I have a Fujitsu Asta09jcc Inverter. I has started playing up and not cooling properly. It flashes its lights every now and then. The lights are: (red light) operation and also the timer (green light) flash 3 times together. Then the red light flashes 4 times by itself after. Was wondering if anyone could help. thanks:)
bobotfel
  • 236 Answers
SOURCE: flashing lights on system
Maybe the unit is on test run, try to push the test run button of remote control pointing the remote to the unit receiver.6d9792c.jpg
Posted on Jan 07, 2008
SOURCE: Fujitsu inverter ASTA24LCC aircon wont
Check that the gas is not leaking, that would be the most likely cause.
Posted on Jun 17, 2008
hvac1960
  • 2133 Answers
SOURCE: My Fujitsu air condition had
The unit is under time setting. You have to cancel the timer by dis connecting the power and restart.
Posted on Dec 08, 2010
hvac1960
  • 2133 Answers
SOURCE: Futitsu Inverter Air-con {ASTA09LCC}- Fan operates
To cancel the timer, press timer on setting until it comes 00.00. Or remove batteries from remote and re fix after few minutes. If still problem persists, check and rectify error code of e-5 as follows:
Comms Error, check your wiring, remove external pumps. Split/Multi - check volts from terminal N to 3 = 0 - 65 Vdc, Multi V - 4 Vdc terminals 3 and 4
Hope helpful.
Posted on Jan 09, 2011
SOURCE: fujitsu halcyon ASU12RML unit has
Fujitsu Halcyon inverter codes green light flashes 2 times. Thank's for the help.
Posted on Oct 15, 2011
Fujitsu halcyon economy light and operation light flashing
I have a fujitsu DC inverter model no. ASYG18LFCA not a week old as yet, when I turn it on it works fine for 5mins. then stops and after a short time the timer and economy lights start flashing, can anyone help on this, please.
Derrick
Apr 02, 2012 | Heating & Cooling
FUJITSU Indoor Inverter ASTA09LCC/ASTA12LCC airconditioning - not cooling
If the operation button is flashing 8 times, the timer light should also flash 4 times in each sequence. This indicates a failure of the PFC circuit in the outdoor unit which basically means a faulty outdoor board and will have to be replaced.
If the operation light is flashing 8 times by itself, the indoor controller board may have a fault. You can normally test this by putting the mode on the remote to 'Fan' and checking that the controls otherwise work normally - louvers work as directed and fan speed changes correctly when selected on the remote.
Most likely the fault lies in the outdoor board but you should contact a tech to diagnose correctly.
Sep 24, 2017 | Fujitsu 18C1 Air Conditioner
We have a fujitsu inverter that is wall mounted - model ASTA 09LCC. The fan is working but the air is not cooling. There is a green timer light that periodically flashes 3 times. Any suggestions?
E3 Outdoor activation of high pressure switch.
Check condenser coil. If blocked, clean it. If out door fan rpm less replace capacitor. Helpful?
Jan 02, 2011 | Fujitsu Heating & Cooling
Fujitsu inverter air cond. Just stopped working properly. Model outdoor AOT30PMAL indoor unit AST30PBA-W. Code oper. Red led flashes fast continously green led (timer) repeats 13 slow flashes. After power...
It sounds like your inverter is at fault. You will need an inverter tester ( most good service techs will have one ) to prove that the output to the compressor is correct. If the inverter is okay then it will be the compressor at fault with a location error or it is simply seized. A common fault that caused this was the eev remained closed (coil failure ) and caused the compressor to over heat.
May 11, 2010 | Heating & Cooling
Fujitsu inverter; opens vents but no red light, no cold air
check that it is set to cooling sounds like it may be set to heat in cooling mode the indoor fan should at least run
Mar 10, 2010 | Heating & Cooling
Fault with 241C Aircon
This happen when you use the inverter for a long time and start getting old and over heat...try to power down the units and keep it for about an hour and then starft them again and try to install a small fan to keep them cool.
May 14, 2008 | Fujitsu 24C1 Air Conditioner
Heating & Cooling Logo
73 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
