Question about Kyocera FS-1120D
Kyocera 1120 when printing error comes jam, but when you open and close the error goes away and continued with printing
    Habit-Forming:
  • 91 Answers
Aply printhead clean and re calibrate ( allimgmint)
Posted on Nov 13, 2014
4TH LIGHT FROM THE TOP KEEPS COMING ON LEXMARK E232
What this light sequence means that the printer has a paper jam.
When a paper jam occurs, the printer stops and the operator panel's Paper Jam light and Continue button lights come on. Press and release Continue twice quickly to display the specific secondary error paper jam light sequence.
How to clear Paper Jam
Press Continue button twice quickly to see the secondary error code.
To get the secondary error codes
When the Error light (!) and Continue button lights are both on, a secondary error has occurred.
When the Paper Jam light (4th light) and Continue button lights are both on, a paper jam secondary error has occurred.
Press and release Continue button twice quickly to display the secondary error code light sequence.
Press Continue button to resume printing once all the jammed pages are cleared from the paper path.
We recommend that you clear the entire paper path when a paper jam occurs.
To clear a paper jam:
1 If you are feeding paper from a tray, remove the tray, and then remove any jams.
2 Open the front cover and remove the print cartridge assembly.
NOTE: Do not leave the print cartridge assembly exposed to direct light for an Extended period of time. Extended light exposure can cause print quality problems.
3 Remove any jams in the area behind the print cartridge assembly.
4 Lift the flap at the front of the printer and remove any jams beneath the flap.
5 Open the rear exit and remove any jams.
6 After you have cleared the jams, reinstall the print cartridge assembly, make sure all printer covers and trays are closed, and then press Continue button to resume printing.
NOTE: The printer reprints the pages that caused the paper jam.
Jun 30, 2011 | Lexmark E232 Laser Printer
I have this error codecode e000 and 0105 under when i turn on my Canon CLC 1180. where was the fuser user in the CLC? How can i check it?
I think the 1180 is close to the 1120 copier I know. The error code is indicating an upper heater open circuit. The fuser is the very left item when the main drawer is pulled opened to remove a paper jam. There are two handle grips front and rear to remove the assembly. You have to check continuity of the heat lamp, fuses, etc.
Jun 13, 2011 | Canon CLC 1180 Copier
My kyocera taskalfa 180 showing c6400 error please help.
C6400 is a fixing unit error.
To reset -
Try this, enter "10871087" from keypad, You should now be in maintenance mode.
Enter "163"press "Start / Print" key.
You should see a screen that says "Execute".
Cursor / highlight "Execute".
Press "Start / Print key.
The machine will turn off and should come back to ready. If not then you need to replace the fixing unit.
I hope this is helpful,
Shawn
Feb 25, 2011 | Kyocera TASKalfa 180 Copier
Kyocera FS 4000 DN printer stops printing for no reason.
Try the feed tires in the tray first. More than likely the paper is not being picked up and causing jam message. The separation roller also has a hub on it to prevent a second sheet from feeding. Sometimes these start to lock up ,a little oil on the hub sometimes relieves some of the tension.
Jun 03, 2010 | Kyocera FS- 4000DTN Laser Printer
My Samsung CLP 315w refuses to print a whole A4 page. Stops half way then message comes up paper jam but when I open back / front, paper not jammed and when I close it document continues printing then...
most likly hood is your exit sensor is faulty. The printer work in this way. if it does not print out all the document. it will print again. that is why you kept getting this same issue after a jam open and close door it will print again.
replace the exit sensor it will help.
Apr 16, 2010 | Samsung CLP-315W Laser Color Printer
Code 1120:0950659 This code is coming up on a Kyocera FS-9120DN printer. Where can I find error codes on internet?
causes
Poor contact of deck level switch 2 connector terminals
solutions
Reinsert the connector. Also check for continuity within the connector ble. If none,repair or replace the cable.
causes
Defective paper deck motor 2.
solutions
Check for continuity across the coil. If none, replace paper desk motor 2
causes
Poor contact of paper deck motor 2 connector terminals.
solutions
Reinsert the connector. Also check for continuity within the connector able. If none,repair or replace the cable.
causes
The deck right lift does not rise properly.
solutions
Check the gears and belts, and remedy if necessary.
Oct 20, 2009 | Kyocera Mita FS-9120DN Laser Printer
Paper jam light is continually on and I can't reset.
Did you check for jam in the back (open rear door maybe jam is there)?
Mar 26, 2009 | Lexmark E232 Laser Printer
I have a Kyocera FS-2000D printer that will not print
first turn off your pritner power.
check open the front door pull your ink cartridge then clean dust and blur from it then check there is not any paper jam then refix ink cartridge.then turn on the power.
Mar 21, 2009 | Kyocera FS-2000D Laser Printer
Error 002 with Canon image class MF 8180 C
I usually open the back cover, top cover, cartridge cover and pull out the paper tray. Sometimes this clears the alarm, if this does not clear the alarm, I unplug the printer for a couple minutes. Between opening and closing the covers and unpluging the printer, the alarm goes away. Ray
Dec 30, 2008 | Canon imageCLASS MF8180C All-In-One Laser...
Paper curl
When a paper jam occurs, the printer will stop printing and the Continue (1) and Paper Jam (2) lights on the operator panel will come on. See the illustration below.
pattlnk_1052005_1635-enus20238_oppaneljamlights_e230_en_us.gif When you experience a paper jam, it is recommended that you check and clear the entire paper path. To clear a paper jam, do the following:
  1. If you are feeding paper from a paper tray, first remove the tray. Look for and remove any jammed or damaged paper you find.
  2. Open the front cover and remove the print cartridge assembly.
    IMPORTANT!
    Do not leave the print cartridge assembly exposed to direct light, especially sunlight, for an extended period of time. Extended exposure to light will damage the green photoconductor roller and cause print quality problems.
  3. Remove any paper you find jammed in the area behind the print cartridge assembly.
  4. Also lift the flap at the front of the printer and remove any paper you find jammed beneath the flap.
  5. Open the rear exit door/cover of the printer and remove any jammed paper you find there.
  6. Once you have confirmed that the entire paper path is clear, reinstall the print cartridge assembly. Close all the printer covers/doors. Reinstall any paper trays you removed.
  7. Press the Continue button to resume printing. NOTE: The printer should reprint the page(s) that caused the paper jam.
  8. If the paper continues to jam, press the Continue button twice quickly while the Continue and Paper Jam lights are on. This will cause the operator panel to display the secondary error paper jam light sequence. The secondary error code will tell you where the printer thinks the problem has arisen. For more information, see the 'Secondary Error Codes' section on page 69 of the User's Guide.
Sep 04, 2008 | Lexmark E232 Laser Printer
Kyocera FS-1120D Logo
47 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Henry Gertcher
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
