Question about Toshiba 50HM67 50" HDTV
Is the "color wheel" on a Toshiba 50HM67 DLP TV even accessible?
    Sergeant:
  • 295 Answers
It is but they don't make it easy to get at as I believe you have to remove the whole Light Engine to get at it. They would prefer a qualified technician would do this type of repair.
Posted on Nov 13, 2014
Testimonial: "I'm sure they would. I don't have the funds to pay a tech so I need to learn how to do it but thank you Philip"
  • 2920 Answers
SOURCE: PICTURES HAVE COLOR BLURRY ON TOSHIBA 72HM196
you might try to adjust the focus
Posted on Dec 14, 2008
SOURCE: How to Access Color Wheel on Toshiba 46HM95
I bought a used 46hm95 but it had a greenish "band" that streched from the upper right corner to the lower left corner. It was only noticeable on a white or light colored background, which is why I overlooked it when I tested out the TV.
I took out the bulb and shined a flashlight into the color wheel. I could see a fingerprint smudge on it. I took off the lower rear plastic panel. the rear is split into two section (the light engine is on the right. You'll have to unscrew a metal guard (three scerws), then disconnect the wires coming from the left section, and then unscrew the plastic guard that protects the lens. Then unscrew the light engine (two screws) and slide it out carefully (you don't have to take it completely out, just far enough to reach the screws to the color wheel covers). There are two covers protecting the color wheel, one plastic and one metal. Unscrew the plastic cover first than the four screws to the metal cover. I left the color wheel in place while I cleaned it with a microfiber cloth. I did pull the glass square in front of the color wheel and wiped that down too.
I put everything back together, and now the picture is perfect.
Things to remember are:
*Keep track of the screws and where they belong, as you remove them so you'll remember where they go when it's time to put things back together.
*Mark the wire connectors from any wire you disconnect in case you forget where they go.
*Be gentle with the color wheel and the glass square because they are fragile.
Hope this helps.
Posted on May 19, 2009
Axle80
  • 73 Answers
SOURCE: Toshiba DLP is it even worth it!
Ebay carries this lamp for about $160. Tech prices are falling fast, you can get a similar sized lcd or plasma for around $900 brand new at sams or costco.
Posted on May 31, 2009
SOURCE: I nees a cooling fan for a Toshiba 50HM67 50 inch
trucker I found this website....http://www.discount-merchant.com/ProductDetails.asp?ProductCode=1089868%2DTOSHIBA&Show=ExtInfo hope it helps
Posted on Aug 22, 2009
Testimonial: "Thanks for the tip!"
welcomejee
  • 10594 Answers
SOURCE: I recently replaced the lamp
This is problem of DMD chip that generates picture/ image in this tv and DMD chip is not available separately so complete light engine will be replaced to fix this issue. It is bit costly fix.
Click Discount-Merchant link to view light engine images and they offer required light engine for $330 and local tv repairman will help you to replace it because it needs expertise and skills.
Hope these info will help you.
Thanks.
Posted on Sep 11, 2010
I have a Toshiba 50HM67 DLP that is "strobing" after replacing the bulb
Actually it could be the color wheel issue not spinning at the correct speed. They are suppose to spin at 60 HZ. My suspicion is that it is slowing down so you are seeing with your eye the slower speed.
Nov 13, 2014 | Toshiba 50HM67 50" HDTV
I have a toshiba 50hm67 the picture is prefect dont think the build is bad, but i have a humming coming out of the tv what could that be and how can i fix it.
If it is a high pitched or even fan like sound it may be the color wheel in that set which if I remember is not sold except with a complete light engine, do some research on that model for color wheel.
Nov 04, 2012 | Toshiba 50HM67 50" HDTV
We have 50" Samsung DLP
Yes,the tv have a colors wheel and it is the cause of these problems.Humming noises,motor noises,picture flashes black&white or colors pictures within the pictures.The colors wheel,is dying or already dead.Hire a tv tech. replaced the colors wheel,will solved ur tv problems.
Nov 06, 2010 | Samsung DLP HL-P5663W 56" TV
Toshiba 62hm85 dlp need the code for color wheel tun up
Replace the Color Wheel
Encompass Parts Distribution 1-800-638-3328
Oct 22, 2010 | Toshiba 56HMX195 52" HDTV DLP Projection...
Need to replace light engine on a toshiba 56 DLP
try this link it's arrowed $270
http://www.discount-merchant.com/TOSHIBA-4D09-40A-Light-Engine-w-Color-Wheel-p/1130472.htm
is like this depending on your Tv Model
Nov 24, 2009 | Toshiba 56HMX195 52" HDTV DLP Projection...
Jun 21, 2009 | Toshiba 50HM67 50" HDTV
I have a toshiba tv model 50hm66 and just replaced the lamp for the 3rd time, now the color seems to have gone out, it only shows purple and green
looks like the lamp is on its way out again, you would be better buying a plasma or lcd the quality is alot better and you wont have to change the lamps and there our non :D
Mar 10, 2009 | Toshiba 50HM67 50" HDTV
DLP TV starts to loose picture after 1 - 1/2 hours of use
This tv has a 3 board video path. Analog main pcb --->Digital main pcb --->DMD pcb. see which inputs have the problem to narrow it down. if only some inputs, suspect analog board. if everything flickers(all inputs and menu), suspect the dmd or engine. you can see the lamp shine out the back. if the lamp is flickering, suspect lamp or ballast.
Nov 22, 2008 | Samsung HLN5065W 50" Rear Projection...
Toshiba dlp
The light engine part number is 234054 and cost $456.00
Dec 20, 2007 | Toshiba 46HM95 46" HDTV
Toshiba 50HM67 50" HDTV Logo
94 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
