Question about Canon MP610 Photo All-In-One Printer
When i print in color there are horizontal red lines from top of the page to the bottom. Why?
    Habit-Forming:
  • 91 Answers
Apply print head clean and recalibrate ( alligmint)
Posted on Nov 13, 2014
SOURCE: Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Posted on Mar 28, 2008
MJS_1
  • 150 Answers
SOURCE: Horizontal colored lines through grayscale printed photos
Hi George,
It sound's like an ink-feed issue:
1) Dirty heads, even after cleaning
2) No-ink or poor quality ink
3) Damaged head: some are part of the cartridge, some are not
4) Air bubbles in ink
The test page is typically not as hi-res nor as saturated as a
photo print. The hi-res photo puts the greatest demand on the print head.
The color lines you see are actually lines of missing color,
where the head has failed to deposit ink, so one or two primary
colors are missing from the complete picture.
For example missing yellow will make a blue line.
Missing magenta will make a green line
Missing cyan will make a red line.... etc..
Clean the heads again and again, print again and again,
hoping to flush the system.
BUT, keep in mind that cleaning wastes huge amounts of
ink and tiny little cartridges of ink cost more than many new printers.
Martin
Posted on Apr 24, 2008
  • 33 Answers
SOURCE: Photo's print with lines through them
Useually if your printing has lines through it it means that the head (where the ink comes out ) is had it & your up for another head. Sorry but useally big bucks I hope it's still under warranty
Posted on Oct 27, 2008
  • 5 Answers
SOURCE: Horizontal printing not straight
Have you cleaned or replaced the printhead recently?
Posted on Mar 23, 2009
  • 615 Answers
SOURCE: PIXMA ip4000 (windows Vista) printing color in horizontal lines
The following a step by step instructions for the printer issue:
Certain colors are missing or no ink prints on the paper
snap in ink tanks properly iP4000 / iP5000
Install recommended ink tanks in the correct order iP4000/iP5000
Perform deep print head cleaning (Windows) iP3000/iP4000/iP5000 by using the software not manual cleaning.
Remove tape from the ink tank … check ink tank vent hole the ink tank requires air to flow through it so ink can move from the reservoir to the print heads.
  1. Confirm there is no orange tape across the top of the ink tank
  2. If the orange tape is properly removed
Replace ink tank
Your feedback is very important to us, please do not forget to rate my service for the site to continue helping everyone and improve on it.
I thank you for the opportunity to help and please do not hesitate in contacting me for any further questions…god bless
Posted on Sep 17, 2009
Scan/copy issue: horizontal lines and bulb red
It's the scanner fluorescent lamp faulty, replace the scanner will solve the problem
Jul 15, 2017 | Samsung CLX-3175FN Color Laser All-in-One...
Can print the color I want. Only prints red.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Aug 24, 2009 | Lexmark X2350 All-In-One InkJet Printer
Horizontal lines (red) on first 1 - 2 pages of initial print-out
Do you refill ink tank? Print blank pages. Is there horizontal lines appear? It might be caused bay ink leakage. Check respiratory hole at ink tank and rubber seal at bottom of ink tank. Print blank pages until no horizontal lines and try to use new ink tank.
Aug 17, 2009 | Epson Stylus Photo 1270 InkJet Printer
Can't print in color
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.  2. Select "Clean and Fix Horizontal streaks."  Click on "Print". This will produce a printed page.
1. Please open the "Solution center" again and go to the "Maintenance" Tab.  2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.  3. Get a damp paper towel.  4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.  5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.  6. Next dab the cartridge on the towel to make sure that the ink is flowing.  7. Snap the cartridges back into the printer.  8. On your computer, select "Old Cartridge install."  9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
May 26, 2009 | Lexmark JetPrinter Z11 InkJet Color...
My printer wont print color!
Hi.
First check if you are using compatible cartridges for the printer. Use the following weblink to check for compatible cartridges for lexmark printers:
http://www.lexmarkstore.com/store/lexmark/DisplayProductFinderPage
if using correct carts and still issue, then you may try the following to clean the cartridges and print contacts:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier and check if it prints color.
To clean cartridge nozzles:
Click on "Start," go to "All Programs," and down to the Lexmark. Click on the "Solution Center." Next, click on the "Maintenance" tab. Select "Clean to fix horizontal strips." This will produce a printed page.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean to fix horizontal strips" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution Center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge (or cartridges) from the printer.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean. Also, wipe the contacts inside the printer (on cartridge carrier).
9. Repeat the "Clean to fix horizontal strips" one more time. If this fails to address the problem, the entire procedure may need repeating.
Hope dis helps u...
Apr 24, 2009 | Lexmark X2600 InkJet Printer
My printer will not print color
Hi.
First check if u r using compatible cartridges for your lexmark printer. You may use the following weblink to find the comaptible cartridges for lexmark printers:
If using correct carts and stil issue, then check the below info to clean the print contacts and cartridges:
Remove the cartridges from the printer. Take a dry lint free paper towel and gently wipe the contacts on the back of the cartridge (not the bottom from where ink is present). Wipe the contacts inside the printer (on cartridge carrier). Snap the cartridges back into the cartridge carrier.
Try it out..
Apr 24, 2009 | Lexmark X2500 All-In-One Printer
Faint horizontal dark line about 2 1/8 inches down from the top
You can easily fix this yourself, one of the quickest ways to fix it is to print 10 doublesided blank pages and it will clean the inside of the machine for you and the line will vanish.
For further print quality problems on this machine follow these instructions to troubleshoot.
When troubleshooting image quality problems, it is important to understand the situations in which the problem occurs.
Print a copy of the color test pages to determine whether the problem is in one color or more than one color.
  1. Press the [Up] or [Down] arrow button on the Control Panel to select [Troubleshooting] on the Display Screen, and then press the [OK] button.
  2. Press the [Up] or [Down] arrow button to select [Print Quality Problems], and then press the [OK] button.
  3. Press the [Up] or [Down] arrow button to select [Color Test Pages], and then press the [OK] button to print the test pages. If the problem occurs with one color on the test pages, perform the solutions for this problem. If the problem occurs in more than one color on the test pages, restart your search and select a case for the image quality problem occurring through all colors.
Mar 27, 2009 | Xerox Phaser 7400/DXF Laser Printer
Poor printing quality on text
so, what sort of text is it you are attempting to print? what program is in use?
Aug 15, 2008 | Dell A940 All-In-One InkJet Printer
Hi George,
Martin
Apr 24, 2008 | Canon PIXMA iP90 Mobile Printer
Canon MP610 Photo All-In-One Printer Logo
37 people viewed this question
old marine
old marine
