Kenmore 44102 Front Load Washer
Clothes too wet
Watch the washing machine go through its complete spin cycle.(It could have a filter in the pump,check for water flow coming out of the drain. Make sure the washing machine is fully leveled with a square. make sure you put fairly big loads to keep it balanced. If the washing comes out wet on the final spin ,add some more garments and then put it on spin again as the w/m might be going out of balance. Under the work bench on top some times there is a spring to adjust the tension. about every five or six years the motor brushes need changing.
Jan 04, 2007 | Bosch WFL 2463 Front Load Washer
Hotpoint Bwd12, Bwd129, Bwm129 Washing Machine Pump & Filter Housing - C00092264 Logo
79 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
