Question about Funai 32MF339B 32 in LCD TV
How do i tighten a loose rf antenna connector
    Top Expert:
  • Funai Master
  • 74,383 Answers
Contact any service technician. Electro help
Posted on Nov 13, 2014
How to connect sega master system 2 to lcd plasma tv
If your TV comes with a composite video input then this may not be an issue. You need the RCA AV cable. Sega outputs only mono audio so put Yellow in TV video In and White in TV audio In (white connector).
http://www.gametrog.com/GAMETROG/HOW_to_connect_Hook_Up_SEGA_Master_System_Instructions.html
If you still have the RF box for the Sega then you should be able to put RF from Sega and TV antenna to the RF box and connect RF box to TV antenna in.
If TV is only HDMI input then you need a converter like this
Composite Video to HDMI Converter
Sep 04, 2014 | Video Game Consoles & Games
Cable in connector broken off
guess u mean the antenna in or also called rf. in this case if u are involved in electronics and have a soldering iron u can open the rf converter and solder a rf cable inside and leave it out the original hole and connect a simple plug for connecting to antenna. just ask again here to topic if something is unclear.
Feb 07, 2011 | Toshiba CF36H40 TV
I have a green screen but I can hear the sound. Amovie plays in the dvd player but the picture is green when I try and watch the cable. Please help.
I take it your DVD is plugged into your Video in and your Cable is plugged into your RF connector or Antenna input. IF this is the case, you might have a bad RF cable. Can you run RCA cables from your Cable box to your TV? This should help with quality of picture as well as better sound. RF Connectors are old school. In todays market, they don't need to be used anymore. I don't use my RF connectors at all. I hope this helps you.
Jan 06, 2011 | Mitsubishi WD-60735 Projection Television
Little white dots on the screen
Your cables to your TV are loose. You must have a firm fitting on the RF connector. You may also have a loose connections from the vcr to the TV [in some cases your vcr is on as well, creating these dot s you refer to.] Or loose fitting from the satellite/cable box to the TV. A firm fitting is call a good ground. You will need to check these and tighten these without breaking the connections to the tuner[RF connector]. Many of the coaxial cables you use are the slide on and are not the best to fit! Good Luck and show a few hands of support and thanks for asking!
Sep 30, 2010 | Toshiba Televison & Video
My antena wont go down ,and the motor wont go off , even when the car is shut off .
Unplug the harness to the ant.It will not go off,until you replace the whole ant.mass.The gear(plastic)are stripped out,and the motor can not sense that the any.is moving.
Jan 19, 2010 | 1991 Oldsmobile Eighty Eight
I want to hook up a vcr, dvd & wii to an old tv. I have a video source connector that hook 3 video surces, but doesn't allow for cable antenna. I also have a rf modulator that does have a hook up for...
I haven't fixed it yet. I think I figured out that I have to get a RF modulator that will accomodate more than 1 video source. I just disconnected my dvd player and hooked up my wii to my RF modulator and it works great.
Dec 25, 2009 | Televison & Video
How do I install the power antenna? I have a replacement, and the wiring is there, but I don't see how to mount the part.
PLEASE DON'T FORGET TO RATE!!!!
Removal & Installation
  1. Lower the antenna and remove the luggage compartment trim panel.
  2. Disconnect the lead-in cable from the antenna and ground strap.
  3. Disconnect the antenna motor wires at the connectors and disconnect the control box connectors.
  4. Remove the top mounting nut and stanchion assembly.
  5. Remove the two nuts retaining the antenna bracket assembly to the quarter panel.
  6. Remove the antenna assembly from the vehicle.
Some antennas require a special socket to remove the locknut
Once its loose the nut can be removed by hand. Sometimes it can be twisted off with a needle nose pliers, but that usually ruins the tool
The antenna mounts in the luggage compartment against the support member
The motor and housing sit on a stand that is bolted to the support member
Unplug the antenna lead from the staff tube
Unplug the connector to the motor
Unplug the connector to the relay
Its easier to remove the antennae from the support to gain access to the ground strap screws
To install:
NOTE Correct sequencing for installation is important to prevent water leakage or dimpling of the quarter panel
  1. Connect the antenna cable, power connector and control box connector.
  2. Insert the antenna mast through the quarter panel hole and position bracket on mounting studs in the luggage compartment.
  3. Install the stanchion assembly.
  4. Loosely install the two bracket retaining nuts.
  5. Install the top-mounting nut.
  6. Tighten the bracket retaining nuts.
  7. Install the ground strap.
Nov 19, 2009 | 1990 Lincoln Continental
How do I hook up a VCR to a small Sanyo TV? Thank you
How you hook up the VCR depends on the connections available on the VCR and the TV.
The simplest method is to use a cable from the VCR's RF (antenna) output connector to the TV's antenna input connector and tune the TV to the VCR output channel (3 or 4). You might need to purchase an adapter to switch from the standard plug on the cable to whatever kind of external antenna connector is on the TV. If the set only has a built-in antenna and no external connection at all (which would be quite unusual), you need a "balun" transformer. This has a connector on one end for the cable from the VCR and a flat wire with two terminals on the other end. Attach one of the terminals to the set's antenna with a clip-on jumper wire. Radio Shack sells the parts.
If your VCR does not have RF output but just audio and video jacks, connect those to the TV's a/v inputs if it has them. Again, an adapter cable might be required.
If the TV doesn't have a/v input available, you need an RF converter. This takes the a/v signals from the VCR and produces a channel 3 or 4 output that you can connect to the TV as described above.
It sounds more complicated than it actually is. Once you look at the VCR and TV, and remember that outputs always go to inputs, it's usually pretty clear what needs to be done. If you still have troubles please post a follow-up comment and I'll try to help more.
Apr 22, 2009 | Televison & Video
T.v channels all snowy
1st check RF antenna pin, is it broken? does the antenna wire is connected propery?
2nd check RF pin connector at rear side of your TV, is it OK?
If every thing is Ok n fine, then your TV tuner is dab and need to be replaced.
Jun 25, 2008 | Televison & Video
My scanner
You may have lost your antenna connection.. Is the connection point loose (rotates a little) if you remove the antenna?
If yes, they you need to open it up and repair the connection, and re-tighten the BNC connector..
Jun 21, 2008 | Uniden BC60XLT Handheld Scanner
Funai 32MF339B 32 in LCD TV Logo
Top Funai Televison & Video Experts
Jaime Hernandez
Are you a Funai Televison and Video Expert? Answer questions, earn points and help others
