Car Audio & Video Logo
P
Peter Nyoro Posted on Nov 13, 2014
Need Security code for Panasonic car radio Model CQ-JC179AA. Serial number R31017
tangi
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 09, 2022
tangi
Contributor
Level 1:
Answers
Questions
0
Helped
604
Points
Hello i need code unlock radio
model 08545-00q21
r?f cq-hs0701cj
serial 588698
Guilain BAMUSAMBA TSHIMPAKA
Level 1:
New Friend:
  • Posted on Sep 28, 2018
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
604
Points
CODE RADIO PANASONIC CQ-179AA EV455 66AR0 B SERIE R31017
5 Related Answers
Anonymous
  • 12 Answers
  • Posted on Jan 07, 2008
SOURCE: Becker Car Radio Security Code Unlock
The best way that your gonna find it is by checking out the dealership, they can help you with that
Anonymous
  • 589 Answers
  • Posted on Feb 09, 2008
SOURCE: Stereo security code for Acura TL 3.2
Your code is 42126.
Anonymous
  • 28 Answers
  • Posted on Mar 25, 2009
SOURCE: How to remove Panasonic cq-c1301u unit from car
This is an interesting question. As to the fact that you didn't mention what kind of car you have, I can't give you exact instructions, but I can give you approximate instructions. Read all Instructions b4 you do anything and detach battery b4 working on system!!!!!!
1. Most car's require you to remove a dashboard panel, of not the whole thing. (on a side note, the panel on my jeep that has to be removed just pops out).
2. Next you need to unscrew the adapter kit from the car. A lot of older cars put Double DIN headunits into their cars, These are the larger sized headunits. Most after-market systems require a plastic adapter to allow them to fit into the larger space. As long as your new unit is the same size as the older unit, this piece can be reused.
3. Then you must remove the old headunit from the adapter. Most are either screwed in or have pressure pins that hold it in place. Either unscrew or carefully push down the pressure pins until you can remove the old headunit.
4. If you have already purchased the wiring kit, if necessary, then continue onto next step, otherwise purchase appropriate wiring kit for your headunit and car. Do not open wiring kit until you are ready to hook up your new headunit!!!!
5. Find new wiring kit, detach old wiring kit, and hook up new wiring kit according to included instructions. For best reliability, I recommend using wire nuts as electrical tape isn't as relaible and can come apart after a while. If you need to save space and can't use wire nuts, I recommend liquid electrical tape. Let this dry before you go any further.
6. Attach new headunit to adapter and then attach wiring kit to back of the headunit. Make sure to attach radio cord to back of headunit. Push adapter and headunit back into place, adjusting wires as necessary. Screw adapter back into place.
7. Re-attach dash panel back to car, reattaching screws where and if necessary and reattach battery. Power up car and test system.
8. Listen away.
If you cannot get this to work, most places like Best Buys and Circuit City have professionals that have the necessary parts and expertise to exchange headunits in cars and can do this for a small fee. Just replacing a headunit should be relatively cheep. Adding other components as well would be more expensive.
Anonymous
  • Posted on Apr 10, 2009
SOURCE: Grundig car radio codes
MC761111184851 9.18429-8152 grundig THANKS
Anonymous
  • 9 Answers
  • Posted on Jun 12, 2009
SOURCE: just need to know which wire goes where
orange is normally illumination(not necessary) other is probably cell phone mute
Help me unlock my ford escape panasonic radio code,the serial number is r31017,the type is cq-jc179aa
You need to take that number as well as the VIN and proof of ownership to a Ford dealer and they will a call a special number to get the code. I hope this helps. Take care.
Hi any one know the radio code for ford escape Panasonic model no. CQ - JC179AA, Part and. EV45 66AR0 B
Look inside your manual package and it is usually printed on a card for the radio.
I need the code radio for PANASONIC CQ-JC179AA PART NO EV45 66ARO B SERIAL NO R31017
this site does not have radio security codes well because they are secure. You can buy access at this site for a small fee. www.radio-codes.com
I lost id code security code use radio panasonic cq-vw100u
Unfortunately radio codes for the VW Panasonic radio (using the Serial Number) will not be available for free from anywhere on the Internet.
Try your Main Dealer .....or a Decoding Service (who will plug it into a laptop to read the code in your radio memory chip )
Security code lock
go on the back of the face or on the radio it self it and reset it that should clear the code
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
