Question about Nextbook Premium 8 Se Android
How do I adjust the sensitivity on the screen
IS THEIR SENSITIVITY ADJUSTMENT FOR THE PAPERWHITE KINDLE
Are you having trouble changing pages? Have you tried taping the lower corner Rt for next page left for last page? Try tap and slide to change pages. I've had mine over 5 years with few or no problems. So far as I know there is no way to adjust it. If it continues or worsens you may want to contact Kindle help.
Oct 31, 2016 | Amazon Kindle Paperwhite
It won't let me use the touch screen
If you have one of the adhesive touch screen protective covers on it. Remove it and try. I have found that over time these screen covers will start to cause sensitivity issues and need to be replaced.
Jul 20, 2015 | Tablets & eReaders
I need a new screen how much will this cost
Screen repairs range from $30 to $200 depending on the unit you have and the demand for the repair. Search for local repair shops in your area and look for reviews. Be careful as many use cheap third-party glass to replace and can result in loss of touch control sensitivity, color and lighting consistency across the screen. Its best to work with a certified provider/repair shop.
Apr 14, 2015 | Tablets & eReaders
The background of my Kindle Fire HD has gone dull and I am having difficulty moving around the screen
Have you tried to go into your settings to re-adjust your lighting? The way to do that is go to the top of your screen and with your finger pull downward and this will show you different settings and one of them is brightness. If you tap on that you are able to control how bright your screen is. As for the problem of having to tap hard to do anything; do you have a screen protector on your screen??? That is a thin covering that adheres to your kindle screen to protect the screen from scratches, etc. What I have found is when my kindle has that problem it is because my screen protector needs a desperate cleaning. It just happened to me recently, I took a cloth and a little bit of windex sprayed on the cloth and cleaned it. I don't recommend doing that on an unprotected screen. I did it because my screen is protected. Once I cleaned it up I no longer had the problem. If none of these work I would contact Amazon or where this was purchased from as it should be covered by a warranty
I hope this helps.
Mar 06, 2015 | Amazon Kindle Fire HD
How to stop notification bar from popping up
Your sensitivity is on too hi and its like your double clicking the screen, adjust your screen sensitivity in your settings.
Nov 16, 2014 | Samsung Galaxy Note 10.1"
How do i make my tablet with a crack screen work again
You HAVE to replace the screen. Once its broken, the display might work; but it will loose touch sensitivity.
If you do have a usb jack for your tablet, you could connect a mouse and a keyboard to it and use it using these external input devices.
Jul 10, 2014 | Iview 754TPC Tablet PC
Turn off predictive text hudl
Go into system to Language and input.
Click on the UNTICKED Google Keyboard English-box at right of page.
If its like my mark 1 Hudl or my wifes Hudl it then shows a Language screen.
Go back and double click the above and go down to text correction where you can either switch off or adjust the sensitivity of the predictions.
Once you have done this a single screen click shows you this "missing"screen.
If you totally dislike the Google keyboard then go into language screen and choose Qwerty keyboard.
Feb 25, 2014 | Tablets & eReaders
Nextbook 8 SE touch screen not as sensitive, have to tap items twice
It might need calibration. There is usually a setting in the display to calibrate the screen. Follow the instructions and see if it helps.
Jan 30, 2014 | Nextbook Premium 8 Se Android
Adjust screen sensitivity on kocaso m1066
Settings/accessibility/touch and hold delay,,,,also language and input/mouse tracker speed
Nov 30, 2013 | Tablets & eReaders
My laptop is Hp TouchSmart tx2,the problm is :-The pointer moves unwnted icon it click by it self.
The problem is very simple. The sensitivity of the mouse pad is too high in your laptop i guess. Try adjusting the sensitivity of the mouse. Go to control panel-> mouse options->mouse sensitivity. Try changing the double clicking speed, mouse sensitivity etc and check your mouse operation now.
Aug 03, 2010 | HP Tablets & eReaders
Nextbook Premium 8 Se Android Logo
63 people viewed this question
Top Nextbook Tablets & eReaders Experts
bigdawg7299
Beej West
Level 1 Expert
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
