Question about Sharp SF-2030 - Lower Pressure Roller - Lower-Pressure-Roller-SF-2030
My printer is saying i should replace used toner container?
  • 483 Answers
Dear User,
I am sharing with you the following objects to help you achieve your desired results,
1. Service manual of your printer to understand the problem
2. A link to step by step, with pictures to understand how it is done for a Samsung printer (will help you understand the process)
Link 1. : http://diagramasde.com/diagramas/otros/SF2025_SERVICIO.pdf
Link 2 : http://www.samsung.com/us/support/howtoguide/N0000190/12120/144599
Regards,
Sid
Posted on Nov 13, 2014
Our kyocera printer says WASTE TONER BOX FULL. what does it mean?
there is a waste toner collector, it is a clear plastic container that collects any toner that is not transferred to the paper. after a certain amount of time it needs to be replaced (or taken out and dump the toner) depending on the copier it uses weight of the container or a sensor to block the light if full. if dumping into a plastic garbage bag make sure it is not dark so the sensor can reset, otherwise it thinks it's still full. You will have to Google where your waste toner box is.
Apr 08, 2014 | Kyocera Office Equipment & Supplies
C351. After changing the toner cartridges, the display still says we need to change the toner. How can this be reset?
I am wondering what color of toner it is asking you to replace?? is it maybe change waist toner container?? because this is different. you can replace the container or empty it (messy but it works)
Sep 02, 2011 | Konica Minolta bizhub C351 All-In-One...
Hi, I have kyocera km c850D. Please could you explain why machine keeps saying replace waste toner box although it is quite empty. please advise if tere are any other parts of the machine to clean or...
Are you using a new waste toner container or did you empty the one that was already in the machine?
The machine uses a sensor that looks at the container to determine if it is full of waste toner. If there is toner on the inside sides of the container were it looks for toner it will indicate that it needs to be replaced even if you have emptied the toner out.
It is a good practice to replace the waste toner container with a new one, that is the way the machine is meant to be used.
If you have correctly installed a new waste toner container and the message hasn't cleared you may have a faulty sensor.
I hope this information is helpful,
Shawn
Jan 26, 2011 | Kyocera Mita (km-c850d) All-In-One Printer
I have an MFC Brother printer and I cant copy or print...it says waste toner full??? How do I fix this problem?
What model MFC Brother Printer do you have? The waste toner is left over toner from each print or copy that isn't used. It collects in a different spot in each printer. Usually the waste toner container is with the regular toner cartridge. The printer is able to detect when the waste toner is full by a light sensor in or near that container. Sometimes excess toner collects on the sensor itself and causes it to think the waste toner is full when it actually isn't. Try finding the waste toner container and empty it or replace it. clean the sensor that is on or near the container. it is likely a small black plastic piece that has 2 or 3 small wires coming from it. The model of printer will help to identify where the container is.
Jan 14, 2011 | Office Equipment & Supplies
I have just replaced my imaging unit - now it wants me to replace/install waste toner bin
When the life span of the waste toner container has expired or it's full, the smart panel program window appears on the computer, indicating the waste toner container needs to be replaced. Otherwise your machine stops printing.
To replace it follow these instructions:
-Turn the machine off, then wait a few minutes for the machine to cool.
-Using the handle, completely open the front cover.
-Pull the waste toner container out of the machine using its handle.
-Remove the container's cap from the container, and use it to close the waste toner container opening. Do not tilt or turn over the container.
-Take a new waste toner container out of its package.
-Insert the new container into position and then push it to make sure that it is firmly seated in place.
-Close the front cover firmly. If the front cover is not completely closed, the machine will not operate. -Please make sure all toner cartridges are installed properly. If any toner cartridge is installed improperly, the front cover do not close.
-Turn the machine on.
Dec 17, 2010 | Samsung CLX-3175FN Printer
The screen on my Phaser 6110 MFP says "Remove/Install Waste toner tank." I don't know what that is.
The life of the waste toner container unit is approximately 1,250 pages
for full color 5% image printing or 5,000 images for black printing. When
the life span of the waste toner container has expired, Replace/Install
Waste Toner Tank appears on the display of the control panel,
your printer stops printing.
To replace the waste toner container:
1 Turn the machine off, then wait a few minutes for the machine to
cool.
2 Open the front cover.
3 Pull the waste toner container out of the machine using its handle.
4 Remove the container's cap from the container as shown below,
5 Take a new waste toner container out of its package.
Tip
Make sure that you lay the waste toner container on a flat
surface so that the toner does not spill.
Caution
Do not tilt or turn the tank over.
6 Insert the new container into position and then push it to make sure
7 Close the front cover firmly.
8 Turn the machine on.
Caution
operate.
Tip
After rebooting, your machine will automatically reset the
counter for the waste toner container
From the manual:
http://download.support.xerox.com/pub/docs/6110MFP/userdocs/any-os/en/B_Guide_EN.pdf
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 16, 2010 | Xerox Office Equipment & Supplies
Message: drum full of waste toner. replace drum cart. Does this mean it's time to replace the drum cartridge or do we just empty the overflow? Please e-mail april@happyvalleycc.org
Empty the container that holds the "waste" toner.
You may have to use the controls on the printer to say that you have emptied the container, because the printer is "estimating" (not actually "measuring") how full the container has become, based on the number of pages that have been printed.
May 29, 2010 | Dell 3010cn Laser Printer
Replace waste toner tank Does it mean that the toner is already used
Open your user manual.
Or get one - go to google or samsung.
The life of the waste toner container unit is approximately 1,250 pages for full color 5% image printing or 5,000 pages for black printing. When the life span of the waste toner container has expired, Replace/Install Waste Toner Tank appears on the display of the control panel,
indicating the waste toner container needs to be replaced. Otherwise your printer stops printing.
1 Turn the machine off, then wait a few minutes for the machine to cool.
--- above from manual, following is my paraphrasing due to lack of pictures ---
4. remove the container cap from the back side and cap the opening
5. take the new waste container out of its package
6. install the new waste toner container.
___________
You may wish to TRY EMPTYING the waste toner, but you will find toner is the messiest and possibly dangerous (inhallation, etc) stuff you've worked with. it is an extremely find powder and can cause an awful mess and is best disposed of by capping and replacing the container with a new one (shop around to find them).
DO NOT attempt to vacuum up toner - just my personal opinion - I suspect many vacuums may not have fine enough "bags" to capture this intentionally very fine dust. BUT Toner vacuums do exist and some "may" work.
Jul 17, 2009 | Samsung CLX 3160fn All-In-One Printer
The printer asks for waste toner to be replaced
your printer has waste toner container in it, and it's full. it's needs to be replaced.
if you have a new waste toner container and it's still saying needs replacement, the sensors on each side needs to be cleaned off.
Jun 14, 2008 | Brother Office Equipment & Supplies
Sharp SF-2030 - Lower Pressure Roller - Lower-Pressure-Roller-SF-2030 Logo
62 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
