How may i enter menu option in Rangs Tv Model - RC2180F ? Let me know plz.
My tv Screen has been vertically small one inch. How can i reset full screen.?
    Top Expert:
  • Televison & ... Master
  • 74,136 Answers
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Posted on Nov 13, 2014
Dutchman
  • 3 Answers
SOURCE: 20 inch T.V.
I have had past experience some years ago with new or fairly new TVs which had vertical deflection failure. I suggest Checking all coupling capacitors on the circuit board around the vertical deflection circuits. One way to check is to turn the set on and slightly warp the circuit board and see if the deflection restores. I have found bad solder joins in several sets which lost the Vert. deflection and was simply repaired by re soldering the connections.
Posted on Sep 01, 2006
  • 236 Answers
SOURCE: scrolling menu option on screen
ON the front panel of your TV, try pushing VOL-UP and VOL-Down at the same time. I've had this happen several times with Magnavox TV's. Stargazer
Posted on Mar 03, 2007
  • 71 Answers
SOURCE: tv picture shrinks to one small line across the middle the screen.
resolder vertical output ic pins
Posted on Apr 27, 2008
SOURCE: toshiba 32a33 32"tv
My dad and I fixed the TV/Video problem over the weekend using one of the solutions suggested. Make sure you stay away from the red wire running from the back of the tube to the circuit board.
1. Take the cover off the back of the TV.
2. On the bottom of the TV is a circuit board that is mounted on top of a plastic tray. Remove the cables running from the speakers by squeezing the tab on the white plug and pulling them up and off the board.
3. Looking at the back of the TV, pull the board+tray out (barely secured in there) and flip it 180 degrees so you're looking at the front of the board.
4. Desolder and remove the TV/Video push button. It's labeled on the PCB, and should be the second button in from the left.
5. Place the tray back in the TV and make sure the other buttons still remaining on the baord are aligned with the buttons on the front of the TV.
6. Put the cover back and you're done.
TV works as good as new again. Of course I can't use the TV/Video button on the TV itself, but the remote handles that fine. 20 minutes max, and no repairman needed.
Posted on Jul 07, 2008
SOURCE: Accessing Menu Sharp TV
I have a Sharp TV model 27F-S40 and also do not have the remote. I need to access the menu to change color, sound, etc.
Can I access the menu thru the channel or volume buttons on the face of the tv?
Bob
Posted on Nov 08, 2008
How to reset samsung led tv to factory settings?
Step 1 Press the "Menu" button on the Samsung LED TV or the remote control. Step 2
Press the up or down arrow buttons and highlight "Support." Press the "Enter" button to open the Support Menu.
Related Reading: How to Reset a Samsung DVD Recorder Step 3
Select "Self Diagnosis" and press the "Enter" button. Select the "Reset" option and press "Enter." Step 4
Enter your TV's security PIN. The default PIN is 0000; however, if you had previously changed it, enter the new PIN. Step 5
Select "Yes" to confirm your selection when the "All settings will return to factory defaults except network settings" dialog message appears on the screen. The TV powers off automatically and restores the default factory settings.
How to Reset Samsung LED TV to Factory Defaults
Nov 29, 2015 | Samsung Televison & Video
Apex AT2702 27" color television under scan
well most of the modern tv today doesnt have vertical hold anymore.
this symptom is caused by a trouble in the IC integrated circuit or the vertical oscillator circuit. let the service guy do the job if u dont know anything about this. good luck!
Sep 18, 2008 | Televison & Video
I have no remote for tv and picture I get is not full screen. How do I use menu to get full screen picture?
Comcast remotes generally do not allow you to use the menu option for your TV. Check the Dynex website by entering your model number to find the manual for your tv.
Dec 30, 2014 | Dynex 32 in. LCD Flat-Panel HDTV
I can't turn off the demo mode on my sony bravia tv
Press Menu on tv remote, go to Settings and select Factory Reset and press enter button on remote, tv will reset to factory default settings and turn Off and On again itself, now select HOME mode instead of Shop mode to avoid demo mode and go by initial setup screen instructions.
Above are generic info about Sony bravia tv, let me know model number of your tv if you do not see factory reset option in settings menu.
Thanks.
Nov 08, 2010 | Sony Televison & Video
I have a 26inch Console Zenith Color TV, when I turn it on, I get a full pidture and sound but after 30 seconds, about 6-10 inches of the bottom screen goes black--but the rest is ok???
Get the remote control and press the MENU key repeatedly until you see the Video menu at the bottom of the list of options you will see EZ Picture.
Use the up/down arrow keys to select EZ Picture and use the left/right arrow keys to select your preference. Set the preference to Preset not custom.
Press Enter, Quit or Menu to exit. See if resetting the TV's Picture settings resolves the problem.
If you have a bar at the top of the screen as well then it could be in letterbox viewing mode. Again just go into the Video menu and turn it off.
Please let me know how you get on.
Good luck.
Jan 14, 2010 | Zenith C27A24T 27" TV
How to center a screen?
Horizontal centering is performed in the service menu. Beware! You can mess up a lot of stuff in this menu.
Aug 02, 2009 | Toshiba Televison & Video
Wd57731 57 inch
There is no way to check it unfortunatly.
Jul 17, 2008 | Mitsubishi WD-57731 57" Projection HDTV
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Televison & Video Logo
50 people viewed this question
Top Televison & Video Experts
Electro Med Services...
